R55 Headliner rain leak but no sunroof
Old Aug 6, 2015 | 12:08 PM
WarEagle's Avatar
WarEagle
I have a 2009 Clubman S with no sunroof but for a few months now after a heavy rain my headliner is wet near the passenger visor by the A pillar. If it's bad enough water will also collect near the door seal and fuse panel near the floor.
All my searches came up with how to unclog or reconnect the sunroof drain tube. Is there a roof drain on non-sunroof models? I see a small gap in the drip rail that may be a drain. Could it be the windshield gasket?
Old Aug 6, 2015 | 06:00 PM
daddyandmadi's Avatar
daddyandmadi
I'd guess windshield. Spray it at a car wash and see
Old Aug 7, 2015 | 07:50 AM
Pure Red's Avatar
Pure Red
Ditto on the windshield. As for testing, our best Glass Install guy will often use a small air nozzle and compressed air to shoot air against the suspected area leaking on a glass. It's suprising how often his technique will catch that leak that water testing with a hose didn't pick up.
I think with water, you have to hit the leak just right at times to get water into the vehicle for many types of seal or sealant leaks.
Other times, the water needs to have zero pressure and just gravity to do its work of slowly leaking into your car....
For those leaks, we usually get foiled by too much water pressure being slammed at the glass or seal, the water is just bouncing off since there's too much pressure being delivered.
So, take your time and you'll find it.
Old Aug 7, 2015 | 08:31 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Maybe the Upper Windshield Trim Molding? Pure Red has a good point. Do you notice it wet after it sits there with water or right away when it starts raining? It could be a slow seeping leak or may appear right away.
888.280.7799 | 6am - 5pm PST
Old Aug 8, 2015 | 06:13 AM
WarEagle's Avatar
WarEagle
It's hard to see the leak since it's just the headliner getting damp in the far passenger side corner. I never see it happening, I usually get back into the car after a heavy rain and it's damp. It doesn't happen after car washes if that matters. I think it may be the windshield gasket because I barely touched the gasket on the driver's side and my fingernail went straight through it.
If the windshield is in good condition can I pay to have it re-sealed? Not sure how much that would cost.
Old Aug 8, 2015 | 02:03 PM
Drivehard's Avatar
Drivehard
100% it's a poorly replaced windshield.
As a side note if you had it done via insurance and it was SAFELITE that came too you and replaced it I can almost guarantee it was those monkeys that caused the leak. In fact I guarantee it was them.
Either way it's a windshield leak if you can. Simply set up a garden hose on mist and position it to hit the top of the windshield for about 1/2 hour. You'll find your leak.
Sent from my iPad using NAMotoring
Old Aug 8, 2015 | 02:06 PM
Drivehard's Avatar
Drivehard
In addition without a sunroof the ONLY other point of entry is the antenna. Water does not flow up MR ISAC NEWTON and gravity have proven that
Old Aug 10, 2015 | 10:28 AM
PelicanParts.com
Vendor
The trim can be replaced, but as far as the sealant, I'm not too sure. Most windshield places break the windshield when removing it to replace. I'd call Safelite or a similar company to see what they have to say as far as resealing a windshield and not replacing one.
Old Aug 10, 2015 | 10:49 AM
daddyandmadi
Not sure if you put in the windshield, but most shops have a lifetime guarantee on leaks. Worth a call if you know who put it in.
Old Mar 27, 2018 | 09:28 PM
Subw00er's Avatar
Subw00er
Part 5 (foam gasket) on my car was leaking after a replacement windshield job - it is supposed to be replaced either side after a new windshield goes in. Its probably not your problem though if the water is higher up - I'd agree its likely the top seal #1.
Take care of this issue now. My brothers r53 was neglected and he has a $500 fuse panel connector repair going on now at the dealer.
Also, check your floor for water. Push your finger hard into the little holes for the car mat screws. If it comes up wet you need to take the seat out and lift the liner to dry it out (fan + wait 3 days). Remove the battery before taking the seat out (air bag light will come on if you dont).
Its not hard to do, just a pita.
Old May 3, 2019 | 03:00 AM
cristo's Avatar
cristo
Alliance Member
Just about never use mine.
It often won’t close despite proper
alignment, cleaning and lubrication,
especially in warmer weather.
I only try it if there’s no rain in the
forecast and I have plenty of time to
take the control cover off and finish closing
it with an allen wrench and work for a
while to re-initialize it.
i also put Zippeeshade covers on for
the warmer half of the year.
ToyCar
Nov 19, 2023 05:20 AM
patsum
26
May 29, 2021 06:29 PM
hockeydad51
Oct 9, 2015 01:51 PM
Colt45Magnus
Sep 14, 2015 03:12 AM
