R60 Front Pad Reset
Old Jan 1, 2014 | 11:34 AM
fkelly5's Avatar
fkelly5
Front Pad Reset
Just had my 2013-22k miles serviced and I needed front pads. They had to do some kinda reset that took 4 hrs. My wife picked up the car so I didn't have a chance to ask the SA- Can someone clue me in on what the 4 hr reset was....
Also for anyone that didn't know - when you start the car look at your speedometer the first numbers you see are the number of miles to your next service- who knew....
Okay about that reset done by the dealer? Thanks in advance
Old Jan 1, 2014 | 12:21 PM
Tylerlanger1's Avatar
Tylerlanger1
Well when MINI was making the vehicles condition based service counter it was miscalculated for the brake wear. Vehicles would say they are due for front brakes(or rear) but actually have plenty left. Technicians then must reprogram the entire vehicle to updated the condition based service counter(Usually takes 3 to 4 hours). Then the tech has to put the correct brake pad lining measurement in the vehicles computer through their diagnostic equipment. Hopefully this makes sense to you.
Old Jan 1, 2014 | 12:41 PM
fkelly5's Avatar
fkelly5
Perfect sense and huge Thanks for your response. Is this a 1 time occurrence or need to be done at all brake replacements?
Old Jan 1, 2014 | 12:46 PM
Tylerlanger1
No problem. It only needs to be done once to correct the miscalibration. Now your service indicator should be accurate for the most part.
Old Jan 1, 2014 | 02:26 PM
pidge1114's Avatar
pidge1114
Just had this done as well. Took 3 hours to reset the system. I have 11,000 miles and it said I needed new brakes, which I didn't. All is fine now.
Old Feb 16, 2014 | 05:54 PM
lego's Avatar
lego
This service just popped up and said I need to service the front pads. I'm just at 29,000km (18,000 miles). I hope I don't need them replaced.
Old Feb 16, 2014 | 06:04 PM
fkelly5's Avatar
fkelly5
Wow that is kinda low. I got mine done around the 28,000 mark (front pads only) he said the rear pads would probably need it at about 32-34k.
Old Feb 17, 2014 | 10:23 AM
hoonu's Avatar
hoonu
Thanks for the info, Tylerlanger1. Is this something that the dealer would do prior to getting an erroneous "service needed" alert?
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
FLYM1N1
Aug 15, 2015 11:20 AM
