R60 Problem using key to close windows?
Old Apr 28, 2013 | 06:11 AM
IBAmyB's Avatar
IBAmyB
Unhappy Problem using key to close windows?
I know there is the trick to use the key & key fob to open and close the windows (& sunroof).
I can open the windows/roof using the fob (holding down the unlock button).
However, no matter how much I try, I cannot get them to then close by turning the (hidden) metal key in the lock.
Anyone else have this problem? Any hints on getting it to work?
Old Apr 28, 2013 | 06:35 AM
fkelly5's Avatar
fkelly5
I don't think this is supposed to work in reverse. i.e close the windows. Need to check the owners manual later today.
Old Apr 28, 2013 | 06:42 AM
DKIKK77's Avatar
DKIKK77
You would have to code the computer to close the windows/sunroof with the fob. It doesn't come that way. Check the electrical section on coding.
Old Apr 28, 2013 | 06:47 AM
IBAmyB's Avatar
IBAmyB
I have seen that you should be able to do it with the metal key in the lock, without having to program the fob. Guess not. :(
Old Apr 28, 2013 | 07:13 AM
MIminiclubman's Avatar
MIminiclubman
My 08 Clubbie has comfort access. If I hold the little black button on the door handle down after locking is complete it puts the windows up and closes the sunroof.
Old Apr 28, 2013 | 07:18 AM
IBAmyB's Avatar
IBAmyB
No comfort access here.
I guess I can try to find someone who can code the fob when I move back to the state (MD) later this year.
Old Apr 28, 2013 | 08:07 AM
chrunck's Avatar
chrunck
I can close my windows in my 2012 CM by turning the key in the door without any special programming. I do have comfort access, but every MINI I've had since 2004 has worked the same way.
Old Apr 28, 2013 | 10:37 AM
IBAmyB's Avatar
IBAmyB
Is there some trick to it I am not getting?
I can get the key to lock/unlock the door, but when I hold it turned, nothing happens.
Old Apr 28, 2013 | 12:06 PM
RobG's Avatar
RobG
My 2012 cms does not do this. Just tried it.
I can put the windows downs with the unlock button. The manual says you have to put put the key fob in and use the toggles to close the windows.
Old Apr 28, 2013 | 05:22 PM
vaselas13's Avatar
vaselas13
My 2012 CM won't do it either.... Opens all windows with the fob but won't close them, neither will the key.... Tried several times
Old Apr 28, 2013 | 09:51 PM
Hoydi Cheng's Avatar
Hoydi Cheng
again, you need to code it. see the electrical section of the forums
Old Apr 29, 2013 | 05:29 AM
sbdubya's Avatar
sbdubya
My 2012 does it. Just have to twist and hold the key for about 5 seconds for it to start the process. And yes I have the comfort access not that it should make a difference.
Old Apr 29, 2013 | 07:00 AM
DVUS CPRS's Avatar
DVUS CPRS
2010 CPRS, that key thing doesn't work for mine either.
Old Apr 29, 2013 | 08:07 AM
Hujan's Avatar
Hujan
Got my car coded by Triple_O Coding. I can put windows down or up with the key fob now. Not sure about the sunroof. I'll ask about that when I talk to him today. (Or you can PM him directly; he is a member here.) I do have one-touch sunroof, though, which is pretty awesome.
I highly recommend Okee (Triple_O Coding). He's very courteous and very good at what he does.
Old Apr 29, 2013 | 06:51 PM
Koopah's Avatar
Koopah
Yes. NCS Expert coding can enable the key fob close of all windows and sunroof. While you're at it, enable the Weather Radio feature!
Old Apr 30, 2013 | 08:16 AM
nowhereman's Avatar
nowhereman
the comfort access close of the windows is something all MINIs are capable of and its just a couple of keystrokes in the dealers system to activate it on your car.
However, they wont do it at most dealers because it is not US Spec due to Insuracne and government concerns of people being closed in the window if you use it remotely and dont see them.
if you know a dealer that will do it thats great maybe i can get mine there and get it done.
Dec 23, 2015 10:36 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
skippermini
Aug 13, 2015 06:13 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
