R60 Exhaust Pipes Turn Black
Old Jan 18, 2013 | 08:54 PM
Zazoh's Avatar
Zazoh
Have chrome exhaust tips but they are always back when I wash the car. The black easily wipes off, just curious if this is normal.
I had the solid Yellow Engine light on for a day, but was told by service department could be bad gas or a loose gas cap, next day light went away, but the solid yellow light in the center speedometer is related to exhaust issues.
Old Jan 18, 2013 | 09:12 PM
shark715's Avatar
shark715
We have the same experience withe exhaust tips.
Old Jan 18, 2013 | 09:24 PM
Bakerbrdz's Avatar
Bakerbrdz
Normal carbon build up
Old Jan 18, 2013 | 11:53 PM
FredoinSF's Avatar
FredoinSF
Exhaust tip getting black deposits is normal.
Check engine light on is not. If it went away it was likely loose gas cap.
Old Jan 19, 2013 | 09:46 PM
Zazoh's Avatar
Zazoh
Thanks all.
Old Jan 20, 2013 | 06:43 AM
Koopah's Avatar
Koopah
I am told that an oil catch can will make some difference. The MINI engine "recycles" some of its oil-based vapor back into the intake. An oil catch can will trap some of the vapor and allow the oil to "precipitate" into the catch can before it has a chance to return to the intake. At least that's the theory...
Old Jan 20, 2013 | 08:47 AM
Jimbo's Avatar
Jimbo
I keep a towel out just for cleaning the tips on both MINIs, it comes off easy enough but you can do it every day! I have a buddy that claims the new formulations of gas is the culprit and says there a number of gas additives that can create a more complete burn of the gas and eliminate the deposits. That being said I have not tried any yet so can't say if it works or not.
Old Jan 20, 2013 | 08:53 AM
mbabischkin's Avatar
mbabischkin
As an old veteran MINI owner I can honestly say that MINIs have done this since they came back to the US. My 2003 Cooper and 2005 S used to get the buildup on the tailpipes. Heck even my GTi does it...
I wouldn't be surprised if my Countryman does it when it comes in too...
With the old engines the theory was that they ran rich which caused the buildup...
Old Jan 20, 2013 | 09:25 AM
FredoinSF's Avatar
FredoinSF
My tips seem to be really nasty after the so to Reno trek. Don't know if its the elevation or sustained hours of highway driving. It comes off easily.
Old Jan 20, 2013 | 09:51 AM
ZippyNH's Avatar
ZippyNH
A rag with a bit of WD-40 does a good job of cleaning off the carbon/soot...seems to deley it from reforming too...
Old Jan 20, 2013 | 10:05 AM
bmwr606's Avatar
bmwr606
i think it is just the way that the unleaded fuel (i cannot bring myself to call it gasolene) burns
my 1974 and 1987 bmw motorcycles also get the exhausts black
if i fill them with 100LL avgas, the exhausts turn a nice light tan or gray color
scott
Old Jan 20, 2013 | 04:52 PM
John Richard's Avatar
John Richard
I think this is a universal trait. My service advisor said these cars run rich. It helps to run 91 octane fuel. I keep a dedicated towel handy to keep them clean.
Old Jan 20, 2013 | 05:25 PM
myoung's Avatar
myoung
Low octane fuel causes the carbon build up. If you can find some Sunoco 110 octane fuel, (some independant dealers sell it) or aviation fuel, it will clean the combustion chamber through to the exhaust tips. It will be absolutely clean. Be ready to pay high bucks per gallon though.
Old Jan 20, 2013 | 05:54 PM
Koopah's Avatar
Koopah
So, is 93-octane (AKI) top-tier fuel considered "low octane"?
That's all I've used in my CMS and I still need to clean the tips regularly....
Old Jan 20, 2013 | 07:38 PM
myoung's Avatar
myoung
Yes, 93 octane top-tier fuel in the USA is considered low octane. Unless you try Avgas or Sunoco 110 you won't see the difference. If there is no difference and it doesn't clear up you've got bigger problems. I run 93 and 94 octane fuels and my exhaust carbon up after about 1 full tank. I run 6 to 8 gal of Sunoco 110 every 2 or 3 tanks and the carbon burns right off. What do you consider Top-tier fuel?
Old Jan 21, 2013 | 08:00 AM
Koopah's Avatar
Koopah
{snip}...I run 6 to 8 gal of Sunoco 110 every 2 or 3 tanks and the carbon burns right off...{snip}
Let's see - 100LL Avgas is selling at my local GA FBO for $5.90/gal. My local Mobil station is selling 93-octane (AKI) for $3.70/gal. Based on a fill-up volume of 12 gallons, my up-charge for using 8 gallons of 100LL and 4 gallons of 93 versus the full 12 gallons of 93 is $17.60 per tank. Do this for three tanks and my up-charge is $52.80.
For that up-charge, I can opt to use 93-octane and clean my exhaust tips at each fill-up using a $20 bill, then discard it.
I have over 450,000 miles on four cars (BMW-200k, BMW-150k, MINI-100k, MINI-12k) using 93-octane and careful maintenance. So far, no ill-effects from using top-tier fuel without racing or 110-octane. In fact, one might argue that similar results could be had using top-tier gas of lesser octane (and cost).
{snip}...What do you consider Top-tier fuel?
Top Tier Gasoline
YMMV,
Old Jan 21, 2013 | 08:23 AM
myoung's Avatar
myoung
I have over 450,000 miles on four cars (BMW-200k, BMW-150k, MINI-100k, MINI-12k) using 93-octane and careful maintenance. So far, no ill-effects from using top-tier fuel without racing or Avgas. In fact, one might argue that similar results could be had using top-tier gas of lesser octane (and cost).
Top Tier Gasoline
YMMV,
So your saying you have carbon build-up but you don"t have a problem with it !!
I was responding to those who do have a problem with it.
Old Jan 21, 2013 | 08:43 AM
Koopah's Avatar
Koopah
So your saying you have carbon build-up but you don"t have a problem with it !!...{snip}
I was merely stating that, in my case, 450,000 miles using top-tier fuel has not produced any deleterious effects from carbon build-up to the four cars I mention. And, while this is an admittedly insignificant statistical population from which broader conclusions cannot be drawn, it has worked in my application. YMMV.
Therefore, in my case, the carbon build-up on the CMS exhaust tips I deem to be only a cosmetic issue. Thus, for me, the extra cost of using a fuel-based method of eliminating carbon build-up on the tips seems, IMHO, rather expensive.
However, everyone should have the right to consider this issue in the manner they wish. If they want to use any method of addressing dirty exhaust tips, whether it be through spending money on 110-octane or by keeping a microfiber towel in the way back, it's all good.
Old Jan 21, 2013 | 08:50 AM
FredoinSF's Avatar
FredoinSF
Envious of you guys who can readily get 93 octane. We're stuck with 91 laced with ethanol over here.
Old Jan 21, 2013 | 08:57 AM
bmwr606's Avatar
bmwr606
However, everyone should have the right to consider this issue in the manner they wish. If they want to use any method of addressing dirty exhaust tips, whether it be through spending money on Avgas or be keeping a microfiber towel in the way back, it's all good.
i was not and do not recommend using avgas in your minis
it will kill the O2 sensors and the cat too
i was commenting that unleaded fuel burns black whereas avgas in the same engine will burn tan/gray
either fuel results in some residue as a result of combustion, in this case, unleaded is black and avgas is tan/gray
scott
Old Jan 21, 2013 | 09:08 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
And the WD40 smells good too
Old Jan 21, 2013 | 01:19 PM
Koopah's Avatar
Koopah
Originally Posted by bmwr606
{snip}...i was not and do not recommend using avgas in your minis {snip}
Right you are! IIRC, isn't avgas "low" lead and not "no" lead?
In any case, I edited my last post to read "110-octane" instead of "Avgas".
Thanks for the reminder...
Old Jan 21, 2013 | 01:23 PM
bmwr606's Avatar
bmwr606
correct, 100LL avgas has lead, but it is about 1/8 as much as the older 100/130 avgas, it is still more than the old ethyl or high-test mogas had
scott
Old Jan 21, 2013 | 01:33 PM
jonnieoh's Avatar
jonnieoh
After years of dealing with this problem, I masked off my stainless steel Milltek exhaust tips, scuffed them up with some scotchbrite pads, and painted them with high-temperature matte black paint. I'm so glad I did.
Now, they look mean, and not "unwashed". Never have to wipe off the exhaust tips again.
Old Jan 21, 2013 | 09:06 PM
sbdubya's Avatar
sbdubya
and that is why I did this:
https://www.northamericanmotoring.co...ml#post3442429
