R60 Thoughts on treatment for Mini Mouse Removal
Old Sep 16, 2013 | 04:26 PM
  #51
chrunck's Avatar
chrunck
It's not hard at all. Takes a little longer than the cup holders, but if you did that you can do this.
Old Sep 16, 2013 | 06:43 PM
  #52
thekaus's Avatar
thekaus
Thanks for the response. Are there any screws or does everything just pop off with a trim tool? I didn't see any screws on the parts diagram
Old Sep 17, 2013 | 06:33 AM
  #53
chrunck's Avatar
chrunck
Instructions are in this thread: https://www.northamericanmotoring.co...dash-trim.html
Old Sep 17, 2013 | 07:31 AM
  #54
gob15's Avatar
gob15
Originally Posted by thekaus
I just ordered the parts for this. How hard is it to remove the existing pieces around the air vents. I did the cupholder upgrade myself, and was hoping to do this myself too.
Did you order the flat black or with the chrome trim? If you did the flat black can you post the exact part #'s and where you ordered from?
Thanks and good luck with the install. Looking forward to the pics.
Old Sep 17, 2013 | 07:50 AM
  #55
dpike's Avatar
dpike
51-45-9-810-000 Center
51-45-9-810-003 Left Vent
51-45-9-810-004 Right Vent
those are the numbers that got me my black trim pieces. i ordered through ECS tuning because the parts were in stock. Sewell also carries these parts.
make sure you use a magnetized bit to get that screw behind the glove box and a stubby driver or socket adapter to get the ones under the windshield.
Old Sep 17, 2013 | 07:54 AM
  #56
thekaus's Avatar
thekaus
I ordered the chrome which is 51459810001, 51459810005 and
51459810006. I also got the shifter ring(51169810002), which I didn't get when I did the cup holder upgrade.
The black should be 51459810000, 51459810003 and 51459810004.
I got them from MINI of St. Louis. They matched the Sewell prices or beat them and I didn't have to pay shipping this way. Should arrive by the end of the week.
Old Sep 17, 2013 | 10:18 AM
  #57
kerrys914's Avatar
kerrys914
I did mine a few months back. I am in STL and can help if you get stuck.. PM me if you like
Cheers
Old Sep 20, 2013 | 04:57 PM
  #58
thekaus's Avatar
thekaus
I got this completed today. Sides fit perfect, but the mickey is significantly higher than the dash in the middle like others have reported. I have an '11, so I'm guessing that the dash has gone through many expansion and contraction cycles from the STL weather and since the new part hasn't it sticks up a bit. It still looks much better than the old silver, and i'm hoping that the gap shrinks over time.
Old Sep 29, 2013 | 11:04 AM
  #59
gob15's Avatar
gob15
Thanks guys. I am going o get my order in soon and give it a go. Noted about using the magnetic driver.
Old Sep 29, 2013 | 11:08 AM
  #60
gob15's Avatar
gob15
Quick question. On the Sewell site the description for the part numbers you provided says they are "Piano Black" trim. Is that the flat black with the Piano Trim or are the entire pieces the shiny Piano Black?
Old Sep 29, 2013 | 01:11 PM
  #61
chrunck's Avatar
chrunck
It's just a piano black ring around the vents and speedo face.
Old Sep 30, 2013 | 05:46 AM
  #62
Hope this helps.
Here is what they look like. We have pics on our site of the items which helps a bunch.
Center Mickey Part #51459810000 Piano Black w/ black inner ring.
http://www.ecstuning.com/Search/SiteSearch/51459810000/
Matching Black w/ black shiny ring - Left vent Part # 51459810003
http://www.ecstuning.com/Search/SiteSearch/51459810003/
Matching Black w/ black shiny ring - Right vent Part # 51459810004
http://www.ecstuning.com/Search/SiteSearch/51459810004/
Thanks again.
Old Sep 30, 2013 | 01:16 PM
  #63
gob15's Avatar
gob15
Great. They look good. MINI has a curious way of identifying their pieces so I appreciate all of the good info.
Old Sep 30, 2013 | 01:21 PM
  #64
You are welcome.
There are Black outisde / Chrome ring versions also Just in-case someone is looking for them.
http://www.ecstuning.com/Search/SiteSearch/51459810001/
Air Outlet Cover Trim Left - Chrome / Piano Black Part Number 51459810005
http://www.ecstuning.com/Search/SiteSearch/51459810005/ES2634336/
Air Outlet Cover Trim Right - Chrome / Piano Black Part # 51459810006
http://www.ecstuning.com/Search/SiteSearch/51459810006/ES2634337/
Thanks again.
Alkaidovich
Jan 30, 2021 01:35 AM
Motown
Apr 20, 2018 09:31 AM
kpl
Aug 11, 2015 04:52 AM
xpunisherx
Aug 10, 2015 10:50 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
