R60 Four days, and in for service
Old Dec 26, 2011 | 10:06 PM
Jeremy Brooks's Avatar
Jeremy Brooks
I'm taking my new CM4 in for service tomorrow. It has an irritating vibration at freeway speeds. From other threads, it looks like it might be a defective tire or an unbalanced wheel.
Anybody else had this problem on a CM4?
Old Dec 27, 2011 | 07:20 AM
Flyer53's Avatar
Flyer53
If it's not the tires and or wheels and it's at high speed..(55-75) have them check for the electronic clutch locked in all 4 in the rear differential. I had the same symptons..went through all the obvious…tires, wheels, balancing…etc. Because of no inventory had to wait a bit for the part to come in from Germany. I'm told once repaired, the vibration is gone. I say told…because the day after it was repaired (Thanksgiving) it was left outside and …broken into…more damage in and out then you would think. I'm hoping to see my Mini back this week… Good Luck & let me know how you make out.
Old Dec 27, 2011 | 07:32 AM
Flyer53's Avatar
Flyer53
Jeremy, Might of mis-stated the issue. So I emailed my service department and this what they replied with….Hope it helps!
"We had found that the rear clutch had began to seize up. We replaced the entire assembly for you."
Old Dec 27, 2011 | 02:08 PM
Jeremy Brooks
Just got a call from the dealer. They found out-of-balance wheels. I'll pick it up later today and hopefully the vibration is gone.
Old Dec 28, 2011 | 11:49 AM
Jeremy Brooks
Just to update: The vibration is gone. The steering wheel no longer shakes back and forth at 65+. The only vibration I feel now is normal road feedback. Looks like it was just a wheel balance issue.
Old Jul 29, 2012 | 12:58 PM
spirit bear's Avatar
spirit bear
Its like Mini builds all these issues into the car so you buy the extended warranty.
Old Jul 29, 2012 | 02:11 PM
starman's Avatar
starman
Except that all these problems occurred long before they got to an extended warranty period.
Old Jul 29, 2012 | 02:36 PM
spirit bear
so you end up thinking its a high maintenance car and things will constantly be wrong with it so you buy the extended plan
Aug 25, 2015 07:11 AM
jziran
Aug 24, 2015 04:50 PM
Aug 19, 2015 12:51 PM
oldkid6
Aug 11, 2015 08:13 PM
