R60 Door Lock Horn Beep
Old Sep 25, 2011 | 07:06 PM
rfg123's Avatar
rfg123
Door Lock Horn Beep
Have a 2012 with connected. How in the world do I get the horn to beep when I lock the doors? Owners manual does not seem tom offer that option.
Old Sep 25, 2011 | 07:15 PM
Gentlefury's Avatar
Gentlefury
You don't.
You can clearly hear them lock when you press the key tho. Also I suggest going into the settings panel and turning on auto lock when all doors are closed. It takes like 10 mins so you won't accidentally lock yourself out. But its piece of mind when you park!
Old Sep 25, 2011 | 07:16 PM
Mojito's Avatar
Mojito
Not an option, without an aftermarket alarm anyways
It's nice when you get use to it, no more obnoxious sounds all the time.
Old Sep 25, 2011 | 07:53 PM
less2's Avatar
less2
Originally Posted by Gentlefury
You don't.
That auto lock only works if none of the doors were opened.
Old Sep 25, 2011 | 09:05 PM
WMW's Avatar
WMW
Lock and beep
I just got my 2012 with miniconnect and the factory alarm. I turned the beep off when locking...now just the lights flash. It is some where in the settings. I was playing with so many settings I cannot remember. I will try to find it and post it if I do...
Old Sep 26, 2011 | 07:45 AM
walk0080's Avatar
walk0080
IMO honking horns and beeping alarms during arm/disarm are soooo annoying. If my MINI had it, I would have disabled it ASAP!
Old Sep 26, 2011 | 08:32 AM
bentyyc's Avatar
bentyyc
Honking and flashing lights are configurable in the settings portion of the Connected menu.
If you can't find, I'll try to take pics the next time I'm at my car.
Old Sep 26, 2011 | 02:20 PM
rfg123's Avatar
rfg123
bentyyc: I didn't see the settings in my Connected software. Only the setting to change the auto-lock which I already did.
Old Sep 26, 2011 | 02:29 PM
Mojito's Avatar
Mojito
honking is only available if you ordered the Alarm option. Not many people did.
Old Sep 27, 2011 | 04:31 PM
bentyyc's Avatar
bentyyc
rfg - here is the pic I promised. As mojito mentioned, you do need the alarm. I think with the package options in Canada, I must have ordered one that included it.
Old Nov 3, 2011 | 01:47 AM
I_m_Mini's Avatar
I_m_Mini
I want to know, I don't have the connect am I not able to do anything to the car??
Old Nov 3, 2011 | 04:12 AM
cmcveay's Avatar
cmcveay
Without the connected option, you access most/all of those features through the BC on the turn signal stalk. The menu comes up in the tach to change light settings, triple blink, door lock/unlock and TPMS reset.
Old Nov 3, 2011 | 09:33 AM
rpetrecca's Avatar
rpetrecca
I agree the 'beep' sound was horrendous. I turned it off and now just listed for the locks.
Now if I could only change or lower the sound of the turn indicator....THATs annoyinig.
Old Nov 3, 2011 | 11:58 AM
I_m_Mini's Avatar
I_m_Mini
So I'm still able to access those function. Just not on the big screen!!!
Old Nov 3, 2011 | 05:56 PM
chrunck's Avatar
chrunck
Haha, I can always tell when my wife is in her car when I call her because I hear the turn signal in the background.
I think you can lower the sound in the stereo options somewhere...
edit: Nope! I thought lowering the "Gong" setting would lower the turn signal noise, but no dice. It just lowers the sound it makes when you start the car, leave a door open, headlights on, etc.
Old Nov 3, 2011 | 10:21 PM
soocy's Avatar
soocy
OK, here is my door lock problem: I have Mini Connected. I can lock all the doors at once with the button on the driver's door handle. That part is fine. I can't get the boot to open even when the car is unlocked unless I have the key close to the boot. How do I change that?
Old Nov 4, 2011 | 08:20 AM
AnnArrogance's Avatar
AnnArrogance
I think there's a setting that you can change so when you unlock the car (either with the key fob or by pressing the door handle button), all the doors unlock at once, instead of just the one door. Although I don't know if that applies to the boot...
Old Nov 5, 2011 | 10:40 PM
I_m_Mini's Avatar
I_m_Mini
Just wondering, will the non-connected CM have less access function than the connected one??
Old Nov 6, 2011 | 03:57 AM
Flyer53's Avatar
Flyer53
Yes, in settings you can! Either with fob or the button on the door handle. Even if you set it to 1 door only, if you press it a 2nd time will unlock all the others. If all doors are locked you can open the boot by manually pressing in the large Mini logo lock twice.
one73ronin
23
Sep 22, 2015 09:56 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
