R60 Is there a way to disable HD Radio?
Old Jul 19, 2011 | 06:37 PM
Eric5279's Avatar
Eric5279
Unfortunately I live kind of out in the boonies. Because of this my HD Radio signal is not very strong. So as I am driving the radio switches back and forth between regular radio and HD Radio. Now I would not mind if I did not notice when It did, but every time it switches It I hear a significant difference. It switches often so it has become very annoying at this point. I looked through the radio setting and did not see a way to disable the HD Radio, but that does not mean I didnt miss it.
Is there a way to disable it?
Thanks,
Eric
Old Jul 20, 2011 | 05:20 AM
sgebauer's Avatar
sgebauer
Yes, you can turn it off in the radio settings. I think it's under the "SET" selection. It's also detailed in the manual.
I had the same problem. I was surprised at how different it sounded between HD and not HD for an AM station. Also, couldn't believe that the radio would just keep switching back and forth without automatically turning it off.
Old Jul 21, 2011 | 10:42 PM
Creakhead's Avatar
Creakhead
The thing I find odd with mine is when I have HD radio on I see the station name on the top right of the navigation screen, but not the current song name. If i shut HD off then it will show the song name.
Old Jul 22, 2011 | 03:36 AM
Sealy's Avatar
Sealy
I'm really confused. When listening to HD, if I loose the signal it goes to nothing. There's no switching to non-HD. Maybe it has to do with HD stations here being totally different from non? ie WMZQ is commercial country pap, WMZQ HD is classic and edgier country. I'll also note that it seems that HD is not quite ready for prime time. Here in DC I loose it alot.
Old Jul 22, 2011 | 08:03 AM
jonnieoh's Avatar
jonnieoh
Can you get some sort of an aftermarket antenna booster or something, to pull the distant stations in a bit better?
Old Jul 22, 2011 | 10:01 AM
ghamma's Avatar
ghamma
Maybe you, too, are ready for the longer antenna:
https://www.northamericanmotoring.co...r-antenna.html
Old Jul 22, 2011 | 01:04 PM
rewdpost's Avatar
rewdpost
Click on the station (or press to the right) and you can view station info which will include the current song.
At least that's how it is for the connected interface.
What will drive you nuts though is that this same screen exists for Sirius channels too, but you can't stay on it when switching between sources.
Old Jul 24, 2011 | 06:25 PM
OneTraveler's Avatar
OneTraveler
After bringing Archie home cross country I was able to observe the HD stations in many dimensions. Now, this is totally anectdotal, so feel free to call BS whenever, but I only noticed the auto switching to nonHD channels on those designated as HD1. Channels that were 2 or 3 or beyond would just go silent when not strong enough signal. The same holds true here at home where I have only 1 hd (broadcasting 3 channels...1 switches, 2,3 go silent). Hope this helps.
Old Jul 24, 2011 | 08:02 PM
Sealy's Avatar
Sealy
Originally Posted by OneTraveler
. . . but I only noticed the auto switching to nonHD channels on those designated as HD1.
You may have it there. I assumed that only the alternate channels were HD. If the base channel is also HD, it would cut in and out, as well. I rarely listen to the HD1 channel, so I would not be likely to notice it.
Old Jul 25, 2011 | 08:05 AM
punkrockdoc's Avatar
punkrockdoc
How do you switch between HD1 and HD2,3, etc? I have been trying to figure this out, and can't seem to find it in the manual.
Old Jul 25, 2011 | 10:06 AM
mastawyrm's Avatar
mastawyrm
There isn't necessarily a 1 2 and 3. Those are basically sub channels of a main frequency because digital(HD) takes up much less frequency space so you can have multiple channels near the same frequency but people don't have to use them. Most of the time I've seen radios broadcasting their HD stream on the same frequency as their old standard stream which is why you will see it bounce back to normal when you lose the HD signal. If a station broadcasts an HD stream on a seperate frequency than their normal stream then there won't be anything to fall back on when the HD signal drops out.
Old Jul 25, 2011 | 10:46 AM
punkrockdoc
But how do you switch between a single station's separate HD broadcasts? For example, her in Philly 94.1 FM advertises that they also broadcast different music on HD2, traffic and weather (i think) on HD3, and Phillies info on HD4. I believe that these all come under 94.1 FM, but I can't figure out how to tune between these. Or is the countryman radio unable to do that?
Old Jul 25, 2011 | 10:55 AM
OneTraveler
(note, I have connected so if you don't your mileage may vary): while in the FM radio section, navigate to your desired HD station that you believe broadcasts on multiple channels. Toggle right on the joystick and screen SHOULD slide to reveal 1,2,3 etc. From here you can add them to your presets that will constantly show as <StationID>HD1 or whichever you choose. Hope this helps.
Old Jul 25, 2011 | 11:53 AM
less2's Avatar
less2
I to have Connected hope the visual aid helps.
Click Horse Nipple
Click Horse Nipple
Click Horse Nipple
The ony exception I found was when you enter it thru your presets, you have to click on it twice untill you get the two pieces of paper on the side.
Old Jul 29, 2011 | 03:58 AM
njmike's Avatar
njmike
I don't have Connected. Is there an option to disable HD for me?
Old Aug 17, 2011 | 07:57 PM
creep's Avatar
creep
Page 105 in your instruction manual.
When on the tuner, press "set", uncheck the "HD" box. You radio will now display "(HD)" next to the station instead of "HD". "(HD)" is a station transmitting an HD signal, however digital radio reception is switched off.
Doc Pain
Mar 10, 2021 04:50 AM
pglgp1292
Oct 5, 2015 06:47 PM
simo711
Oct 1, 2015 05:36 AM
ericf1993
Sep 26, 2015 03:58 PM
