R60 Interior Rattles
Old May 25, 2011 | 10:06 AM
BobbyFray's Avatar
BobbyFray
Interior Rattles
I have had my CM All4 for a couple of months now. My only issue is that there are a couple of annoying rattles that only occur when driving on certain road surfaces (it does not happen on nice smooth roads, but these are difficult to find in Seattle!). I need to get my wife to drive while I crawl around and listen to try to identify where exactly these are coming from. It seems that one is coming from above (sunroof trim?) and others from the dash.
Has anyone else experienced this? Am I being too picky or should I make an appointment at the dealer to have this looked at?
Old May 25, 2011 | 10:46 AM
rewdpost's Avatar
rewdpost
There's a whole thread on sunroof related rattles. Hopefully you just have the same issue as everyone else and can resolve it by removing the plug.
Old May 25, 2011 | 02:19 PM
BobbyFray's Avatar
BobbyFray
Thanks, I'll check out the thread. However, I guess that I feel that it should not really be my responsibility to resolve rattle issues on a brand new vehicle. Thoughts, anyone?
Old May 25, 2011 | 02:24 PM
tippykayak's Avatar
tippykayak
I've had two rattles, but both turned out to be things I put in the car (lint brush in the driver door, change in the "ashtray" in the back cupholder). Doh!
Old May 25, 2011 | 02:25 PM
Syck2972's Avatar
Syck2972
I have a small rattle every once in awhile. It is in the drive side passenger door. But it only rattles under 25mph and it isn't all the time.
I'm not too worried about it right now. I've only had it a week, it might just need time sometime to settle in.
Old May 25, 2011 | 02:29 PM
BobbyFray's Avatar
BobbyFray
Yes, I also found these types of rattles (seat belt connectors rubbing on the pillar, cup holders rattling in rail). The vibration rattles I am hearing are soething else. I need to at least figure out where these are coming from as it is driving me nuts!
Old May 28, 2011 | 05:09 AM
JudgeS's Avatar
JudgeS
I have the slightest rattle that sounds like a BB or pea rolling in the dash, when I come to a stop. It's very soft but very annoying, and it's a long roll.
Old May 28, 2011 | 06:14 AM
Cosmic Blue Conspiracy's Avatar
I started a thread under the Problems and Issues. So there are a few things I have learned. The window creaks come from the paint surface rubbing on the flocking. The dealer put a thin strip of teflon tape on the metal, invisible when the doors are closed, and it fixed it.
The dash rattle in the middle may be the speedo. Apparently it is the speedo itself (the interior needle) and not the unit against the dash. They said there is a tech bulletin and it is not fixable at this time.
The ones that drive me crazy are on the right door or dash, somewhere around the front door handle. Certain spoken word things through the HK audio set off the buzz I'm hearing, and it also happens over rough pavement.
The weird thing is my passengers in the front seat can't hear what I'm hearing...ever. When I slam the front passenger door, I do hear a prolonged "twang" like something is loose in the right front door pillar near the bottom, and then again, there is something SOMEWHERE near the right HK speaker or door handle. I think I may have the dealer listen to the vibration as the speaker creates it, just to isolate it, and it may be the speaker itself.
The seatbelt rubber inserts in the door pillars do vibrate, as well.
Old May 28, 2011 | 02:21 PM
John Richard's Avatar
John Richard
That woodpecker in the sunroof drives me up a wall. Gotta get that sucker. Will find out about this plug gizmo.
Old May 28, 2011 | 06:24 PM
The rattles just keep on coming. Tonight the speedo rattled incessantly, the console on the headliner started rattling, and now the rail itself in the rear is rattling (not the accessories). Sounds like I'm in an old cargo van.
Old May 28, 2011 | 07:40 PM
BradfromOntario's Avatar
BradfromOntario
Ours too. I put a rolled up piece of paper in the flap to keep it from making contact and it still rattles. I don't want to remove it until I have exhausted all other options because it is there for some reason.
Old May 29, 2011 | 05:10 AM
RT4's Avatar
RT4
I'm in the same boat... lots of random rattles when I'm not on a perfectly smooth surface. I've driven Chryslers for ever.... and the fit and finish of my Mini reminds me of the K-cars and Daytonas my parents drove in the 80s. I'm amazed at how much the turn signals move around when you touch them. Hopefully this car will be durable.... initial quality isn't that great.
Old May 29, 2011 | 01:46 PM
oxfordgreen's Avatar
oxfordgreen
Similar/Same thing?
I had what sounds like a similar/same thing (and also in Seattle) with an intermittent vibration/rattle sound from day 1 with my CM All4. Long story, but 2 aggravating service visits later turned out to be a sunroof thing. (Though it usually sounded to me like it was coming from the dash.)
Don't recall the exact thing at the moment, but something along the lines of a tube in the sunroof frame that holds some cables, and it was the cables in that tube causing the vibration noise.
Apparently with anything significant with the sunroof, they replace the entire thing in one piece, which is what they did in my case. Probably been a couple hundred odometer miles since it was replaced, and no sign/sound of it since. So appears to be resolved.
If this is what's needed in your case, be warned they had the car for a week to get the part in and install. And make sure they schedule you a MINI loaner instead of the crappy Enterprise rental (which I had on the first visit.) They (Seattle MINI) use Enterprise when all their MINI loaners are taken.
Good luck, hope this helps.
Old May 29, 2011 | 02:53 PM
Oxford...Mine doesn't have a sunroof, and I think many of these rattles are door and dash related. I believe the speedo with the nav screen is problematic and will always rattle. It is disconcerting how many just seem to crop up out of nowhere. Love the handling of the car. Always want to go drive somewhere, but I want the car to not feel like a Yugo in fit and finish.
Old May 31, 2011 | 05:23 PM
BobbyFray's Avatar
BobbyFray
Oxford Green - Thanks for the comments and suggestion on the loaner. I don't want the Enterprise rental! I will take it in soon, but just want to try and figure out where the noises are coming from first. It does sound like some are coming from either sunroof or console above. However, as Cosmic Blue indicates, other rattles appear to be coming from the dash/speedo/display area but I just can't pinpoint the source!
Old Jun 1, 2011 | 04:53 AM
Bobby...The tech at my dealer said it's the speedo needle that vibrates. Still trying to ID my right side door/dash buzzes. Lots of this stuff is temp sensitive.
Old Jun 1, 2011 | 09:31 AM
MINItitan's Avatar
MINItitan
A person I know who used to be a MINI sales person told me when I mentioned I was getting a Contryman that MINI's were "rattle boxes".....
Old Jun 1, 2011 | 10:34 PM
BLAUGRANA's Avatar
BLAUGRANA
Don't know if you sorted this out, but it could be the speaker.
Old Jun 2, 2011 | 09:56 AM
BobbyFray's Avatar
BobbyFray
Cosmic Blue - While sitting in the passenger seat today, I listened to the speedo and clearly heard the vibration coming from behind the nav screen. This is the most irritating of the rattles I have been experiencing and the only one that I can now pinpoint. Thanks again for pointing it out. You mentioned that there is a "tech bulletin" on this issue. Does this mean that they hopefully plan to come up with a fix?
Old Jun 2, 2011 | 10:03 AM
The tech bulletin was the excuse the tech used for why they can't fix it! :-) It's a design flaw or "feature." ;-)
Old Jun 2, 2011 | 11:27 PM
less2's Avatar
less2
Thanks I could not figure out where Woody wood was hiding, because it didn't make the sound all the time.. I thought it was the kids car seat. Time to make a appointment
Old Jun 11, 2011 | 06:14 PM
AlfaDude1's Avatar
AlfaDude1
Rattle Resolved !!!
My Countryman All4 started to rattle on the passenger side dash at around 1500 miles. I haven't had much time to deal with it but finally spent some time today trying to find it. I took everything that wasn't bolted down out of the car just to make sure it wasn't something dumb.
Tonight, I opened the hood and looked around. I opened the battery compartment cover and voila. There is a red plastic cap covering the positive battery terminal that had sprung open and was resting against the inner firewall.
I snapped it back into place and took the same bumpy ride that I take every morning where I could normally hear the rattle. There is now total silence! It feels and sounds like a new car again.
I hope this helps others that have been annoyed by the noise like I have. Let me know if it does.
Old Jun 11, 2011 | 07:52 PM
John Richard
Congratulations are in order for some expert problem solving. Well done. I would suppose this gives others with rattles some hope for a silent future.
Old Jun 11, 2011 | 08:14 PM
I'm going to check on this tomorrow. But I still have issues in the right B pillar. Also, my back passenger seat has some "give" in the seat back, so going over bumps knocks it into the back area, making the sound like the seatbelt hitting the plastic. Front passenger seat has a vibration inside the seat back. I hope to tackle each of these. The window creak is gone due to the teflon tape. The speedo I think will always rattle. Headiner console vibrates also. Very frustrating. If the car wasn't such a blast to drive, I don't know what I'd do.
Old Jun 21, 2011 | 05:46 PM
jerrychimini's Avatar
jerrychimini
Cool Rattle noise
Bobby,
I just got my Countryman S about 4 weeks now. I've exactly the same rattle noise problem when car hitting the uneven surface. The noise sounds like rain drop hitting the roof top. I am checking with local dealer on how to resolve this issue. My Countryman does not have sun/moon roof.
Have you got your noise resolved?
Cheers,
Jerry
San Jose, CA
