New Aux Gauges
Old Dec 9, 2005 | 11:24 PM
guidmini's Avatar
guidmini
New Aux Gauges
Hey 1st gear'ers. Just installed my aux gauges that mount next to
tachometer. wow! it dresses up the dead space around the steering wheel area next to Tach. I don't have the Ralley pack gauges. Just a single Tach. So it looks great. It took about 1.75 hrs to install. Me and my friend who is a Mini tuner did the work. The guages list for $325.00. It consist of a Volt Meter Gauge. and a Supercharger boost gauge. With a new mounting bracket,and all necessary kit to install. This is actually posted from one of the Mini guys. My Setup is the same.
It really glows @ night. I don't have anywhere to post my picture. So i borrowed his. This is something for you newbies that want to dress up that dead space around your steering.
See Ya Guido
Old Dec 10, 2005 | 12:01 AM
Vento9's Avatar
Vento9
Looks nice but $325, Yikes.
Old Dec 10, 2005 | 07:22 AM
jonnieoh's Avatar
jonnieoh
Looks Schweeeeeeet!
I have 2 questions for you:
1.) Do you have any idea what the MINI Dealership would charge for that installation?
2.) How difficult was the installation? I don't know if I would be able to handle it or not, so any insight you could provide would be helpful.
Thanks, Jonnieoh
Old Dec 10, 2005 | 07:49 AM
Thomas J's Avatar
Thomas J
I like the pod for the gauges (looks a lot cleaner than a lot of the aftermarket options), but I'd rather not have the Stewart Warner gauges... Anyone know if the pod can be bought seperately?
Old Dec 10, 2005 | 08:04 AM
guidmini's Avatar
guidmini
Gauges
Uber. The Pod comes with the kit.
You really should not knock the SW gauges. They did a really clean .Job. It also says cooper S on there.I don't think you will find any other guages out there. With the same . Its a clean kit.
John. The Dealer gets 1.5 hrs for ther job according to Factory work instructions MINI. so if the delaer labor rate is say 100.00,your looking @ $150.00. But Most dealer ship I know here in southern cal are @ $115.00-120.00. I did the Job myself . I am Factory Mercedes Benz Technical specialist. So it wasn't to bad. Anyone can do it. Just have to get correct work instructions. They come in box.
Old Dec 10, 2005 | 08:11 AM
10851CS's Avatar
10851CS
Yes, it can be purchased empty. Alta sells them.
Earl
Old Dec 10, 2005 | 08:39 AM
trick's Avatar
trick
I wish I'd get a response from Promini to find out if their pod/gauges are plug and play with the 06s.
Old Dec 10, 2005 | 08:55 AM
Thomas J's Avatar
Thomas J
Thanks, 10851CS... I'll check Alta out!
guidmini- I don't have a problem with the SW gauges in particular, but there are a couple of reasons why I'd prefer something else:
-I'd like to have an oil pressure gauge, not a voltmeter
-I converted my dash lights to blue, so the SW's might not look as good as some of the other gauges available out there... they're still an option, though
I like the OEM kit for the how clean it is and the fact that it says Cooper S on it, but I'm looking for a something a little more suited for my tastes.
EDIT: unless I'm looking at the wrong site, the pod that alta sells is their own porduct, not mini's... I'm looking for someone who sells the oem piece to hold my own gauges. I think I'll give my dealership a call...
Old Dec 10, 2005 | 10:36 AM
elbum0's Avatar
elbum0
Man that looks hot! I'll have to consider that once I get my MINI.
Old Dec 12, 2005 | 02:37 PM
mogsxr750's Avatar
mogsxr750
Nice
Those look great, but my only complaint is that I allready have the OEM gauges down low which have the voltage reading already! That would be a perfect compliment if it were Boost and Oil preasure as opposed to voltage....
Nevertheless...It looks beautiful
Old Dec 12, 2005 | 03:08 PM
newbs49's Avatar
newbs49
If the kit in the pictures are the MINI kit for the column you can't get the pod seperate. Look at the posts under gauges from months ago. The lighting on the factory kit is sub par, very hard to see at night on boost gauge. Mini has got to get rid of the volt gauge and put oil temp or pressure as an option for these . The pod is great compared to any other but as of yet you can only get the whole kit.
Old Dec 12, 2005 | 06:01 PM
Hyper Skip's Avatar
Hyper Skip
Expensive
My dealer, is charging $539.00 for the guages installed. Yikes! We get soaked here in Cali.
Old Dec 12, 2005 | 06:08 PM
Webini's Avatar
Webini
Well that makes me feel a bit better (not). I thought is was just my install that had poor lighting on the boost gauge. Now it seems I have to live with it.
newbs49's Avatar
newbs49
Get the gauges from Classic MINI. I think they only charge $260.00 for the kit. Call Jayson at 440-205-6404.
Old Dec 14, 2005 | 01:36 PM
JET BLACK's Avatar
JET BLACK
[quote=mogsxr750]Those look great, but my only complaint is that I allready have the OEM gauges down low which have the voltage reading already! That would be a perfect compliment if it were Boost and Oil preasure as opposed to voltage....
Nevertheless...It looks beautiful[/quote
promini has what you are looking for.
Old Dec 14, 2005 | 02:38 PM
glassintrepid's Avatar
glassintrepid
Um, mine are fine. They are l.e.d.'s. I think they are brighter than the regular light bulbs.
rikaro
Nov 24, 2015 02:05 PM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
