'05 JCW MCS Technical specs??
Old Mar 4, 2005 | 07:42 PM
Hounddog's Avatar
Hounddog
Where can I find tech specs such as:
type of pistons (forged, etc)
type of crank
valve size
injector size
TB size
compression ratio
gear ratios
differential ratios
Wayne
'05 CR/B JCW MCS on the way
Old Mar 4, 2005 | 10:27 PM
matthewz's Avatar
matthewz
Nice choice..
hey Wayne,
I'd help out if I could, but I can't. That is a FINE selection you've made there, though :-)
See my sig for more ;-)
Old Mar 4, 2005 | 10:43 PM
Edge's Avatar
Edge
AdMINIstrator
Cool sig idea... needs to be updated for the 05s though, first item on the list, the new colors... especially Hyper Blue! Then, they need to add different factory wheel options, the different JCW upgrades (e.g. brakes & suspension), and other new stuff like LSD. Also, no mention of transmission types?
Old Mar 5, 2005 | 02:11 PM
matthewz's Avatar
matthewz
Hey
Hey,
I'm cool with it. It wasn't my web page, after all :-)
Seriously, individual who posted the web page goes by the tag "3D Geek", and is apparently on his 2nd MCS now. Most of the web site ref's his first one, "Yoda The Magnificent".
I could always speak to him about updating the page. I think we'd have to offer new tags, as well. If I break open the decoder page, I can review the format and change it. Might be something for the next few break days I get (Su-We).
Cheers,
Matthew Z.
Old Mar 5, 2005 | 03:00 PM
Edge's Avatar
Edge
AdMINIstrator
I'm guessing that it will be pretty easy - the existing tags can still work, just that new tags and options have to be added to accomodate all of the new options!
If you (or he) are looking for any "beta tester" type people, to help ensure that all options are covered, lemme know.
Old Mar 6, 2005 | 07:24 PM
Hounddog's Avatar
Hounddog
Compression ratio on an '05 with JCW head???
Anyone know the compression ratio on an '05 with JCW head?
Wayne
Old Mar 6, 2005 | 07:46 PM
Ryephile's Avatar
Ryephile
type of crank
valve size
injector size
TB size
compression ratio
gear ratios
differential ratios
Wayne
The whole bottom end of the engine is all the same as the stock MCS; forged crank, pistons, and con-rods. The JCW cylinder head uses the same camshaft and valvetrain, just has ported intake and exhaust runners, so the compression ratio is all the same as stock. The Throttle Body is stock MCS. The Injectors are different, at 380cc vs. [I think] 340cc stock. Transmission, and the whole rest of the car is same as stock MCS. Let's try it the other way, here's what's different than stock:
airbox, ported intake and exhaust runners in cyl.head, injectors, ECU mapping, cat-back exhaust, supercharger ratio (supercharger same as stock, just new), colder heat range version of stock spark plug.
I hope that helps,
Ryan
Old Mar 7, 2005 | 08:28 PM
Hounddog's Avatar
Hounddog
Tech specs
I hope that helps,
Ryan
Ryan,
You were very helpful and answered my real questions, forged crank, pistons and type rods.
One thing though, what is the stock compression ratio??
I knew about the JCW head and the mods are mostly for flow charactersitics and improvements.
Wayne
Old Mar 9, 2005 | 06:52 PM
NealW
Wayne
8.3:1
Old Mar 9, 2005 | 06:55 PM
Ryephile's Avatar
Ryephile
^^ I concur! 8.3:1 is the MCS and JCW Compression Ratio.
--->Hounddog, you're very welcome! :smile:
Old Mar 15, 2005 | 07:23 PM
Hounddog's Avatar
Hounddog
Compression ratio
Originally Posted by NealW
8.3:1
NealW,
Thanks, found the link to the site of the motor manufacturer Tritec Motors and that's exactly what they listed.
Wayne
NYXF56JCW
Nov 17, 2024 05:06 AM
Melvinyip
Apr 17, 2020 09:28 AM
dyeLucky
Sep 11, 2015 10:41 AM
nomar116
Aug 10, 2015 11:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
