Pop the trunk with the key in?
Old Feb 23, 2005 | 07:59 AM
HowardPM's Avatar
HowardPM
Is there a way to open the trunk with the car turned on? In the morning I'll bring the garbage to the dumpster, but rather then turning off my car I just want to hop out grab it out ot the trunk and then get back in and go. The trunk unlock button doesn't seem to work if its in the ignition.
Old Feb 23, 2005 | 08:02 AM
Yucca Patrol's Avatar
Yucca Patrol
Try the unlock switch on your toggle panel. It looks like a little padlock. . .
Old Feb 23, 2005 | 08:03 AM
biggripper's Avatar
biggripper
Just make sure you flip the door unlock toggle first...hop out and open your boot in the usual fashion then get your trash.
Sean
Old Feb 23, 2005 | 08:04 AM
greatgro's Avatar
greatgro
The unlock toggle switch unlocks everything - doors, fuel door and boot hatch.
Old Feb 23, 2005 | 08:27 AM
HowardPM's Avatar
HowardPM
hmm
thought I tried that. Guess not. Thanks
Old Feb 23, 2005 | 08:48 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
reach under the back seat and find the manual pull for the boot. pull it and it opens........or just hit the unlock switch
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 5, 2008 | 08:22 AM
leek's Avatar
leek
My unlock toggle switch has stopped working on the boot (after it had to go to the dealer, apparently for some major reprogramming). Is this something I can program, or does the dealer have to do it?
Old Jan 5, 2008 | 09:22 AM
Msteadman's Avatar
Msteadman
I'm pretty sure the dealer will have to do it. Especially since your issue seems to be an actual malfunction. Selective boot unlocking/locking is not a user programmable setting.
Best of luck in getting it resolved.
Old Jan 5, 2008 | 10:01 AM
mini4rb's Avatar
mini4rb
Unless your MINI is an early 2002 S, that doesn't have a manual release . Found out the hard way when my battery died. So was battery so dead it wouldn't take a jump start through the contact points under the bonnet . I was able to get rear seat backs released and ran jumper cable directly to the battery.
Old Jan 5, 2008 | 11:03 AM
glnr13's Avatar
glnr13
are you sure? did you look UNDER the rear seat? grab hold of the bench area and jerk it upwards and it realeases. the manual release for the boot should be there. oh and you can jump your car from under the hood too.
edit: found a pic of the r56 manual release:
it's the ring in the center, forward of the seat belt clips
Old Jan 5, 2008 | 05:48 PM
mini4rb's Avatar
mini4rb
I had the bench out at that time and couldn't locate anything that looked like a release handle or labeled as such.
I sent a message to MINI USA and this is the reply I rec'd -
"Originally, there were no plans to retrofit a manual release for the boot on the 2002 MINI, however that was being mulled over. I'd suggest speaking to the folks at your MINI dealer for the most recent information. They would be in the best position to update you on any retrofits that may have been introduced."
I haven't taken the time to try locating the release since.
Old Jan 5, 2008 | 05:53 PM
glnr13's Avatar
glnr13
that sux
Chiro444
Sep 22, 2015 02:31 PM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
MiniUnz
Sep 14, 2015 11:11 AM
WillShootPhotos
Sep 14, 2015 07:50 AM
David Eric Rosenberg
Sep 10, 2015 12:34 PM
