New R53 Owner
Old Dec 7, 2018 | 07:39 PM
Crimsonguard6's Avatar
Crimsonguard6
New R53 Owner
I’ve got a 2002 Cooper S, my first wrench turning venture on a modern car. Other cars are a ‘76 MGB w/ 2.8 Chevy V6 and T5, ‘72 FJ55 Landcruiser (in pieces).
I bought the R53 in September with lots of mods to it and enjoying so far, high mileage body, 300k+ but fresh motor.
Engine: Iron block 1.6L bored over to 77.5mm(+.5), Forged Crank, Forged cracked capped con rods, KING rod and main/thrust bearings, RMW Aluminum forged pistons with 8.5:1CR, RMW Race Cam, DDM Works cold air intake and intercooler diverter
Supercharger: Stock M45 with 15% ud pulley
Fuel + Ignition
Bosch 550cc injectors set to 630cc at 45psi
RMW tune, 1000 rpm idle to prevent stall from cam, Rev limiter bumped to 7400rpm
MSD ignition coil pack
NGK 8mm wires
NGK iridium 2 stage colder plugs
Exhaust
Stainless steel Megan 4-1 header
Invidia N1 Catback
BSH lower 50% solid mount subframe side has polyurethane bushing
Passenger mount is the vibratechnics dampener paired with power flex polyurethane bushing on the rocker arm mount
Transmission mount power flex polyurethane bushing
Old Dec 9, 2018 | 08:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Welcome
I've had several MGs so the new MINI is a good match
Old Dec 10, 2018 | 07:59 PM
ItsmeWayne's Avatar
ItsmeWayne
Hi and welcome to the NAM family!
Congrats on your Mini buy!
Where's the pics?
Old Dec 12, 2018 | 10:28 AM
miniCPA's Avatar
miniCPA
Welcome to the forum. When I drive my first gen MINI, "modern car" is the last thing that comes to mind. I guess it is all in your prospective. I suspect that coming from an MG, the MINI is modern without going too far.
We need pictures of the fleet.
Old Dec 12, 2018 | 11:00 AM
Derek86's Avatar
Derek86
Now, that is interesting.
Old Dec 12, 2018 | 04:05 PM
ItsmeWayne's Avatar
ItsmeWayne
In the early 1970's I purchase a 1967 MGB roadster. I replaced the non syncro OD transmission with a 70's all syncro OD transmission. I drove the car daily for 12 years and truly loved it for the time.
Was there highest HP year. I think it was 101HP, or somewhere there about. The 06 MCS JCW (210 Hp) that I have now, is not comparable, as it does everything better and is the most fun road car I have driven. Not the fastest for sure, but it is a monster handling car on the twisties here in southern Oregon.
Fast and fun 1.6 LT supercharged go kart!
Old Dec 12, 2018 | 04:55 PM
Crimsonguard6
And fun. It’s about 155 HP at the moment, complete sleeper. I could bump up the motor to a 3.4 with a Demon 1000 carb, a guy with that set up says he’s around 225 at the wheels. Anymore than that you run into body twist issues.
Old Dec 12, 2018 | 04:57 PM
Crimsonguard6
Was there highest HP year. I think it was 101HP, or somewhere there about. The 06 MCS JCW (210 Hp) that I have now, is not comparable, as it does everything better and is the most fur road car I have driven. Not the fastest for sure, but it is a monster handling car on the twisties here in southern Oregon.
Once I get it running right (ECM mapping issue) I’m gonna put it on the dyno to see where it’s at. Definitely fun to drive the windy roads of Missouri
Old Dec 14, 2018 | 05:25 AM
Derek86's Avatar
Derek86
I'm assuming it's an S10/S15 drivetrain, just not the kind of thing people usually swap into sports cars. Definitely cool.
Old Dec 17, 2018 | 02:24 PM
Crimsonguard6
Correct. If I went with fuel injection, that came out of mid 80s Camaro. That block bores out to a 3.4L which is how you get the 200 HP plus numbers along with a good amount of torque.
Old Dec 17, 2018 | 02:32 PM
Crimsonguard6
1976 MGB with GM 2.8L
Old Dec 20, 2018 | 09:08 PM
SharoSC02's Avatar
SharoSC02
Old poster here, haven't been here for years. Had a 2002 R53 that I added whole bunch of mods, too many to list but check them below in my signature spot with my good friend's Jan's tune, he got it to 220 at the wheel. I miss this place as I spent so many hours and years investigating, researching, discussing and gathering data for my beloved R53 that is now owned by a young kid.
I was lucky enough to oganize a tune weekend with the old enthusiasts here including Jan that flew in and we did a full weekend tunning session for the full weekend. Mine was the last tune and won the grand prize for the highest HP number output which came at the end of the very last day.
Chriscj99
Nov 11, 2012 05:19 AM
Dr. Mini Man
Jul 9, 2010 11:04 PM
mbu
MINI5280
Jun 10, 2010 04:39 PM
Dan00Hawk
Chicago MINI Motoring Club
15
Jul 14, 2007 09:50 AM
