2009 r55 jcw
Old May 6, 2017 | 09:17 AM
boca202's Avatar
boca202
2009 r55 jcw
Yeahh I know it was not a good idea, I bought a 114K 2009 R55 JCW for like $7.5K.
It was in really decent condition overall, however I´m not that sure about the maintenance history.
So far I´ve changed the timing chain tensioner since the rails seem to be in good condition.
Resealed valve cover.
Cleaned manually the intake valves.
Changed plugs.
New battery.
Following: coils, plugs for passenger side PCV hose, catch can for driver side PCV.
Current problems, a light stumble mostly when cold (No CEL, no code), Airbag light since the module is shot. Carbon and water coming out of the catback when starting in the morning.
Any help is appreciated.
God bless all!
Old May 6, 2017 | 02:38 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Welcome to NAM.
There is allot of information here on your model of car between the threads, the members and the vendors. If you have not already done so, may I suggest you check out the Gen2 Stock Problems/Issue folder. You may find some information on your issues.
Old May 6, 2017 | 03:48 PM
boca202's Avatar
boca202
Thanks r53coop.
I've read quite a lot by now, and the stumble when cold seems to be an inconclusive subject.
I'll keep reading though.
Old May 7, 2017 | 07:53 AM
ItsmeWayne's Avatar
ItsmeWayne
Hi boca202,
Stumble at idle may need an electronic tune, to tweak the ECM.
You stated you cleaned the intake valves manually. Just wondering how you did this.
You may want to perform a leakdown test, to see if any valves are leaking, as stumble can be caused by poor sealing valves/seats.
On another note... 114K miles on a Mini is not a common problem, as they run well, for over 300K miles. I see them here in the Pacific Northwest, quite often.
I hope you get your stumble worked out!
Old May 7, 2017 | 10:32 AM
boca202's Avatar
boca202
Thanks ItsmeWayne.
To clean the valves I followed the procedure from this forum. Uninstalled the intake manifold and used brushes and carb clean. The stumble improved as the power, but it's still there.
Old May 7, 2017 | 12:45 PM
Alpha Motoring's Avatar
Alpha Motoring
Try a full walnut blast, I don't think you're getting all of it or even 50% of it doing it manually.
Old May 10, 2017 | 07:47 AM
boca202's Avatar
boca202
to expensive fo me!!! maybe I'll try to build my own blasting rig. thanks!!
Old May 11, 2017 | 08:37 AM
Yea, I would try one of these options. Some people make their own and use the OEM tools or make their own tools. Once it's done you will get your power back and some MPG.
https://www.northamericanmotoring.co...-cleaning.html
Also check the valve cover, it might have a sticky PCV valve which is consuming more oil which then coats the intake valves and needs to be blasted.
https://www.northamericanmotoring.co...nd-more-3.html
Old May 15, 2017 | 04:51 AM
JABowders's Avatar
JABowders
Veteran: Army
Welcome.
Great looking car.
Motor On!
Old May 25, 2017 | 11:22 AM
boca202's Avatar
boca202
Originally Posted by JABowders
Welcome.
Great looking car.
Motor On!
Thanks!!! ;-)
Old May 25, 2017 | 02:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Congrats and good find I've been hunting a JCW R55 to replace our Cooper S R55 shop car.
Old May 27, 2017 | 07:46 AM
azwheeler's Avatar
azwheeler
Hi,
Good looking clubman. I look for quit some time to find my clubman s and it's just over 100k and doing some services, I went to the mini dealer no got the service history and the owner before me did all there Services at the dealer.
