2008 56 S owner in MA
Old Jan 10, 2016 | 01:02 PM
mcn02's Avatar
mcn02
Great site! Cheers.
Old Jan 10, 2016 | 01:18 PM
bavmotors's Avatar
bavmotors
Pics? Background info?
Old Jan 11, 2016 | 09:13 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Welcome to NAM! Post up some pictures of your R56 for us when you can.
888.280.7799 | 6am - 5pm PST
Old Jan 11, 2016 | 07:31 PM
mcn02's Avatar
mcn02
I'll get some up here tomorrow!
Old Jan 12, 2016 | 05:57 AM
Welcome. Yes pics are needed
Old Jan 12, 2016 | 10:07 AM
mcn02's Avatar
mcn02
Old Jan 12, 2016 | 10:10 AM
PelicanParts.com
Vendor
Very nice! BRG is always a great color.
Old Jan 12, 2016 | 10:40 AM
TimL's Avatar
TimL
Welcome from Lowell! Where are you located?
Old Jan 12, 2016 | 01:10 PM
Originally Posted by mcn02
Very nice the dark anthracite R108's look nice and you are lowered a bit Congrats. BRG w/ the anthracite looks good.
Old Jan 25, 2016 | 06:52 PM
mcn02's Avatar
mcn02
The lowering seems to be more of a hassle then worth the look. I would probably bring it back up if I had the original springs. Guess I'll just have to upgrade the suspension good eye!
Old Jan 25, 2016 | 06:57 PM
mcn02's Avatar
mcn02
I'm from Boston but I'm down in Scituate in the south shore. I do trek to the north shore from time to time. Great to see someone nearby. Thanks Pelican on the write up for the engine mount. Any weird surprises when doing the transmission mount? I did the engine and lower mount over the weekend before the snow and with it being nice tomorrow want to complete the trifecta.
Old Jan 26, 2016 | 07:21 AM
Yea, just get coilovers and then you can adjust what you want.
"Any weird surprises when doing the transmission mount? I did the engine and lower mount over the weekend before the snow and with it being nice tomorrow want to complete the trifecta. "
Done them before., No the lower one is easy , quick in and out ( couple bolts ) The upper one can be a bit more work. Were the old ones all cracked out. Power flex also has some upgrade to tighten the lower up a bit , the performance is good for the DD.
https://www.ecstuning.com/Mini-2008-.../Engine/Mount/
Old Jan 26, 2016 | 07:36 AM
mcn02's Avatar
mcn02
To give you an idea. They were getting pretty worn out. I had some pretty serious engine movement under torque so I figured might as well do all 3.
Old Jan 26, 2016 | 07:50 AM
PelicanParts.com
Vendor
Next time, be sure to check out our DIY tech articles on our site. Under MINI > tech info (tab at the top) > R56. We cover all mounts that need replacing as well as tons of other projects. Good job on replacement!
Yep,
Can see the cracking , bet it was there.
When you can see the engine move around by hand pushing on it without any force.
Old Jan 26, 2016 | 08:20 AM
mcn02's Avatar
mcn02
Pelican +1, you have some solid write ups in the DIY. I used them as reference when swapping the upper engine mount. You should add one for the transmission mount. I think you have the r50/53 up there. I'll see if there's a lot of variance in the steps when doing the trans mount.
*Just as a note this all started as I was getting some shuddering when letting the clutch engage with a good amount of torque kicking in. With the amount of engine movement I could not determine if the clutch was worn and needed repair and a flywheel resurfacing. With 80K and 8 years of NE winters I started with the mounts to reduce movement. If the vibrations continue after the final mount replacement. I'll post.
Old Jan 31, 2016 | 01:41 PM
MiniRoadstah's Avatar
MiniRoadstah
Lasted quite a long time under our less than perfect New England wear and tear seasons! Nice Mini!
Jan 6, 2016 02:20 PM
Dec 18, 2015 08:06 AM
Dec 14, 2015 11:14 AM
