Testing TPMS
Old Dec 18, 2015 | 09:50 AM
cdsamm's Avatar
cdsamm
Testing TPMS
I am looking at a used after market set of winter wheels/tires and the seller has said that there the TPMS is installed. I have a 08 Clubman R55, which is when the system changed over, I am not sure if they will map correctly to my mini. Is there anyway, other than actually mounting them, that I can check to see if they will work. Thanks Chris
Old Dec 18, 2015 | 09:58 AM
Need to now what year MINI he had them on by the month/ year. Also do you have the TMPS inboard in the wheels , some early 2008's still had the wheel speed for the TPMS.
If you do you need the -9/2009 TPMS sensors.
More info
https://www.northamericanmotoring.co...port-tpms.html
Old Dec 18, 2015 | 10:13 AM
cdsamm's Avatar
cdsamm
He is not sure as to the year of Mini they came off here is his reply.
"It's a 2013. I bought it used and it has 19" wheels. These 16" were extras and I'm assuming original. The 19" wheels are JCW and the car is not JCW"
I am not sure as to the type of sensor I have in my 2008 Clubman, but I do know that they are very sensitive to pressure, as I have to adjust with the weather. Thanks Chris
Old Dec 18, 2015 | 10:17 AM
Sounds like the stock wheels from the 2013 , which mean the TPSM are for 9/2009+ MINI is my guess. Got the last 7 digits of the vin, I can see if it cam with 16" stock.
Old Dec 18, 2015 | 02:26 PM
cdsamm's Avatar
cdsamm
Last 7 digits are. DWP32679
Last seven digits are DWP32679
Old Dec 21, 2015 | 08:02 AM
Thats a MINI Countryman VIN, 5x120 lug. Do you have another VIN ?
Old Dec 21, 2015 | 09:11 AM
cdsamm's Avatar
cdsamm
Thanks ECSTuning, that is the only number he gave me. Doesn't look like they will fit as mine is a 4 lug. Thanks for your help. Chris
Old Dec 21, 2015 | 09:45 AM
Welcome, yea 5x120 wheels, yours is the 4x100. Mystery solved.
Mini-Rookie
Jan 14, 2018 01:06 PM
Mini_Touge
Dec 23, 2015 11:26 PM
Accessory Products
Dec 15, 2015 03:14 PM
Accessory Products
Dec 15, 2015 01:00 PM
silence2-38554
Dec 12, 2015 06:33 PM
