Mini Cooper Phone Mount Smartphone Xl Pro Series F55 F56
Part No: G3NMI7347
Your Price $99.00
This is a Special Priced Item
Flexpod Universal Scissor Mount is a great solution for you if you don't see a model specific cradle, OR HAVE A CASE on your iPhone, Android, Galaxy S or other device. Kit includes the Scissor Cradle and Mounting Bracket for the right side of the tachometer.
Fits the following models:
2014+ F56 MINI Cooper and Cooper S Hardtop
2015+ F55 MINI Cooper and Cooper S Hardtop 4-Door
The Pro Series Mount is easy to install, and gives you the freedom to choose what angle your smartphone is mounted at. The Scissor Module uses rubberized pegs and a spring loaded cross-grip design that pinches your phone, keeping it in place. You can adjust the device within it's grip to avoid buttons or allow access to plugs on any side of the device. This mount can also be rotated 90 degrees to hold your smartphone horizontally.
The Scissor is best for gripping phones over 2 inches but less than 3 inches wide.
08-16-2016 01:37 PM
11-01-2015 12:03 PM
Suspension Products
10-29-2015 10:23 AM
