Hello from central PA
Old Nov 19, 2015 | 02:20 PM
Rich Rodichok's Avatar
Rich Rodichok
Just bought a 2012 Countryman S with 14,500 miles on it. After 4 days, the clutch went. Dealership had to send it to Allentown Mini for replacement. In the process, I ended up with a 100,000 extended warranty at the dealer's expense, and a new clutch. Pretty happy with the car otherwise. Really my only annoyance with the car is the stupid, small cup holders in front of the gearshift. The left one is in the way for reverse, the right one is in the way for 5th. I was thinking about getting the accessory rail cup holder, but there's the armrest and e-brake. Looking for a better solution. I HAVE to have my coffee when I drive.
Old Nov 19, 2015 | 03:18 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Welcome to NAM! The cup holder thing seems to be a common complaint, mostly because people say they're too small. There is a retrofit thread on here to upgrade to the 2013 cup holders, which are bigger, but doubt that's what you want. I also found this thread here with people posting alternatives that you might find interesting. Otherwise, if you need anything else for your MINI let me know! Enjoy.
888.280.7799 | 6am - 5pm PST
Old Nov 19, 2015 | 04:19 PM
Rich Rodichok
thanks very much. I'll check it out.
Old Nov 20, 2015 | 05:25 AM
Welcome, nice pic near the lake. #1 mod for countryman = front cupholders 51169811185 and for the rear if you don't have the full center rail section + dual read cupholders.
https://www.northamericanmotoring.co...-owners-7.html
Dual rear : Two versions , one with and one without front center armrest.
https://www.northamericanmotoring.co...upholders.html
https://www.northamericanmotoring.co...a-12-a-10.html
Old Nov 20, 2015 | 05:30 AM
Qik420's Avatar
Qik420
I use a tall slim cup, works just fine
Old Dec 7, 2015 | 10:03 AM
Rich Rodichok
just ordered the the front cupholders 51169811185. Thanks, ECSTuning. I'll let you know if I have any install question.
Old Dec 7, 2015 | 10:07 AM
You are welcome.
Old Dec 12, 2015 | 02:11 PM
Rich Rodichok
looks like I must separate the amber plastic lighter bracket from the lighter insert in order to get it into the new cupholder assembly (I was able to force it through the original console with the pieces together) Can't seem to get these two pieces apart. Anyone out there willing to pass on this knowledge. I'm kinda stuck. Thanks in advance.
Old Dec 12, 2015 | 02:22 PM
Rich Rodichok
Never mind, just had to use a little force
Old Dec 12, 2015 | 02:43 PM
Rich Rodichok
NOW I'm a happy Mini Driver.
Old Dec 14, 2015 | 05:46 AM
Awesome, thanks
Old Dec 19, 2015 | 08:41 AM
Rich Rodichok
Hey, ECSTuning
I love the new, larger cup holders, but I'd like to get the trim ring for the top that is notched and the rubber bottom circular pads for the cup holders. Could you give me those part #s? I'm looking on the ESCTuning site but don't see them. Thanks for your help.
Old Dec 21, 2015 | 12:01 PM
Hey, ECSTuning
Notched ? The trim ring is notched on the insde of the newer cup holders ?
Front insert for newer larger cupholder 51169811184
https://www.ecstuning.com/Search/SiteSearch/51169811184/ X 2
Old Dec 21, 2015 | 12:53 PM
Rich Rodichok
I thought I read somewhere that there was a gray trim ring that had notches to match the larger cupholder notch below it. Sometimes when I pull my cup out, it grabs the gray trim ring and pulls it off. Of course I may have dreamt it. I will order the bottom inserts. Thanks
Old Dec 21, 2015 | 12:57 PM
Oh, ok, thought you ment lower cup trim.
Notched trim only comes in black. 51169810002
https://www.ecstuning.com/Search/SiteSearch/51169810002/
Old Dec 21, 2015 | 01:00 PM
Rich Rodichok
That's the one. Thanks again!
Old Dec 21, 2015 | 01:11 PM
welcome.
minihune
Hawaii
28
Jul 4, 2019 12:49 PM
phil_deez
Feb 6, 2017 08:49 AM
JamesDeBart
Apr 16, 2016 05:00 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
dangsteven
Oct 17, 2015 06:20 AM
