2005 mini cooper spark plug change
Old Jan 8, 2011 | 09:33 AM
terryb237's Avatar
terryb237
i am trying to change spark plugs and wires in my 2005 mini cooper. can anyone help me out. what size socket fits the plugs. are there any special instructions i should know before i start.
Old Jan 8, 2011 | 09:41 AM
Rich.Wolfson's Avatar
Rich.Wolfson
It is a 5/8 spark plug socket and if you use a regular one you will need a 6" extension. As for special instructions....
It is important to only change your plugs when the engine is COLD. As in overnight cold. And don't change them unless you have a torque wrench as they get torqued to 20 ft/lbs. I also put a dab of anti-seize on the plugs when I install them.
There have been numerous reports of ejected plugs and ruined heads because of improperly installed plugs. I check torque every 5000 miles each time I change the oil and have never had a problem.
As for what plugs are best, I will leave that to all the others with opinions on that.
Rich
Old Jan 8, 2011 | 10:00 AM
terryb237's Avatar
terryb237
thanks for your help.why do some say it takes a 14mm 12 hex socket.
Old Jan 8, 2011 | 05:26 PM
Rich.Wolfson
Don't know. I use a 5/8" 6 point extended length spark plug socket. But a regular length socket would work fine too.
Rich
Old Jan 9, 2011 | 01:32 PM
terryb237's Avatar
terryb237
thanks
Old Jan 9, 2011 | 02:08 PM
Vollgas's Avatar
Vollgas
You can also get a deep dwell socket that is made for spark plugs.
I recomend Brisk plugs myself.
Old Jan 9, 2011 | 06:17 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Make sure you torque them when they go back in a blown out plug is an expensive fix.
Old Jan 10, 2011 | 11:22 AM
terryb237's Avatar
terryb237
thanks for all your help guys. i just purchased a set of brisk silver plugs and a set of 10.2 mm performance wires and when they arrive will install them. wish me luck. they are located on top of engine should be a piece of cake. should i use a 16mm socket or a 5/8 socket.
Old Jan 12, 2011 | 11:36 AM
terryb237's Avatar
terryb237
msd coil
i just purchased a new msd coil. can anyone give me advice on how much gap should be on my brisk silver plugs on my r50 cooper,05 model.
Old Jan 13, 2011 | 06:31 AM
OVREZY's Avatar
OVREZY
16 mm and 5/8 are almost the same size -- the 5/8 works fine.
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Minii cooper bean
Aug 11, 2015 02:10 PM
jrezzo
Aug 9, 2015 10:32 PM
joelcseymour
Aug 7, 2015 12:43 PM
