Suspension NM Sway bar super Creaky! help!
Old 09-19-2016, 11:00 AM
atlantaorange's Avatar
atlantaorange
atlantaorange is offline
Specs:
NM lowering springs
NM 22mm Rear Sway bar with NM rubber bushings and factory mounts set on full stiff setting (first hole)
So... after installing my new NM springs and sway bar, i have a super loud creaking coming from the rear of the car. I went back to my shop yesterday, took everything back apart in the rear, used all of the grease that came with the sway bars and the creaking seems worse now.
The creaks is most prevalent on accel\decel, not when going over bumps or speed bumps.
I have been super happy with the ride of the springs and the handling improvement but the sways are really bugging me. Has anyone else had this problem? Did you use a different grease or wrap with teflon? i have aftermarket sway bars on 2 bmws (e30 and mroady) and have never had any noise from them.
thanks for the assist everyone, i did a search first and didn't see any threads on this. I sent an email to Jerry as NM also.
Tony
Old 09-19-2016, 11:08 AM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
Originally Posted by atlantaorange
Specs: NM lowering springs NM 22mm Rear Sway bar with NM rubber bushings and factory mounts set on full stiff setting (first hole) So... after installing my new NM springs and sway bar, i have a super loud creaking coming from the rear of the car. I went back to my shop yesterday, took everything back apart in the rear, used all of the grease that came with the sway bars and the creaking seems worse now. The creaks is most prevalent on accel\decel, not when going over bumps or speed bumps. I have been super happy with the ride of the springs and the handling improvement but the sways are really bugging me. Has anyone else had this problem? Did you use a different grease or wrap with teflon? i have aftermarket sway bars on 2 bmws (e30 and mroady) and have never had any noise from them. thanks for the assist everyone, i did a search first and didn't see any threads on this. I sent an email to Jerry as NM also. Tony
I think my NM sway came with grease, did yours.
mQubed Motorsport, Manic Tuning Dealer
Old 09-19-2016, 11:21 AM
atlantaorange
yep, a little squeze thing of white colored grease. used all of it evenly between the 2 rubber mounts and the swaybar.
made no difference...
did you also grease between the rubber bushing and the factory mount?
Old 09-19-2016, 12:52 PM
MarioKart's Avatar
MarioKart
Vendor
I put grease on collar and the bar. Also greased camber arms, if you have rnem
Old 09-19-2016, 02:30 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
I didn't have the problem on my R56. On my F56 I also bought the NM billet RSB brackets with the grease fittings to make it easier to service. Zero squeaks so far.
Old 09-19-2016, 06:46 PM
atlantaorange
did you use the upgraded end links as well? i wonder if the factory ones are part of the issue.
i am not looking to spend another $150 for the fancy RSB's if i dont have to.
Old 09-19-2016, 06:50 PM
vetsvette's Avatar
vetsvette
Moderator
Yep. NM end links and lower control arms too.
http://www.nm-eng.com/338/0/0/3290/n...ting-22mm.html
Old 09-19-2016, 07:11 PM
atlantaorange
that's right, i forget how setup your car is!
well i am not planning on going that far. if i cant get the creaking to go away, ill move back to the stock rear sway bar.
I have an appointment to have the car aligned tomorrow. i will have the shop take a look and move the endlinks to the softer spot.
Im going to give Jerry at NM a call tomorrow also.
Old 09-20-2016, 06:34 AM
honderpilot's Avatar
honderpilot
honderpilot is offline
Specs:
NM lowering springs
Tony
Call Jerry. He is terrible with emails and you will literally never receive a response (at least with my experience). He is also awesome over the phone and can usually propose a solution immediately.
Old 09-20-2016, 09:40 AM
vetsvette's Avatar
vetsvette
Moderator
^^^ +1 ^^^
Old 09-20-2016, 11:17 AM
atlantaorange
yep that was my experience as well. nothing against Jerry!
so. i think i know what is going on and im a dumb ***
while the car was being aligned today, we were under the car looking at the sway bar abd realized i have it installed upside down. it is hitting the underside of the car.
sooo, thanks everyone for the help, i am going to correct this tonight...
it honestly was not obvious from the instructions which way the bar goes, however i should have looked more closely once i bolted the sub-frame back up.
at least i am 90% sure how to fix this now.
Old 09-20-2016, 12:08 PM
honderpilot
Glad you got it figured out. nothing worse than not knowing the problem.
Old 09-20-2016, 03:11 PM
vetsvette's Avatar
vetsvette
Moderator
Old 09-20-2016, 04:35 PM
atlantaorange
finish the reinstall (#3!)
no more creaks etc.
whew
now i can enjoy!
oh and jerry got back to me on my emails! i let him know it was all my fault, he said i wasnt the first person to do that...
Old 09-26-2016, 01:03 PM
TheBigNewt's Avatar
TheBigNewt
TheBigNewt is offline
Yeah one time I replaced the seat in my car and couldn't figure out why I couldn't see the steering wheel or the windshield.
Old 09-26-2016, 04:53 PM
gjxj's Avatar
gjxj
gjxj is offline
maybe he should think of marking them better, just sayin..
Old 09-26-2016, 05:58 PM
vetsvette's Avatar
vetsvette
Moderator
They did. The bar has NM graphics on it. Install it so you can read it while standing under the car.
Old 09-26-2016, 06:50 PM
atlantaorange
didnt notice that
anyway, all good! car is at dealer now for the bearing recall... fingers x'd that it wont need a new motor.
Old 12-26-2016, 10:16 PM
Clutch Wotan's Avatar
Clutch Wotan
Clutch Wotan is offline
Works fine with the linkage set, made some noises during set, good mod !
Facebook Post
Lex2008
How to
11
09-07-2017 10:19 AM
eseel
09-01-2016 08:32 AM
jeff5150
08-26-2016 09:25 AM
sootyvrs
08-26-2016 05:35 AM
hntsmith
08-24-2016 07:17 PM
Quick Reply: Suspension NM Sway bar super Creaky! help!
