Help with Removing 2002 R50 Crank Pulley
Old 12-01-2015, 11:40 AM
MazMini's Avatar
MazMini
MazMini is offline
So Im in the middle of my build and Im stuck on removing this crank pulley. From what I read there are suppose to be holes?? I looked at the Pelican Tech articles and ModMini's Youtube Video but mine is totally different.. Am I suppose to just use a 3 Jaw Puller for this one? Any help would be appreciated. Also not sure on the condition of this pulley as well..
Old 12-01-2015, 12:25 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Shown in our article is the later (2004-on) style harmonic balancer that is a direct replacement for all years of MINI Cooper S. For your R50, it should look like this. Yes, use a 3 jaw puller.
888.280.7799 | 6am - 5pm PST
Old 12-01-2015, 02:30 PM
MazMini's Avatar
MazMini
MazMini is offline
[QUOTE=PelicanParts.com;4150080]Shown in our article is the later (2004-on) style harmonic balancer that is a direct replacement for all years of MINI Cooper S. For your R50, it should look like this. Yes, use a 3 jaw puller.
Awesome!!!!! I appreciate it !
Old 12-01-2015, 02:31 PM
PelicanParts.com
Vendor
[QUOTE=MazMini;4150147]
You're welcome. Let me know if you need anything and good luck.
Old 12-01-2015, 08:15 PM
MazMini's Avatar
MazMini
MazMini is offline
[QUOTE=PelicanParts.com;4150148]
Just a quick update.. The puller I bought tonight has the fatter ends.. I am going to have to look for one that is a little thinner..
Old 12-02-2015, 08:19 AM
PelicanParts.com
Vendor
[QUOTE=MazMini;4150242]
Some people have had to slightly modify the jaws by grinding them. Check out this thread here where the individual had to use a 3 jaw puller. Should have somewhat good information even though yours is a big different.
Old 12-02-2015, 08:42 AM
MazMini's Avatar
MazMini
MazMini is offline
[QUOTE=PelicanParts.com;4150345]
I bought a 2 Jaw puller with flat edges .. which i thought would work but THAT TOO Needs some modification to make it work and the pulley is starting to chip off the edges.. FRUSTRATION HAS SET IN!
Old 12-02-2015, 11:22 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Ouch , yep its has to be on it or use one similar to the Genuine MINI part puller which pulls / pushes from the center.
Old 12-03-2015, 02:41 PM
MazMini's Avatar
MazMini
MazMini is offline
Do you guys sell any?? At this point I give up.. I dont have a grinder or anything so Im just going to buy a tool that will not damage the pulley any further...
Old 12-03-2015, 02:43 PM
https://www.ecstuning.com/Search/Sit...h/83300493982/ 83300493982 genuine MINI part
or
https://www.ecstuning.com/Search/SiteSearch/ES1876770/
Old 12-03-2015, 05:53 PM
MazMini's Avatar
MazMini
MazMini is offline
Cool I decided to get a Angle Grinder and grind the edges down so hopefully i get it off this weekend.. I will let you know.
Old 05-22-2017, 02:18 PM
AlphaBob's Avatar
AlphaBob
AlphaBob is offline
I know this is an old thread, but isn't the puller supposed to attach on the ears of the center hub (the ears that are right next to the spokes)? I'm going to pull my harmonic balancer tomorrow, and plan to use those ears, not the outside of the Pulley.
Old 05-22-2017, 02:48 PM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
ST3ALTHPSYCH0 is offline
If you are going to pull from the rim, I'd recommend flipping the puller arms so that you can grip the inner edge of the rim rather than outside the belt channel. Just a thought (and I would even do that out near the spokes).
Old 05-23-2017, 06:13 AM
AoxoMoxoA's Avatar
AoxoMoxoA
AoxoMoxoA is offline
You are correct; attach the jaws of the puller inside the tabs alongside the spokes.
Old 06-08-2017, 07:05 PM
AlphaBob's Avatar
AlphaBob
AlphaBob is offline
Perfect! Thanks for the highlighted picture. I found the puller that fits exactly:
Rented this at the local auto parts store.
Fits like a glove! Sorry, didn't think about pictures until after the fact.
Old 02-13-2018, 02:26 PM
Pixnad's Avatar
Pixnad
Pixnad is offline
Installation of harmonic balancer on base 2002 r50
Does anyone have a procedure to install the harmonic balancer on a base 2002 r50(non supercharged) with an automatic transmission? I was able to remove the old one off using the 3 clawed Chrysler puller. The problem now is finding a pulley that fits. Ordered two different ones and they were too big. They were way to big fitting over the camshaft end. Anybody have and suggestions? Need to get this thing up and running. Do I need to go OEM?
Old 02-13-2018, 06:44 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Take your stock crank bolt to the hardware store and get a bolt about an inch longer. Then use it with some washers to pull it onto the crank. then add more of the washers and pull it on further until on all the way.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 08-26-2018, 11:07 AM
Tim Wilcox's Avatar
Tim Wilcox
Tim Wilcox is offline
Did you resolve this issue? I returned the first pulley I ordered because it slipped on with no effort and spun when I put the belt on.
z3ds
01-07-2016 09:06 AM
Wisconsincooper10
01-04-2016 02:51 AM
DRated
11-30-2015 11:07 PM
PelicanParts.com
11-30-2015 12:20 PM
MiniStarcher
11-29-2015 04:40 PM
Quick Reply: Help with Removing 2002 R50 Crank Pulley
