Electrical INPA & check engine light N16 engine.....
I am turning to the group for help. Well this may be lengthy so bear with me. I have a 2013 Mini cooper non s that I have been rebuilding and have a check engine light and Trifecta fault on the ABS. The ABS issue I think I have found and have the part ordered. The check engine light is constant and I have been trying to diagnose. After running some test in INPA I keep getting error codes DME/DDE 32D6 & EGS 5100/CF31. In addition when I try choose R56 (Shift F8) and then ENGINE, I do not see the N16 engine as a choice to choose from. So after much searching I have done the following and have it working. However I keep getting the German version and trying to get it to the English version. Here is what I have done.
Software I am running :
DIS v57 & TIS, SSS v32, INPA Ediabas 5.0.6, NCSExpert 4.0.1, Carsoft 6.1, NavCoder demo. (DIS and SSS are updated until 2010)
- 1 x interface K+D+CAN protocol
When I open INPA and go to the R56 engine menu my DME was not listed. The MED17 for the N14 engine was listed but not the MV1722 utilized on the N16 equipped vehicles so I added the following to the R56.ENG file under INPA/CFGDAT.
"ENTRY= MV1722,MEV17 for N16,"
The MV1722.ipo is in the SGDAT folder and the MV1722.prg file is located in the EDIABAS/ECU folder. So after the update the menu started working however it is in German
Trying to find ENTRY= MV1722,MEV17 for N16, in the [ROOT_R56_MOTOR] list in the INPA/CFGDAT file used to direct the softwareto R56.ENG (i.e. the file that INPA.INI uses to point to models using the R56.ENG) ? I have added this to INPA
[ROOT_4]
DESCRIPTION= 4 Zylinder
and I've modified R56.ENG as noted with
[ROOT_MOTOR]
DESCRIPTION=Engine
I am trying find what is causing the check engine light to stay on constant. I do have ista-d and ista-p and ready to go that route since my vehicle is newer. It looks like INPA/DIS is for vehicles 2010 or older. Do to harddrive space I can have one or the other
[ROOT_4]
[ROOT_MOTOR]
DESCRIPTION=Engine
Datens
Make sure you have the latest datens. In addition do a search in the forums if you need the files. Also there is another site called mhhauto.com that deal strictly with auto software. A lot of knowledge there. A lot of people have gone to ista p and ista d. That is how I went and got the Icom A2 hardware.
[ROOT_4]
[ROOT_MOTOR]
DESCRIPTION=Engine
[ROOT_4]
[ROOT_MOTOR]
DESCRIPTION=Engine
N16 engine
Yes I got it to work. However I could only get the german side to work. I think with a little more testing I could have got the english version going. While I was learning all this. I realized that This INPA version is for mini's older than what I have (2013). Since then I have upgraded to ista-p/ista-d with the ICOM A2 hardware.
I could never find the files in the datens (and they're current, but maybe not complete) that I have.. (The MV1722.ipo is in the SGDAT folder and the MV1722.prg file... )
Eventually I'll probably upgrade to ista-p/ista-d with the ICOM A2 hardware as well but I like the INPA tool and have had good luck with it using it.
Btw, thanks much for the fast response.
Hi there !
anyone can share the N16 R56 engine files?:
MV1722.ipo
MV1722.prg
It is my engine (N16) but I can't see it in the INPA screen, just:
DDE for PSA EV4
MEV17 for N12
MED17 for N14
I can see the "mv1722.prg" file under "\EDIABAS\Ecu\" but there is not the "MV1722.ipo" under "\INPA\SGDAT".
Thank you in advance !!!
MV1722.ipo
MV1722.prg
DDE for PSA EV4
MEV17 for N12
MED17 for N14
Hi there !
MV1722.ipo
MV1722.prg
DDE for PSA EV4
MEV17 for N12
MED17 for N14
MV1722.ipo
MV1722.prg
DDE for PSA EV4
MEV17 for N12
MED17 for N14
No DME updates on the car, just others in default mode (ie: when adding xenons, FRM was reset to default with the new VO).
I have not updated the datten files in +2 years but I still worked smoothly in the car with Rheingold, NCS, INPA, WinKFP and Tool32.
Installing new hardware (MFSW, Sport button, Replacing FRM, changing VINs) and changed general functional configurations (sound, lights, alerts, and more).
I'm happy at least until today
Are you or anyone else able to share those files?
Unfortunately, it's all in German. Doubt you're still posting on here but just in case, did you have any theories as to how to trigger English? Everything else in my INPA setup works in English.
Can you share your n18 configuration files?
I'm bumping a very old thread but adding the N18 listing (and the updated Datens) to my config, gives me a working engine option in INPA for my N18 Countryman.
Thx
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
