Drivetrain R56 Noisemaker Revealed!
Old Dec 30, 2009 | 01:30 PM
NAProf's Avatar
NAProf
I installed the NM Engr. cold side boost tube on SUnday and pulled all the "Noisemaker" tubing out. Have seen a bunch of speculation on NAM about just what the "Noisemaker" is, so I decided to find out. Picture 1 is the noisemaker by itself - the left side connects to the cold-side boost tube and the right side has a tube that runs through the plastic firewall and dumps into the cowl space.
I took a band saw and cut the end of the noisemake off. Picture 2 is what you get.
The right cap has a very stiff plastic bellows connected to it. The left side is just a cup. The right cap fits into some grooves and looks to have been attached with epoxy. Just to see how stiff the bellows is I put 60 lbs of weight (equiv. to about 10 psi boost) on it and it didn't move. That makes me think it is acting as just a vibrating membrane (read ear drum) that amplifies the sound of the blowoff which is occuring just upstream. The is no bleed or blowoff through this "noisemaker, so for sure it doesn't hurt anything to get rid of it. Can't say that I missed any noise as my DDM intake and Alta Catback provide plenty of aural stimulation.
Cheers,
Greg
Old Dec 30, 2009 | 03:22 PM
countryboyshane's Avatar
countryboyshane
Interesting. A great piece of useless crap added to the engine bay by BMW!
Old Dec 30, 2009 | 05:47 PM
mellowmcs's Avatar
mellowmcs
it's more of a fine tuning device... not in terms of performance but sound.
Early in the development process, BMW began to research what customers prefer as a sporty sound from the car’s engine. Once again a roadster presents unique challenges to the engineers because the acoustics are much different whether the top is up or down.
The process began in the sound lab with people listening to different sound samples. These samples were engine noises but they had been synthetically created on the computer. The goal was to find the ideal roadster sound. This sound shouldn’t be so loud as to disturb one’s neighbors but it should be louder than a luxury sedan. The sound must be “solid” and correspond to what is expected from a BMW. These aspects were all combined and a sound target was designed. This sound target, which is stored as a computer file, was specified in terms of tone and decibel levels. But it also was somewhat subjective.
On the real car, the sources that contribute to the sound the driver and passenger hear include the engine itself, the air intake and the exhaust. The engine noise is very mechanical sounding and while, for example, a Ferrari’s sound is indeed very mechanical; BMW feels that their cars should be more refined.
For the 3.0-liter model only, a special “sound generator” was developed. “Sound generator” is a misnomer; “selective sound
filter” would be more accurate. In any case, the sound of the engine is managed in a very specific manner. The sound generator brings the sound back to the firewall to make it more apparent to the driver and passenger. In addition, this system filters out some of the naturally occurring sounds and selects others. The sounds that are selected for are those associated with a performance roadster. The result is a sound, especially upon acceleration, similar to a big V8 engine. Not only is the sound pleasing but it also provides feedback to the driver; the power is heard as well as felt.
In the BMW acoustic labs, the various components can be tested independently. On all three models, 2.2, 2.5 and 3.0 liter, the various sounds are graphed over the whole engine range. The characteristics can be mixed and tuned to complement one another. The process is almost like a musician mixing a recording. Testing is then done in an acoustic chamber with a rolling road. Final testing is, of course, done on actual roads.
Old Dec 30, 2009 | 08:23 PM
dunphyj's Avatar
dunphyj
nice to see! thanx for throwing this out there for us NAProf! +1
Old Jan 2, 2010 | 05:25 AM
Gilboyto's Avatar
Gilboyto
I know you said that you put weight on it and it didn't budge. Do you think this unit works more off of vacuum and pulls the plug towards the bottom of the noisemaker rather than away from it?
Old Jan 2, 2010 | 05:51 AM
NAProf's Avatar
NAProf
No Moving Parts
Gilboyto,
I was surprised to find there were no "moving" parts in this thing. I believe it simply acts like a speaker. The end of the bellows deflects slightly when the pressure changes on the turbo side. The bellows acts as a chamber that turns this change in pressure to sound (a la a speaker cone) and it goes out the tube to the cowl area. I really don't see this thing doing anything as sophisticated as described in mellowmcs's quote.
Cheers & Happy New Year,
Greg
Old Jan 2, 2010 | 05:59 AM
Gilboyto's Avatar
Gilboyto
Interesting! Thanks for the reply.
I have been looking at removing this as it seems my noisemaker is much louder than even the stock DV. Mine has an annoying "whistle" sound when I let off the throttle...hardly intimidating lol
Old Jan 2, 2010 | 09:19 PM
dunphyj's Avatar
dunphyj
yeah... it's not connected to a vacuum source... just to the bulkhead, basically a gigantic box :P
Old Jan 4, 2010 | 02:06 PM
Ladybug-S's Avatar
Ladybug-S
And the noisemaker delete kit does make a difference to cabin noise. Small but noticeable, even with the Alta CAI.
Old Jan 5, 2010 | 02:02 PM
OTB's Avatar
OTB
What the hell is wrong with cars nowadays?
How many of you would have preferred a M______ F______ water temperature gauge over this worthless pile of dog dookie?
It seems like every car made nowadays has 200 lbs of worthless crap that needs to be tossed in the trash. You can't even buy a pickup truck nowadays without automatic ball sack warmers and seven cup holders.
....ok had to vent a little
Old Mar 3, 2010 | 12:30 PM
TheMadDane's Avatar
TheMadDane
$1.00 Noisemaker Delete!
This is what I used to plug the hole in the noisemaker opening, 1" PVC cap, it slides in very snug if you put the open end pointed out.
$1 at Home Depot and a decent helping of GOOP Automotive Sealant. Been on for 6 months and I checked it yesterday, its solid as a rock and not going anywhere.
http://www.amazon.com/Charlotte-Pvc-.../dp/B000R9DZ42
Old Mar 14, 2010 | 07:46 PM
tominizer's Avatar
tominizer
I've heard speculation that this removal (mod) adds at least 10% better performance due to the weight reduction and better balances the vehicle to a more neutral 50/50 weight distribution left to right ..................... !!
Old Mar 14, 2010 | 11:41 PM
dunphyj's Avatar
dunphyj
HA! :P
Old Mar 15, 2010 | 07:41 AM
Porthos's Avatar
Porthos
Just wondering what it sounds like without the noise thingamabob? I know that there is a blowoff down toward the turbo or somewhere on the intake stream of things and does it make any noise?
Old Mar 15, 2010 | 10:46 AM
TheMadDane's Avatar
TheMadDane
It makes the car more quiet. I have a CAI and I like the sound of the turbo Blow off. Tha car still makes enough noise with acceleration, but now I can hear my music at all levels clearly.
Old Jun 25, 2010 | 12:20 PM
Maelvampyre's Avatar
Maelvampyre
Dane
I don't understand what you mean by "plug the hole in the noisemaker opening"
You put the PVC cap in a piece of cutoff hose attached to the object picture above by NAProf, the cold side boost tube, or where?
Old Jun 25, 2010 | 04:53 PM
tvrgeek's Avatar
tvrgeek
"a Ferrari’s sound is indeed very mechanical;" Very polite way to say it sounds like five 61 VW bugs at 3500 RPM redline. No thanks.
I am not into noise. Looks like I should pick up a pipe cap. If I want more engine noise, I will delete another useless part, the intake muffler.
Old Jun 26, 2010 | 06:44 AM
clnconcpts's Avatar
clnconcpts
where is this wonderful piece of equipment installed?
Old Jul 31, 2010 | 11:57 AM
NAProf's Avatar
NAProf
Noisemaker Location
clnconcepts:
On the R56S the noisemake is behind and under the stock airbox mounted on the plastic bulkhead. There is a tube going from the left side to the cold-side boost tube just before the boost tube connects to the throttle body. It is part #13 in the diagram below (thanks RealOEM).
The part on the right side (#16) just plugs into a hole in the bulkhead.
Cheers,
Greg
Old Jul 31, 2010 | 12:34 PM
tvrgeek's Avatar
tvrgeek
Thanks for the picture. Would you happen to have access, or know where I could gain access to the wiring diagrams? A service manual? I guess Bentley will publish it eventually, but I would like to have one sooner than later.
Old Jul 31, 2010 | 01:40 PM
NAProf's Avatar
NAProf
tvrgeek,
I bought a TIS DVD on E-Bay for like $5. It has BMW's whole line through Spring of 2008. But it is not as good as the DIY threads on NAM in most cases. The TIS also doesn't have wiring diagrams.
Where in Maryland are you? If you have a one time need I could maybe meet you somewhere and let you borrow the DVD.
Cheers,
Greg
PS - The diagram I posted is from Real OEM. If you are just looking to see how things are put together you can get a lot of info from that (and part numbers/prices).
Old Aug 6, 2010 | 06:20 AM
konijay's Avatar
konijay
I did this mod last night and i say NVH level has gone down by maybe 10-15%...
engine feels more refined = less boomy
less vibration = feels tighter
I feel like i got a new car...
Old Aug 6, 2010 | 09:08 PM
clnconcpts's Avatar
clnconcpts
What is silly part number 3?
Old Aug 7, 2010 | 12:47 AM
czar's Avatar
czar
Part No 3 is a screw, you mean, what is No 9 ?
No 9 is the intake resonator/restrictor (muffler) Commonly replaced by, what is known as, the resonator delete hose.
Old Aug 7, 2010 | 06:47 AM
NAProf's Avatar
NAProf
As Czar says, it is a muffler in the hot-side charge pipe. The wastegate for the turbo is just upsteam so I expect this is to baffle some of that noise.
Alta, NM, Forge and several others make replacement hot-side charge pipes that delete this muffler.
It is interesting to note that MINI calls the stock air box and air filter the "intake muffler". I expect for the same reason - to hide some of the blow off noise.
Cheers,
Greg
