Drivetrain R56 Noisemaker Revealed!
Old Aug 7, 2010 | 02:57 PM
  #26
///Mflossin's Avatar
///Mflossin
"intake muffler" is nomenclature that is found on old, naturally aspirated BMW's as well...really doesn't talk to the fact that this thing muffles noise in any way. I have found BMW part nomenclature to really be all over the place for the most part...a lot of times it makes perfect sense and other times I scratch my head.
Old Aug 9, 2010 | 11:36 PM
  #27
Rixter's Avatar
Rixter
So when you get rid of this useless component are you left with a hole where items #16 & #17 insert into the car (firewall)? Does that need to be plugged?
Old Aug 10, 2010 | 12:19 AM
  #28
TheMadDane's Avatar
TheMadDane
As far as I can remember no, it just mounts flush to the firewall no hole.
Old Aug 10, 2010 | 05:51 AM
  #29
konijay's Avatar
konijay
i plugged up the noisemaker then disconnected #16 then stuffed up some paper up the hole on firewall...made the car really quiet...
Old Aug 10, 2010 | 11:08 AM
  #30
Rixter's Avatar
Rixter
Paper?
Well maybe a bit of insulation is called for. So there is a bit of a hole unless you do something about it?
Old Aug 10, 2010 | 11:13 AM
  #31
Rixter's Avatar
Rixter
Originally Posted by NAProf
I thought that if you went with something like the NME product (http://www.nm-eng.com/488855.html) that everything from #11 to #17 comes out?
Old Aug 10, 2010 | 12:19 PM
  #32
konijay's Avatar
konijay
Paper?
it's about 1.5 inch x 3.5 inch square hole...u can just stuff some paper up that hole..u will know what i mean when u take #16 off and feel it
I tried to leave everything looking stock as possible just in case...so i just removed #16...this mod didn't cost me one penny...
Old Aug 11, 2010 | 09:29 AM
  #33
Bigprfed22's Avatar
Bigprfed22
Intake muffler is an old old wooden ship , used in the civil war era...
Old Aug 11, 2010 | 09:52 AM
  #34
Rixter's Avatar
Rixter
Big-22 did you notice any PSI boost with the NME mod? The airflow should be better.
Old Aug 11, 2010 | 10:02 AM
  #35
Bigprfed22's Avatar
Bigprfed22
I have both pipes, i will say that after the gauge install now i know when i over boost. I have a 2010 and during normal boost i see maybe a .5 lbs almost a lbs. During over boost i see 1 lbs -2lbs maybe a little more than usual, dependant on load also. definitely changed the boost curve around as the spool characteristics changed.
Old Aug 14, 2010 | 08:18 PM
  #36
moose2578's Avatar
moose2578
does anyone know about the muffler delete pipe for the intercooler and does it do nething>
Old Aug 16, 2010 | 06:18 AM
  #37
Bigprfed22's Avatar
Bigprfed22
i noticed quicker spool after i did the hot pipe, an increase in boost came with the cold pipe... i did them both but around 2 weeks apart.
Old Aug 17, 2010 | 02:21 AM
  #38
czar's Avatar
czar
The over boost function gives an additional 150Mbar (2.17 PSI) over stock, for no longer than approximately 12 seconds.
Old Aug 17, 2010 | 06:25 AM
  #39
Bigprfed22's Avatar
Bigprfed22
Before my rmw tune (last night) as long as i would mash the throttle i would get it in every gear if i started in a low enough revolution range. After i did the hot pipe gauge wise there was an increase on top of the factory overboost.
But now RMW runs the show and boy is it entertaining
Old Aug 17, 2010 | 07:07 AM
  #40
BamaCooperS's Avatar
BamaCooperS
Noisemaker Exit Pipe Diameter?
Does anyone know the outside diameter of the tube where the noisemaker piping exits the main piping (the OD where item 10 attaches or the ID of item 10)?
Old Aug 17, 2010 | 07:10 AM
  #41
Bigprfed22's Avatar
Bigprfed22
if your looking for a plug i think folks on here have used 1 inch, dont quote me on that though.
Old Aug 17, 2010 | 07:45 AM
  #42
BamaCooperS
Actually I'm looking for the OD. I want to try and find a silicone/EDPM cap that I can slide over the noisemaker outlet from the main pipe and then secure with a hose clamp. If the ID is around 1", maybe the OD is around 1-1/4 or so. I would like to find the actual size so that I can get a plug with a real snug fit, then add the clamp. Thanks.
Old Aug 17, 2010 | 07:58 AM
  #43
Bigprfed22's Avatar
Bigprfed22
no idea as im at work but when i get home i will measure for you sir.
Old Aug 17, 2010 | 08:38 AM
  #44
Minibeagle's Avatar
Minibeagle
Originally Posted by tominizer
I've heard speculation that this removal (mod) adds at least 10% better performance due to the weight reduction and better balances the vehicle to a more neutral 50/50 weight distribution left to right ..................... !!
Forget that. I drive naked to save about 3 lbs of weight. Car is way more responsive that way.
Old Aug 17, 2010 | 08:49 AM
  #45
BamaCooperS
Thanks Bigprfed22. I would appreciate it.
Old Aug 17, 2010 | 09:03 AM
  #46
Bigprfed22's Avatar
Bigprfed22
Old Aug 17, 2010 | 09:16 AM
  #47
Rixter's Avatar
Rixter
That's dedication to performance I could suggest a way of saving another pound if you'd like
Old Aug 17, 2010 | 09:25 AM
  #48
Bigprfed22's Avatar
Bigprfed22
is that why im slower after lunch!?
Old Aug 17, 2010 | 09:33 AM
  #49
Rixter's Avatar
Rixter
I'm not saying a thing
Old Aug 17, 2010 | 10:59 AM
  #50
Minibeagle's Avatar
Minibeagle
I don't need a horn either *TOOT TOOT*
