Info on off sets
Old Feb 7, 2007 | 05:00 PM
pauliekeys's Avatar
pauliekeys
Info on off sets
I'm looking at getting some 16" Rota's but I want to know if I'm going to run into rubbing issues with a 40mm off set. I'm using H-sport springs and plain on getting a 205-50-16 tire. I hope there are some of you that have this set up and can give me real world knowledge. I don't want to trim and I'm running on 215/35/18 right now with no rubbing at all. Thanks for any help you can give.
Old Feb 7, 2007 | 09:35 PM
pauliekeys's Avatar
pauliekeys
Anyone ? Buler ? Need to know before I pull the triger.
Old Feb 8, 2007 | 05:43 AM
meb's Avatar
meb
I'll jump in since none else has...yet.
By way of comparison, I have 17" BBS with 38mm offset with 205/45/17 with zero rubbing at about 1" lower than stock ride height. The H-Sports are soft, especially up front...I also use a 5mm spacer up front making the offset 33mm. But the rear may become a problem before the front.
Now, a 38mm with a 5mm pacer works on the rear with a 205/40/17 - the above is a 45 aspect ratio.
Hpefully this helps.
Old Feb 8, 2007 | 08:27 AM
pauliekeys's Avatar
pauliekeys
Thanks for the response ! I'll take all the help I can get. I hope some people with 16" rims with the 40mm off set join in because that is what I'm looking at and I hope to learn from what they have found. 16" 205/50/16 or 215/45/16 with 40mm out there ? Before my 18's, I had for a VERY short time a set of 17's with 215/45/17's and they rubbed a little in the rear. Why the spacers ?
Old Feb 8, 2007 | 10:18 AM
meb's Avatar
meb
Long story...and many threads here about these. Glad to answer your question, but perhaps in a PM?
Michael
Old Feb 8, 2007 | 10:22 AM
pauliekeys's Avatar
pauliekeys
Please give me any info on the matter. I'll wait for your response. Thanks, paulie C.
Michael
Old Feb 8, 2007 | 10:23 AM
pauliekeys's Avatar
pauliekeys
Any info would be very helpfull. I'll look for your PM. Thanks !
Michael
Old Feb 8, 2007 | 01:19 PM
stevecars60's Avatar
stevecars60
If you are looking at Rota 16" D2s with a 40 - they will not fit over the front calipers. The 17"s will fit. As far as rubbing w/ 1 1/2" drop the 40 should fit but I can't be 100% sure but judging what you have now - shoulden't be a problem.
Old Feb 8, 2007 | 03:48 PM
pauliekeys's Avatar
pauliekeys
Thanks, they're not D2s. I've seen and talked to a member that has the Rotas that I'm looking at and they fit his and after market brakes as well. I think what really comes into play now is what brand of tire I choose. Some brands have a very boxy design; others a more rounded shoulder. What I'm gathering from other post is that a 40mm off set will be fine with a 205/50/16 or a 215/45/16.
Old Feb 9, 2007 | 03:56 AM
stevecars60
With some tires you can go to a 38. It's strange, with the D2s Wilwoods fit perfectly ( the casting on the OE caliper is just a little big )
While researching the tires. there are some 205/50 that are just as wide as 215/45 if you are looking for width. Try to stay around 24.5 for diameter so the speedometer isn't too screwed up.
Old Feb 9, 2007 | 08:21 AM
pauliekeys's Avatar
pauliekeys
By any chance could you tell me what brands are the same width as a 215/45 ? That would be very helpfull. Thanks !
Old Feb 9, 2007 | 09:54 AM
stevecars60
If you had asked a couple of weeks ago ..... the research has gone to the dump
Besides a a Mini S, we have a Scion XB. The first choice was a 225/40 which is a big tire for a 16 x 7" rim, it will work. The way to figure the tire is look at the diameter first, every manufacturer has something different. Width varies quite a bit. The XB ended up with Hankook 205/50 K106s the least expensive high performance tire you can buy ( they are much, much, better than expected, wet, dry & snow ). These tires, real footprint, are 3/4" wider than the Falcon 215/40 17s on the Mini.
I wish I had more info for you....... What I did was look at "D", find the widest tire that would fit on a 7" rim, then compare. Wide does not mean best but it will give you a baseline to fit the rim. There are a ton of good tires for a 16" rim.
madmax88
Oct 26, 2015 01:45 PM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
AZN Optics
Aug 16, 2015 11:52 PM
minipopkart
Aug 13, 2015 05:22 AM
