Getting rid of run-flats
Old Jan 25, 2007 | 12:48 PM
vector625's Avatar
vector625
I'd love to get rid of my Pirelli run-flats because they keep going flat (all the time). I'm not even sure where to start for replacements, but I wanted to know what everyone does for spare tires if they switch.
I've actually had 2 "real" flat tires in the past 3 years. It's great to be able to not have to worry about the flat immediately. I've changed tires many times, so it would just be a matter of figuring out where to put a spare.
What do all of you non-run-flatters do for spares? Where do you put them? Or do you just drive locally?
Old Jan 25, 2007 | 01:01 PM
cube17576's Avatar
cube17576
Coordinator :: STLMini
Get a can of Fix-a-flat and a portable air compresor. For long distance trips I know some people will put a full size wheel and tire in the boot.
Old Jan 25, 2007 | 01:08 PM
camminich's Avatar
camminich
I 2nd that. For less than $40 you can have a great little spare kit that will fit quite cozie in the boot. I drove over 2000miles on MTTS with no spare, just my kit.
You will notice such an improvement in ride, and lack of road noise too when you move away from your RFs.
Old Jan 25, 2007 | 01:20 PM
limestonedan's Avatar
limestonedan
I went through this myself when I bought my new '06 last summer. It was complicating as I have a MCSCa which does not have room for a spare tire. If I bought non-run flat tires I'd need either a spare "donut" tire (did not fit in the trunk) or the other option would be some sort of emergency roadside tire repare/inflate system.
I researched tires through TireRack and read the reviews of Mini owners with similar driving styles. I ended up purchasing Avon Tech M550 A/S 215x45x17's and had TireRack ship them directly to my dealer for installation B4 I picked the car up new at the dealership. I sold the brand new run-flats back to the dealer. I also purchased the "Continental Tire ContiComfortKit" through TireRack for $79.00 which I leave in my trunk.
So far, for me, I really like the Avon's. They were not expensive. Thankfully, I have not used the ContiComfortkit yet..
Hope this helps. Good luck!
Limestonedan
Old Jan 25, 2007 | 03:37 PM
Febmoon1's Avatar
Febmoon1
Avon's are nice, I bought them in place of my runflats and bought an air compressor and slime stuff for flats in a kit for $20 at AutoZone. I also bought a 5th tire I keep in my garage in case I do get a flat that can't be fixed. Most tire places don't stock the 215-45-17 as a normal item.
Old Jan 25, 2007 | 03:41 PM
jonnieoh's Avatar
jonnieoh
I just picked up a small kit at Advance Auto Parts, which has a small air compressor, and a bottle of slime. It cost $19.98.
Here's the link: http://www.partsamerica.com/ProductD...number=SSPDQ06
Old Jan 25, 2007 | 05:11 PM
Nay's Mini's Avatar
Nay's Mini
Cool - I'm getting rid of my run flats soon. And looking at getting Tenzo Overdose wheels - 215-45-17 Great to hear that there is a solution to keep in the car!
Old Jan 26, 2007 | 05:15 AM
WannaMini_'s Avatar
WannaMini_
I had actually read from a few NAM members that a cell phone and a little time on your hands is the best option. That the fix-a-flats and slimes of the world could actually damage your wheels. But I could be wrong. Someone please correct me if I am misinformed.
Are you getting new wheels, too? Tirerack is a great resource as is this board. I started with - did I want summer and winter tires with two sets of wheels, or did I want all-seasons? Then I established my budget. Then I just started doing a bunch of window shopping!
Old Jan 26, 2007 | 07:12 AM
limestonedan
What I've read/heard, the ConticomfortKit is not supposed to damage the tires like other tire repair sealants on the market. I have not personally used it yet so I don't know..
Old Jan 26, 2007 | 12:53 PM
C4's Avatar
C4
I think that the biggest risk about switching from runflats to radials is the possibility of a complete tire blowout, in which case your trusty can of tire GOO will not do you any good
I will stick with RFs for this very reason. Also, boot space is very precious for me to take it up with a small spacesaver spare tire. I am not saying that going "radial"is a bad idea, just that it implies taking some risks if the worse were to happen.
Old Jan 26, 2007 | 12:54 PM
C4's Avatar
C4
I think the tire GOO can damage the tire pressure sensors, or so I read in the can of "Fix-A-Flat".
Old Jan 26, 2007 | 05:12 PM
zenism's Avatar
zenism
I thought MINIs didn't use in tire pressure sensors, but measured tire rotation speed. If you figure the tire diameter becomes smaller as a tire loses air, and that a tire with a smaller diameter spins faster at a given speed, then you can use the ABS system sensors to guess when a tire is running low air. That's my noob's take on the operational description within the owner's manual.
Motor on...
Old Jan 26, 2007 | 08:12 PM
Sparky's Avatar
Sparky
Get rid of the runflats ASAP. Get a better performing, better riding (even if you go to a 215/40-17), wider tire for half the price. I bought the Ultrik mobility kit from Mini Mania which includes a compressor, tire sealant and a cool case that fits perfectly in the boots' side cubby so it doesn't fly around with all the added grip you'll have. Tire-Rack and, surprisingly, Discount Tire are good places to check out. Good Luck
Old Feb 2, 2007 | 01:34 AM
supercharged_01's Avatar
supercharged_01
Anyone Tried Toyo T1R's ?? i have had enough of Run Flats
CooperSharp
Oct 12, 2015 09:21 AM
Qik420
Oct 4, 2015 08:19 PM
Oct 1, 2015 12:13 PM
nshannon29
Sep 30, 2015 05:21 PM
aldito2
Sep 30, 2015 10:44 AM
