I just swapped off my winter tires this morning for my OEM runflats. I cannot get the warning light to go out even though I measure 35 lbs in each tire. Any thoughts?
Right now mine is flashing on and off. My rear passenger-side has a nail in it and is almost bald. Going after work this afternoon to get a couple of new tires. Hopefully that'll stop the blinking.
Turn the ignition on and hold it down until it stops blinking
From the user's manual:
1. Before a journey, start the engine, but do
not start driving
2. Press the button long enough for the
indicator lamp in the display elements
to light up for a few seconds
3. Drive off.
It takes a few minutes before the Flat Tire
Monitor can detect a flat tire and issue an
alert.
If I get aftermarket wheels and tires on my 06, is this alarm always going to be on??
Nope. I've got aftermarket wheels and tires and it doesn't stay on. I think the system works by detecting difference in the speed of the tires caused by lower pressure in a tire. Even if you go to non-runflats, it will still pick up a flat before it goes completely flat.
After I repaired a tire, the light stayed on even though I did what the manual said. I had to do the reset as indicated by the manual but drive for a while for the light to go out.
