Braking Question
Old Dec 18, 2005 | 10:50 PM
Battle Cattle's Avatar
Battle Cattle
Braking Question
I have started to notice as I brake (mostly after it has rained and roads are drying out) that just before I stop I hear my brakes squeak (doesnt bother me) but its not constant... I keep steady pressure and you hear squeak, then pause (without any braking, like brakepads arent touching) then a squeak again... repeat process until I stop...
any ideas?
-Josh
05 MCS with 10,500miles
Old Dec 19, 2005 | 04:56 AM
Dolmangar's Avatar
Dolmangar
I have the same noise. I've seen a few threads on it, seems like a common problem. Something to do with the OEM brake pads. As long as you check to make sure that you haven't warn down your pads, it shouldn't really be a problem.
You can change pads to eliminate the noise (I'm sure others will have some suggestions on which pads to choose).
Old Dec 19, 2005 | 06:46 AM
TampaMCS's Avatar
TampaMCS
Mine does this too, its annoying as hell!
Old Dec 20, 2005 | 11:09 AM
Battle Cattle
glad I am not alone...
Old Dec 20, 2005 | 11:17 AM
goaljnky's Avatar
goaljnky
I got that too. But have to be on a quite street to hear it. Almost sounds like the brakes are locking up for a split second right before stopping.
Old Dec 20, 2005 | 11:28 AM
pooch1's Avatar
pooch1
Pads are glazed,if you want to pull off and rough up pad to remove glaze,it should stop the squeak.Personally I just change pads with the next service,its not worth taking them out to service without replacing.
Old Dec 20, 2005 | 06:48 PM
kenchan's Avatar
kenchan
brake hard from 40mph 2-3 times and it should remove that glaze.
goaljnky- in your case, you might just need new pads.
Old Dec 20, 2005 | 07:01 PM
Byron's Avatar
Byron
Brakes
I had same problem,EBC greenstuff pads solved the problem.
Old Dec 20, 2005 | 11:29 PM
Snappychip's Avatar
Snappychip
hey yeah i got that problem too at 9500 miles. i think i will try the 40-0 test a few times to scuff them up
Old Dec 21, 2005 | 04:36 AM
pooch1's Avatar
pooch1
Any pad change will stop the problem
Old Dec 21, 2005 | 04:59 AM
boognish's Avatar
boognish
I have that noise, too... I don't think of it as a problem though.. the brakes/pads are fine (no mechanical issues)... it's just noise... live with it until your first brake pad change, then choose a non-OEM pad and your noise will most likely go away...
Hey while we are on the subject of brakes... my 03 with 40,000 miles is on its original set of OEM pads. I have a few, maybe 4 mm of pad left (I think they start out with 13 mm?) on each.
I also noticed that the pads have worn away some of the rotor, because there is a slight "lip" formed on the outermost edge of each rotor where the pads do not touch it, therefore they haven't worn away any of the rotor surface. When I replace the pads (probably around 50K at this rate...I'm a "light footed" braker, I guess), should I also put on a new set of rotors all around?
Rock on,
boognish
Old Dec 21, 2005 | 05:43 AM
pooch1's Avatar
pooch1
Thats what Mini recommend.Also the lip will cause a noise eventually.There is a minimum thickness stamped on rotor you should measure with cliper to make sure it is not under.When they get thin they start to warp causing a slight shudder on breaking.
Old Dec 21, 2005 | 08:19 AM
goaljnky's Avatar
goaljnky
Rock on,
boognish
Wow, I got that much left (4mm) and I only got 15k on my car.
Old Dec 21, 2005 | 12:44 PM
pooch1's Avatar
pooch1
Highway mis very easy on brakes.
Old Dec 22, 2005 | 10:04 AM
Duane's Avatar
Duane
Brake Noise
The cheap and easy possible solution would be to re-bed in the pads. A procedure can be found here:
http://www.stoptech.com/tech_info/wp...contents.shtml
Other solutions include a set of pads that are known for the low noise. But I will warn you brakes are always a compromise and so in order to gain low noise, more often then not you have to give up some performance.
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
