Info on tire sizes for "S" lites
Old Dec 9, 2005 | 05:50 PM
MiniMeg06's Avatar
MiniMeg06
My wife and I ordered a 06 MCS with "S" lites and am thinking about up sizing the tire. How big of a tire can I install w/o rubbing. 225/45-17s? I will NOT be lowering the car. I have seen way too many wheels w/ curb rash on the 205/45-17s! My BETTER half may rub a curb or two. (i.e. help proteck the black powder coated wheels!) White with black roof, mirrors & stripes. NO thanks to 16" or 18" wheels
Thanks for your time,
Randy & Meg
Old Dec 9, 2005 | 07:05 PM
AldoS's Avatar
AldoS
215/45-17 works, no problem. It looks like I could fit 225/45
on my S-Lites (with Kumho Ecsta 712's) but haven't tried.
224/45 would be pretty tall.
Old Dec 10, 2005 | 07:20 AM
kenchan's Avatar
kenchan
i think Nitto's make NT555's in the 225/40/17 size...but not sure if id
recommend that size nor the product.
Old Dec 11, 2005 | 12:42 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Randy & Meg
Larger tires will not prevent curb rash, only being careful of staying clear of curbs will help keep your rims safe.
Stock sized 205/45-17 tires are fine. Some rims are more prone to scraping if you are not careful but any rim can be damaged if you park too close or if you jump a curb.
Larger sized tires could help minimally- 215/45-17 is safe for no rubbing with stock suspension. 225/45-17 could rub but that would be much more likely with any lowered MINI or with certain aftermarket rims. You can check with alex@tirerack.com for fitment issues using a stock MINI (rims and suspension). 215/45-17 offers a large selection of tires to choose from.
Old Dec 22, 2005 | 05:25 AM
Mini Black Dragon's Avatar
Mini Black Dragon
Have not seen a copy of MC2magazine in Canada yet. Book stores and MINI dealers still waiting also. I'm curious what their article on wheel&tire choices were for the MINI??? Run flat recommendations? Non-RF's? Winter tires?
Can anyone help out with their review & recommendations? Thanks [IMG]images/smilies/smile.gif[/IMG]
Old Dec 22, 2005 | 06:22 AM
Tit's Avatar
Tit
I'm running 215/40/ZR17 Toyo Proxes T1-R. They have a 'rim protector' lip on the part of the tyre wall closest to the wheel....I have curbed one wheel bouncing off a tall gutter trying to avoid a car coming into my lane - but that was quite a big one.....even took a 3 inch long chunk out of the tyre (ironically, the 'rim protector' part....).
The tyres have been great...I'd reccomend them! They are slightly noisy, but have a good ride quality and they grip like 'ell in both wet and dry..... They are a pretty soft compound, but I've gotten 25000km and a track day out of them so far, and I reckon I have a few thousand left in them yet...
Old Dec 22, 2005 | 07:21 AM
kapps's Avatar
kapps
Are there any of you actually running 225/45's or 225/40's? Try to put your finger between the front strut and the wheel . There's no clearance even on my 205's. I did some calculations using Yoko ES 100's as my base. If you went with 215's, the section width increases only .3" which is neglegable but 225's increase .6" which means it will bulge out an extra .3" on each side of the wheel. I'm not sure it will fit at all w/o any spacers.
Old Dec 22, 2005 | 07:25 AM
Wagnbat's Avatar
Wagnbat
My wife and I ordered a 06 MCS with "S" lites and am thinking about up sizing the tire. How big of a tire can I install w/o rubbing. 225/45-17s? Randy & Meg
http://1010tires.com/TireSizeCalculator.asp
Stock tire size is 205/45/R17x7
Width, thickness, rim size.
You can change your sizes using the above calculator, and find out the difference % wise the change is... And the calculator will show the info in an easy to read format. I believe I read any change less than 3% different is good, otherwise you'll have to take the car to the dealer to recalibrate the speedo.
Old Jan 12, 2006 | 11:33 AM
n3nyongmini's Avatar
n3nyongmini
OK to follow up...
curbing aside, what IS the largest tire on can fit on s-lites with stock suspension?
215/40/17?
225/40/17?
225/45/17?
I am interetsed in both width and diameter. I know I know about throwing speedometer off - I no so concerend about that. I am concerned and wanting, however, to increase the contact patch...
Derek
Old Jan 12, 2006 | 11:48 AM
ScuderiaMini's Avatar
ScuderiaMini
Derek,
I am sporting 215/40/17 BFG g-force Sports on s-lites for now, and i am absolutely happy with the combo. it looks muscular, handles good. I did not put on 215/45/17s, for two reasons: 1. i have lowering springs 2. would not look right.
so, is 225/45/17 doable? yes, and i strongly beleive it will rub like a ****
Old Jan 12, 2006 | 02:07 PM
Stevie B's Avatar
Stevie B
I hear that. San Antonio has the greasiest roads I've ever driven on.
Old Jan 13, 2006 | 07:51 PM
n3nyongmini
must be all the enchiladas...
So - 215/40/17 is a common upgrade...
anybody going to 215/45/17 w/o rolling, cutting or rubbing?
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
