Dan, question about 18" ASA J5s and lowering springs
Old Jan 30, 2003 | 10:13 PM
notpaddyhopkirk's Avatar
notpaddyhopkirk
Dan,
I bought a set of 18" x 7.5" ASA JS5s with Yoko Prada Spec2 215/35 18s from the Tire Rack. I love them... The next step (in my plan) is to install the H&R Sport Srping set that you folks carry. My question is: With the wheels and tires that I already have, will I experience any rubbing or clearence issues?
Thanks for the help, I have been singing the Tire Racks praises since I placed my order. What a pleasure...
Eric
Old Jan 30, 2003 | 11:13 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Hey Eric.
What is the offset of those wheels?
With a lowered car using the H&R or KW springs, you will run into rubbing problems with a 40mm offset, and that was on 16s. I have a feeling you will need to have at least a 45mm offset, maybe 43mm, with 18s and springs.
Hope that helps!
Randy
Old Jan 31, 2003 | 06:33 AM
Alex@tirerack's Avatar
Alex@tirerack
the Js5's are 42 mm offset.
Dan
_________________
MCO tire and wheel forum Moderator
Old Jan 31, 2003 | 07:15 AM
wwwebb's Avatar
wwwebb
notpaddyhopkirk,
When you get those on you must take pictures. There aren't many 18s out there.
Old Jan 31, 2003 | 07:26 AM
mightyMiniz's Avatar
mightyMiniz
I would like more info on those 18's I'm about to recieve a set of 18x8's and am not sure if it's going to fit right.
Post Pics!
Old Jan 31, 2003 | 07:28 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
>>Dan
Dan,
Unfortunately the camber adjustment on the MINI isn't really adjustable, so you don't get much play there.
I already have roughly .5 - 1 degree negative in the rear, due to the springs, and the 40mm 16s still rubbed.
Hope that helps.
Randy
_________________
Click It!
Old Jan 31, 2003 | 07:30 AM
cooper44's Avatar
cooper44
After lowering, I swear I've seen other posts that say no alignment is needed. Negative camber isn't really much of a concern, but will I still need to get it done? Thanks!
Craig
Old Jan 31, 2003 | 06:39 PM
notpaddyhopkirk
Actually I have had them on for a couple of weeks. I don't get any rubbing now but I was just wondering if anybody knew, Dan in particular, if the H&R springs would cause any rubbing with this combo.
I am not talking about loading the back up with bags of concrete, just under normal 1-2 person ocupancy use.
Pic 1
Pic 2
Pic 3
Thanks, any feedback is much appreciated.
Eric
Old Feb 3, 2003 | 08:49 AM
trixander's Avatar
trixander
Wow, the larger wheel size really emphasizes the smallness of the brake rotors. Looks cool, though
Old Feb 3, 2003 | 10:27 PM
notpaddyhopkirk
Indeed, my thoughts exactly.
It would be nice to find a kit that allowed the stock calipers but with larger crossdrilled discs to improve the look. Probably improve the braking too, if only becuase of increased leverage.
Old Feb 4, 2003 | 09:53 PM
notpaddyhopkirk
I am guessing that no one knows about this combo and the H&R springs.
If anyone has any info I would be glad to have it. Otherwise I am going to have to just experiment.
jeremy_reyes94
Sep 6, 2019 07:53 AM
melscoop
Mar 30, 2016 06:56 PM
G1HQ
Aug 28, 2015 01:41 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
