Help with painting s-lites please
Old Feb 17, 2005 | 08:39 AM
sfjames2's Avatar
sfjames2
Hello guys, I'm planning on painting a set of s-lites black. Any paints that you recommend? Anyone done this before?
I was going to get them powder coated, but don't want to spend the money and actually think painting them might look better.
thank you
Old Feb 17, 2005 | 09:13 AM
sfjames2's Avatar
sfjames2
anyone?
Old Feb 17, 2005 | 09:16 AM
Tüls's Avatar
Tüls
Turbius Maximus
you are best off spending the $ with a body shop....you'll get better results...if you are stuck on doing it your self make sure you sand then really well....prime, and then paint...and after you paint the black...use a laqure to "clear" it....
as for the paint types.... again if you are going to do it your self....go to a paint shop and do some research on spray paints...fint out which ones are for metal etc....
you can get very nice results...if you take your time....I still recomend having it done "professionally" if you have someone you trust
Old Feb 17, 2005 | 09:23 AM
sfjames2's Avatar
sfjames2
thanks Tuls. My dumas forgot about taking them to a paint shop.
Old Feb 17, 2005 | 09:30 AM
sright's Avatar
sright
Assuming you have a sprayer. I would add to what TULS said that dust and dirt contamination will be you biggest pitfalls. you must make sure it is clean and use a tack rag. If you don't have a booth do it in the morning with no wind. I have used alot of dupont products in the past so that is what I recomend. Dupont Lucite for the gloss coat. I don't do any of that anymore so there may be better products out there. I now use a FUJI HVLP sprayer for my woodworking hobbie so I dont remember the exact numbers on the dupont products but in the end it will be cheaper to go have someone else do it.
Old Feb 17, 2005 | 09:41 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
The guy I bought my new wheels from is now running black powder-coated s-lites. They look AWESOME!
He has a PS/B JCW MCS modded up the wazoo.
Old Feb 17, 2005 | 10:06 AM
sfjames2's Avatar
sfjames2
thanks for the feedback guys. One body shop quoted me $50-75. per rim. Doesn't sound to bad, but now I'm wondering, what the chances are of them getting damaged during the tire mounting procedure. decisions, decisions.
Old Feb 17, 2005 | 02:49 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You might check around for quotes on powder coating- in my area it think it will be about the same as $65 to $75 per rim. Results can vary with how well the paint or powdercoat is done. Good prep work is essential for the paint to stick.
If you mount non runflats you're likely to be at less risk for damaging the rims than if you use runflats.
A clear coat for durability would be worth a lot and keeping brake dust off the wheels with EBC green pads or Miltex Redbox pads would be recommended. The stock pads dust too much and if not cleaned off regularly will harm the finish.
Old Feb 17, 2005 | 04:00 PM
aminicooper's Avatar
aminicooper
BBM (in Emeryville) does rim painting in powder coat or body paint... I think powder coat was ~70$ each where as body paint (glossy) was ~115$ each. I had inquired with Jaques at the last Pulley Party since they had some custom painted rims on some cars.
Old Feb 17, 2005 | 04:11 PM
sfjames2's Avatar
sfjames2
thanks aminicooper, I'm going to get them painted instead of powder coated afterall.
Old Feb 17, 2005 | 04:59 PM
Rick-Anderson's Avatar
Rick-Anderson
A place here in Orange quoted me $45 a rim to powdercoat them.
bahman
Feb 14, 2016 10:29 AM
jeri534
Nov 6, 2015 01:40 PM
vulkandino
Oct 31, 2015 08:29 PM
BackcountrySkier13_inAZ
Oct 14, 2015 06:00 PM
M7Speed
Oct 1, 2015 07:05 AM
