Need help with some wheels for my R56
Old Oct 20, 2018 | 07:37 AM
Heroofsomething's Avatar
Heroofsomething
I have a base mini r56, I saw some wheels being sold online and they look nice but I not sure if they'd fit my mini. I've tried looking to see what the spec of my wheel is but it's all crazy confusing as everyone seems to switch up how they define their wheel size/fitment. Anyway these are the wheels and I'm hoping someone will know if they fit my mini
also it has this branded at the back. "3908" "17/.9.0J"
Old Oct 20, 2018 | 11:27 AM
MINIAC's Avatar
MINIAC
A 9" wheel width is pretty extreme. You also need to know the PCD (bolt pattern), ET (offset) and center bore.
Old Oct 20, 2018 | 12:55 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The picture shows a 5-lug wheel, which will not fit your 4-lug R56
Old Oct 20, 2018 | 01:26 PM
Heroofsomething
Yeah I remember someone saying if should be 17x45 or something of the sort? Im not sure what the 9 is for but it seems to have the 4 lug part as well since I've seen wheels for my car with the 10 holes. He said they're universal.
thank you for your help I just hope they fit cause I want that look for my mini!
Oh also how would I find out the PCD? And the ET and Center Bore?
Old Oct 20, 2018 | 02:14 PM
MINIAC's Avatar
MINIAC
Originally Posted by Heroofsomething
... how would I find out the PCD? And the ET and Center Bore?
You'd have to ask the seller or find specifications for the wheels online.
Old Oct 20, 2018 | 03:10 PM
Heroofsomething
okay, also I went on realoem and looked at the specs, but it's also confusing and I dont know what it means. Thanks for your help btw I see why you're in 6th gear lmao
Old Oct 20, 2018 | 05:12 PM
MINIAC's Avatar
MINIAC
The first number (51/2Jx15) is the width (5.5") and diameter (15") of the wheel and 45 is the offset (ET).
You may find the following reference helpful ...
Wheels and Tires - The MINI Wiki
Also check the Tire Rack for wheels.
Old Oct 21, 2018 | 03:41 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Again, if the wheels pictured in the first post are the ones you want, they won’t fit because they are drilled for a 5-bolt hub. Your R56 has a 4-bolt hub. It doesn’t matter if the diameter, width, and offset are correct or not. If the bolt pattern is wrong, wheels won’t fit.
Manny_cooper
Oct 28, 2016 06:05 AM
Fashizzles84
Feb 27, 2015 08:10 AM
BLAUGRANA
R55 :: Clubman Talk (2008+)
18
Oct 13, 2010 07:48 AM
mrravioli3
Tires, Wheels, & Brakes
Oct 21, 2009 05:28 PM
