Stock rim but taller tire?
Just got my new to me 2012 Clubman this Tuesday and I'm already looking to upgrade some stuff! I don't know if it my newness to the world of MINI but I fee like I'm sitting way lower to the ground than other small cars. I even feel like other MINIs sit higher than me. I believe I'm running at stock suspension height. The previous owner bought it used and said he didn't change a thing for the time he had it. It has Michelin Pilot Sport A/S 3 175/65ZR15 Can I and should I get a taller tire to raise my height? I've scrapped the front lip 2x already leaving gas station lots. That scrape sound is unnerving to say the least. My MINI is my daily commuter. I commute via highway and I live in Northern CA so theres zero threat of snow. Barely any rain. Don't plan on doing any track stuff. Just some roadtrips up to San Francisco and down to LA.
I played with this. Went up a little in tire diameter on my 05. But I also went down in "wheel" diameter.
https://www.americastire.com/learn/t...SAAEgJppPD_BwE
From the sounds of what you are saying, I'm afraid you'l have to go much too far in tire diameter to keep the underside off the ground. The tires will/might end up rubbing on the fenders.
Measure the car, find out how far you need to go...up, and then play with the calculator above.
Mike
Mike
Wow. Not worth the money. How about if I went up in wheel size to 16? 17 seems too much for commuting.
Mike
Mike
Guess I'll just leave it as is. I just have to get used to the feeling and more careful with driveways.
That's what I put on my 05. Removed the 17" wheels and installed 16" wheels.
Installed 205/55-16" Dunlop tires. My car has been lowered about 1.5". No tire rubbing with that tire and a stock offset wheel. The only driveway my car..."so far" rubs anything on is my own driveway..! And that's just the stock under chassis air dam.
The speedometer is about 2+ mph off now.
Mike
Mike
Mike
Mike
Save your money and get 185/65-15 or 195/60-15 tires when your current tires need replacing.
Ok. How will the wider tires affect driving performance and gas mileage? If I stay with my stock 15" wheels.
Gas mileage has to do with rolling resistance and tire rubber compound which can be tweaked for eco use. If two tires of the same type are compared the wider tire will have more resistance and slightly less mpg, the eco tire will usually be better on mpg by 2-3 miles per gallon. Of course air pressure is a huge factor on getting better mpg.
Looking at the bigger picture you have to consider wheel size and possible tire sizes and whether the tire you want for the intended use you need (performance vs Street vs cold weather, etc) comes in the size you want. For example the better Max Summer tires for handling and performance tend to come in 17" wheel sizes and larger. 15" wheels are good for race tires and All Season tire sizes.
175/65-15 is the OEM size but you aren't limited to that for 15" wheels. 195/60-15 is a common tire size that yields many good tires.
mini_macky
Tires, Wheels, & Brakes
Mar 15, 2009 12:25 PM
Krut
Suspension
Sep 23, 2007 09:59 AM
blitz64
32
Sep 26, 2005 11:24 PM
chrisneal
23
Jan 22, 2003 03:47 PM
