Mini Cooper S tire fitment 16x8
Hello all. I need help. I plan on getting Avid.1 AV19 wheels on my R56s that are 16x8 et15. I don't know what tires i need to get that will give it an aggressive look. I have BC racing coilovers and plan on closing the wheel gap. I was looking at 205/45/16. I don't want that tall of a wheel wall. does that make sense? Like i dont want a big tire but i dont want it too thin either.
I am okay with very slight stretching but would recommend none. i don't want too much camber, -2 will probably be the most i'd go. Also its a daily driver, I don't track, yet, and i'm not THAT aggressive, but sometimes like to drive a little hard (who doesn't in a MINI?)
Please Help! i'm new to fitment and could use some help soon!
Thank you! I know i'm picky but any help would be much appreciated!
3SDM 0.05 (Yes, "0.05" is what it's called. It's doesn't pertain to any measurement)
H&R Street Coilovers
Hi guys I'm new here and actually from Essex in the UK
I have joined up because I came across this thread when searching for image of the 0.05 wheels on Minis! They do really look great and I've just got to have some lol.
@MNMLST @Nick Royer could you tell me what camber you're running on your rear wheels?
Also, guys over on the UK forum seem to all have 50 profile which looks a little chunky... so it's good to see some 45 business going on! Do you have any problems with your tyres?
Any other tips much appreciated.
Olly.
Olly.
...@MNMLST @Nick Royer could you tell me what camber you're running on your rear wheels?
Thanks for the reply! Wow 3° really, it doesn't look that extreme in your pictures. I hope you don't mind but I've emailed the above to a reseller I found in the UK for precisely the kind of look I want
It seems you're running standard wheel bolts too? That's good as most I've come across seem to have a stud conversion... not a problem in itself, but it's just added cost innit.
That's great, thanks.
I am getting these put on next month now, with top mounts on the front and two sets of rear control arms on the rear so should get them sitting nicely! Unfortunately it's proving hard to get the (Michelin) tyres I want in 205/45... but I shall continue my search.
Got one more question regarding these particular wheels though. Do you know if they have a 60 degree tapered seat? If so then I can go ahead and order the wheel bolts I want
16x8
Just thought I'd update this showing pictures of them now on my car. Ended up with 2.5° front and 4.0° rear camber...
Hey man I was wondering if you can help me because I have a r53 Mini and I want 16x8 with a 25mm offset and I have stock suspension. Do you think this will work or no
Attachment 143625
Attachment 143626
Attachment 143627
Attachment 143625
Attachment 143626
Attachment 143627
205/45-16 is smaller diameter than stock. Stock 16 inch tire size is 195/55-16, and stock 17 inch tire size is 205/45-17. If you are still on stock suspension, you shouldn’t have any rubbing, but it will look funny...
Alpha Motoring
Nov 10, 2015 07:08 AM
Oct 1, 2015 12:34 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
