MCS swap to JCW calipers?
Old May 16, 2015 | 05:18 PM
yukinoinu's Avatar
yukinoinu
Is it possible to swap my 2 piston R53 calipers to the JCW 4 piston calipers? or is this a totally not needed upgrade? I do autocross felt a little fade in my brakes but only after 6 very hard runs, I have stock calipers with stoptech rotors and pads. Not sure if needed or if they are just a waste of money.
Old May 17, 2015 | 04:20 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
There are several things you can do to improve braking before switching to a big brake kit or JCW brakes.
Replace brake fluid with higher temp fluid (not OEM) and change it once yearly.
Use brake pads that tolerate higher temps (those made for light track use)
Spend some time with an experienced autocross instructor who can check and critique your braking technique. Too many drivers will brake late and overshoot/understeer into a tight turn. Some drivers will brake when they don't need to such as in a slalom (due to going too fast for the spacing).
Old Jul 16, 2015 | 01:16 PM
AU_Mini's Avatar
AU_Mini
Look into buying stock R56 S brakes, which are the same as the 53 JCW just at a cheaper price.
Should be able to upgrade the calipers, rotors, and pads for under $400.
Old Jul 16, 2015 | 01:24 PM
Mib4840's Avatar
Mib4840
Make sure you get the carriers also from the R56. You will need them. It is an extremely easy swap! I did mine on my 04. I bought the front set up from a 2011.
Old Jul 16, 2015 | 01:27 PM
AU_Mini's Avatar
AU_Mini
Good catch, I meant to add that. I'm not sure how the rebuilt units are but they can be had from your auto parts store for under $200 with the carriers included.
I would also suggest SS braided line since you have to disconnect your old lines from the calipers anyway.
Old Jul 16, 2015 | 05:00 PM
RB-MINI's Avatar
RB-MINI
Originally Posted by Mib4840
Make sure you get the carriers also from the R56S. You will need them. It is an extremely easy swap! I did mine on my 04. I bought the front set up from a 2011.
Make sure they have the R56S carriers, at least if you want to run the 294mm rotors like the R53 JCW brakes.
Old Jul 16, 2015 | 10:03 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I have a set of R56 JCW Brembo brakes waiting in the garage to be installed, so my 2012 R56S calipers, rotors, and pads will be posted in the marketplace in a week or two...
Old Jul 21, 2015 | 12:10 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
minihune speaks wisely. Depending on humidity where you live, I'd bleed those brakes before each event. Also consider that you may get moved up in class if you run up-graded brakes.
Old Jul 21, 2015 | 12:41 PM
rkw's Avatar
rkw
If you truly go with the R56 JCW 4 piston brakes, check whether your current wheels will fit over them.
squawSkiBum
Oct 2, 2015 09:21 AM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
StealthR53
Aug 8, 2015 10:59 AM
