Brake pad wears
Old Jan 25, 2014 | 09:00 AM
  #51
coopercarly's Avatar
coopercarly
Anyone?
Old Jan 25, 2014 | 04:47 PM
  #52
squawSkiBum's Avatar
squawSkiBum
Moderator
see here:
https://www.northamericanmotoring.co...guide-pin.html
You may not need new caliper pins. Pull the old ones out, if they are undamaged then just clean the pins and the holes with brake cleaner, lube with brake grease, replace, change the pads, and you're good to go. Be careful of the little rubber boots, and be sure to check that the rotors are not below minimum thickness.
Old Jan 27, 2014 | 12:26 AM
  #53
Himesed's Avatar
Himesed
You may need to bleed your brakes. air in the line may impact only one caliper or any combination of calipers.
Old Jan 28, 2014 | 08:12 PM
  #54
coopercarly
Originally Posted by squawSkiBum
see here:
Thanks for the info! My inner pad on the passenger rear is rubbing metal to metal and ruin the rotor so I'm going to replace the rotor.
Old Feb 16, 2014 | 06:56 AM
  #55
madman67's Avatar
madman67
Originally Posted by danjreed
Pretty basic design. Several DIYs online. Just use good tools/chemicals/right stuff/good hardware you'll have no problems.
Here's a good DIY
http://r56mini.com/cooper/diydiscsandpads/
And yes, always replace brake parts as full axle sets (as in left/right complete..) Rotors.. pads.. hardware.. left/right always as a set.
Good advice. Besides, the pads come as FULL sets,(driver/pass.side) so, you may as well replace all. Just did the front brakes on my wife's '09 MCS yesterday! @SoundMessage, I'm no Master Mechanic by any stretch, but this procedure is really pretty simple and can save you LOTS of money!
Old Jul 7, 2015 | 06:15 AM
  #56
Al-Hajj Jameel Ibn Dawood's Avatar
Asymmetric Caliper Pins
I am doing the brakes on my car, and ran into the same problem with a caliper rebuild being necessary on the front passenger caliper. There's also another issue - the caliper pins are not identical for each side. One is a long smooth pin, the other is shorter, with a rubber sleeve that fits on one end.
Caliper pins look exactly like this.
I thought I had reassembled it correctly, and initially assumed the "stealership" had fished through the parts bin and just gave me some mismatched replacements... I also fought with it for a bit, but caliper pins are supposed to go in with ease. I checked Rock Auto for some new pins, and found that a reman TRW caliper would have the exact same setup.
Has anyone else run into this?
Also, how do you keep the brake fluid from draining out when you remove the caliper?
Gremothra
Sep 9, 2015 08:42 PM
wildwestrider
Sep 4, 2015 06:25 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Tires, Wheels & Brakes
Sep 1, 2015 12:13 PM
Aug 25, 2015 09:18 AM
