Do I need new rims if I get rid of my run flats
Old Apr 16, 2013 | 11:21 AM
cocopud's Avatar
cocopud
I have pretty much decided to go with non run flats when I replace my tires. Always hated how the car handled and don’t want any added expense if I can avoid it. I have looked into going with non run flats quite a bit, but wondering why I still read that you have to change the rims also as regular tires will not fit on run flat rims but most people don’t mention it. Any truth to this at all.
I currently have the original 195/55 R16 tires on a 2009 copper S convertible.
Old Apr 16, 2013 | 11:26 AM
MINILLA's Avatar
MINILLA
Nope my Cooper S came with runflats and we switched them out with no trouble....
Old Apr 16, 2013 | 11:40 AM
Velocityvic's Avatar
Velocityvic
Not unless you want to change wheel size.
Old Apr 16, 2013 | 11:46 AM
CKeffer's Avatar
CKeffer
So long as you get a tire made for the same size wheel, then there will be no issue. There is no such thing as a wheel made specifically for runflat tires, or non-runflat tires.
Old Apr 16, 2013 | 12:11 PM
Chappy's Avatar
Chappy
We did the same thing on our MCS, but also switched to a much lighter rim which made a big difference in the performance characteristics.
Good luck
Old Apr 16, 2013 | 06:40 PM
Btwyx's Avatar
Btwyx
There is such a thing as a wheel made for run flats, but that's a different system. MINI uses ones which fit on regular wheels. There's no issues changing to non run flats.
Old Apr 16, 2013 | 07:49 PM
ZippyNH's Avatar
ZippyNH
+1
Old Apr 16, 2013 | 08:55 PM
Porthos's Avatar
Porthos
No not really unless you want your MINI to look that much better.
Old Apr 17, 2013 | 07:32 AM
CKeffer's Avatar
CKeffer
You have any more info on this? Cause this is the first I've heard about such a thing....outside of the tweel and other similar systems, but those are less runflat and more airless.
Old Apr 17, 2013 | 08:41 AM
BRGPA's Avatar
BRGPA
I think Honda's PAX runflat wheel/tire setup is one where you can't just mount non-runflat tires to the original wheels. Glad MINI didn't use that system!
Old Apr 17, 2013 | 07:58 PM
Btwyx's Avatar
Btwyx
They seem to be called "Auxiliary Supported Run-Flat Systems". Don't know who makes them.
Old Apr 17, 2013 | 09:58 PM
bmwr606's Avatar
bmwr606
you do not need to change wheels to replace runflats with nonrunflats
if you are still in doubt, contact a tire profressional, i suggest Alex at tirerack.com
Alex Mouroulis | Sales Specialist
__________________________________________________ ________
Tire Rack
7101 Vorden Parkway
South Bend, IN 46628
O: 888 428 8355 ext. 4294
O: 574 287 2345 ext. 4294
F: 574 236 7707
Alex@tirerack.com
scott
Old Apr 18, 2013 | 09:29 AM
CKeffer's Avatar
CKeffer
Interesting, I had never heard of those. Thanks!
Old Apr 18, 2013 | 01:53 PM
silo617's Avatar
silo617
Got rid of my runflats today!!!!!!
Have been researching all week about what tires to get.
Got 15,000 on my original set of runflats. Also told I would have to replace rims. (which turned out to be BS.) I have a 2012 coupe s with optional 17" rims. Practically needed to wear a mouth guard to ride in the downtown streets of Baltimore with the runflats. Replaced today with Continental
205/45/R17 all weather Extreme Contact DWS non-runflat tires @ $116 a pop from TireRack. Delivered next day . Install with balancing etc. $99.
I CANNOT BELIEVE I AM DRIVING THE SAME CAR. Runflats just suck.
Mini wanted $400 a tire to replace with the same crappy original runflats.
Old Apr 18, 2013 | 04:50 PM
fused's Avatar
fused
Nope, just have your tire guy pull the runflats and put your NON RF tires on.
The rest, balance etc....is just like any other NON RF on any other car...
Getting rid of my RFs was the BEST thing that I could ever had done for my mini....
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
romansmini
Aug 25, 2015 11:57 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
