Need some help - Wheels not flush with hub - fix?
Old Mar 18, 2004 | 09:31 AM
Storer's Avatar
Storer
Alright, I ordered some wheels and had them put on today. The installer said that they don't fit flush with the hub. Not terribly bad, but noticeable above 50 mph.
Can someone tell me how to correct this? Will wheelspacers do the trick?
TIA
-Chris
Old Mar 18, 2004 | 09:41 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Sounds like they have the wrong centerbore. Do they have centering rings? These wheels have a 73 mm centerbore but use various size centering rings (56.1 mm for the MINI) to allow a perfect fit. This pic shows the old centering rings from a Miata application (54 mm ???)
:smile:
Old Mar 18, 2004 | 09:53 AM
Storer's Avatar
Storer
Thanks for the response. Wish I knew... I'm not knowledgable at all about wheels and tires. Crap...
Old Mar 18, 2004 | 10:57 AM
kenchan's Avatar
kenchan
You need to get the correct centering rings. On the picture above, you see that
black ring in the center of the wheel? That's a centering ring.
You will need to get one for that wheel that is for the Mini (56.1mm diameter).
That's all. :smile:
Old Mar 18, 2004 | 11:54 AM
Storer's Avatar
Storer
Awesome! Thanks kenchan!
Alright, question number 2... where can I find centering rings?
Old Mar 18, 2004 | 12:27 PM
andy@ross-tech.com
What wheels do you have? Where did you get them?
Old Mar 18, 2004 | 12:50 PM
Storer's Avatar
Storer
Andy, I got some cheapo wheels from AIR Dynamic Racing (Volution wheels to be exact)... knockoffs. I would rather have gotten name brand wheels, but could not afford them right now. Unfortuantely, I had to get something because a nasty pothole gave my all-season Goodyear's a bubble.
Old Mar 18, 2004 | 01:17 PM
kenchan's Avatar
kenchan
Your best bet would be to take that centering ring off and either
measure the diameter using a digital caliper, ..unless of course,
some one can get youthe exact centering ring from the manufacturer
(best way).
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, Anthrasite Int, TK5 16x7, 6CDMP3, etc.
<a href="http://hometown.aol.com/teined/index.html">more info</a>
sevin
May 2, 2026 06:11 AM
Minibeagle
Aug 13, 2015 10:00 AM
ki7hy
Aug 12, 2015 07:07 PM
bleonard1401
Aug 11, 2015 02:53 PM
bleonard1401
R60/R61 Stock Problems/Issues
Aug 10, 2015 02:15 PM
