Show me your WHEELS! 2.0
Old Nov 6, 2014 | 01:00 AM
  #926
Systemlord's Avatar
Systemlord
Originally Posted by johntotah94
OZ Ultraleggera
Nice 18" inch wheels, hows your ride quality?
Old Nov 6, 2014 | 06:49 AM
  #927
Grizld700's Avatar
Grizld700
Not the best pic in the world (iPhone5) but this is my winter set up
Old Nov 6, 2014 | 12:39 PM
  #928
Systemlord's Avatar
Systemlord
That green is blinding me, you'll be easily visible to other motorists!
Old Nov 6, 2014 | 12:41 PM
  #929
That green is intense. You will stand out.
Old Nov 6, 2014 | 01:44 PM
  #930
D.D.'s Avatar
D.D.
Yikes!!! Bright!!
Old Nov 6, 2014 | 01:58 PM
  #931
Grizld700's Avatar
Grizld700
They make me grin every time I see it in the parking lot they're way fun. Makes me feel like a high schooler. So that being said, I'm sure by the end of winter I will be more than ready for my summer wheels and tires again.
Old Nov 15, 2014 | 12:56 PM
  #932
mikes888's Avatar
mikes888
BMW M3 wheel on a 06 Mini Cooper R50
Attachment 102375
Attachment 102376
Full photo of vehicle posted at "What have you done to your mini today. I put a set of BMW M3 rims 17x7.5 mounting 205/40 R17 tires on an R50 using adapters. Girlfriend wanted something blue on the wheels so, I used blue lug nuts.
Old Nov 15, 2014 | 04:24 PM
  #933
Systemlord's Avatar
Systemlord
Originally Posted by mikes888
Attachment 102375
Attachment 102376
Invalid Attachment specified. If you followed a valid link, please notify the administrator
Old Nov 23, 2014 | 04:23 PM
  #934
Dustypants's Avatar
Dustypants
Some borrowed Team Dynamics 1.2, 15mm spacer in front, 5 mm in rear. NM springs and koni yellows.
Old Nov 23, 2014 | 06:58 PM
  #935
johntotah94's Avatar
johntotah94
Actually a lot better than before. I have H&R Springs and it rode super hard with my stock wheels. The new wheels raised my wheel gap so probably gave the suspension more slack. Ride quality is a lot better. Probably will go a tad lower when I get coils.
Old Nov 24, 2014 | 03:32 PM
  #936
mini coop's Avatar
mini coop
Being that your mirrors, scoop and headlight rings are green, what color are your summer wheels? Do you change everything around?
Old Nov 24, 2014 | 07:41 PM
  #937
anuppercasej's Avatar
anuppercasej
Sparco Assetto Gara 16x7
Old Jan 2, 2015 | 09:38 AM
  #938
R53_Unionjack's Avatar
R53_Unionjack
Originally Posted by babyR00F
xxr 527 chromium black 17x8.25 +20 205/45/17
2004 liquid yellow r53 tein s tech lowering springs
Have you had any issues with rubbing anywhere? Because I was actually going to do the same set up and then I saw that you have done it too. Just with the gold wheels instead
Old Jan 7, 2015 | 06:41 PM
  #939
lbzking's Avatar
lbzking
here is mine.
17x7.5 Gline
Attached Thumbnails Show me your WHEELS! 2.0-2015-01-07-17.13.45.jpg   Show me your WHEELS! 2.0-2015-01-07-17.16.29.jpg   Show me your WHEELS! 2.0-2015-01-07-17.17.26.jpg
Old Jan 16, 2015 | 12:09 PM
  #940
Lantz's Avatar
Lantz
17" O.Z. Formula4
Mounted new 17" OZ Formula4 HLT's this week.
Old Jan 16, 2015 | 12:13 PM
  #941
Grizld700's Avatar
Grizld700
Nice accenting wheels caps there
Old Jan 19, 2015 | 06:20 PM
  #942
Mitchell Z06's Avatar
Mitchell Z06
Originally Posted by ra2fanatic
More pics and specs??
Old Jan 19, 2015 | 06:30 PM
  #943
ra2fanatic's Avatar
ra2fanatic
I wish I had more photos myself!
They're in storage for the season.
18x8 +32 offset.
Old Jan 19, 2015 | 08:16 PM
  #944
Indimanic's Avatar
Indimanic
R113
Nice stock wheels
Old Jan 20, 2015 | 05:04 AM
  #945
Mitchell Z06
18x8 +32 offset.
ah no worries, spec alone help, talked to the guys at CCW last week about some classic/4 and there are wanting to put me into a 17x8.5 and I keep thinking they will stick out to much for my taste, seeing your picture alone helps, may just go with a 17x8 with that same offset
Old Jan 20, 2015 | 08:18 AM
  #946
ra2fanatic's Avatar
ra2fanatic
It really depends on the finish, but since they're similar to the Classics I used to have, then they'll likely stick out for sure w/o proper camber adjustments.
If you're running JCW BBK or any BBK for that matter, you will have clearance issues with Classics. Not entirely sure about C/4's. I had to run 10mm spacers up front just to clear my StopTechs and that was the end of my run with the Classics, it just pushed my fronts too out and killed the ride.
Also, keep in mind that with 17's the faces will look smaller because of the design of the barrels in relation to the centers as well. Hence why I like the 18s look from CCW because they look so much better this way.
Also, if you go with the C/4's, get the Swiss finish where all the alternating hole are drilled, it's a waaaaay clearner look.
Old Feb 13, 2015 | 09:23 AM
  #947
santoph's Avatar
santoph
16" Panasport
Old Feb 14, 2015 | 09:08 PM
  #948
superbriam's Avatar
superbriam
My wheels 15x8 +25 tires are 195/50. Its great low and wide.
Old Feb 15, 2015 | 05:34 AM
  #949
americo11's Avatar
americo11
nice!
Old Feb 15, 2015 | 05:38 AM
  #950
americo11's Avatar
americo11
That is one beautiful roadster!!! Classy, black and silver. Those wheels really compliment the car. Great Choice! Really great choice.
Originally Posted by GEMSTER
17x8 ET30 Rotiform NUE Brushed Face with Polished Pockets. Wrapped with 205/40 Bridgestone RE760 Sport.
