SCC Super Z6 Snow Cables
Old Nov 11, 2010 | 09:44 PM
Gopedjim's Avatar
Gopedjim
Has anyone tried the SCC Super Z6 cables with 205/45-17 tires?
http://www.scc-chain.com/Traction%20Pages/Trac_SZ6.html
The website claims that only 1/4" clearance is required. There seems to be about 3/8" clearance between the back of the tire and the strut, so it SHOULD work. I'm wondering if anyone has used them before.
The owner's manual is obviously no help, because Mini doesn't suggest chains on 17" wheels.
Before you ask, snow tires aren't a good option for me. I'm just looking for chains I can carry during occasional ski trips to Tahoe.
I've got a 2010 MCS with the 17" wheels.
Old Nov 14, 2010 | 06:13 PM
MLPearson79's Avatar
MLPearson79
I would think they should be fine, just as long as you drive like you have chains on (meaning, SLOWLY lol).
Old Nov 15, 2010 | 08:34 PM
krim's Avatar
krim
no problems using them on mine, as long as they're installed correctly
Old Nov 15, 2010 | 09:18 PM
hsautocrosser's Avatar
hsautocrosser
"The owner's manual is obviously no help, because Mini doesn't suggest chains on 17" wheels."
My manual does.
175/65-15
175/60-16
185/50-17
It says only certain types of fine link chains have been tested and to contact your dealer for more information.
Old Dec 17, 2015 | 12:12 AM
pepprwhite10's Avatar
pepprwhite10
Thinking about purchasing the same. How did these turn out on the 205/45/17s?
Old Jan 18, 2016 | 07:28 AM
SupeR53's Avatar
SupeR53
I've seen SO many cable chains scattered on the side of the road, used some once or twice, but I find that 4 wheel studs are much more effective and less trouble. But then, I commute down 3500' of elevation every day through a canyon. Just my $.02
Old Jan 18, 2016 | 12:21 PM
Studs are the way to go if you do snow tires. I have pirelli winters on studs right now.
But if you do need a set of chains , the snow socks will work for emergencies. Dont run with studs of course More for people on all seasons and get the occasional snow/.
All right here , watch the certain sizes. Certain chains only.
https://www.northamericanmotoring.co...endations.html
If you are in a snowy area , snow tires or snow tires with studs are great.
Old Jan 27, 2016 | 03:43 PM
hsautocrosser
Metal studs are not permitted everywhere.
Some of the more surprising states not allowing them: Alaska, Michigan, Minnesota, Illinois, Wisconsin.
And some states apparently require chains in snow emergencies even if you have studded tires.
http://drivinglaws.aaa.com/tag/studded-tires/
Old Jan 28, 2016 | 04:55 AM
Yea, some states only allow studs for a certain time like Ohio here. Yea and some require chains in the mountains. If a state by state thing.
minimacattack
Metroplex MINI - Texas
Oct 18, 2016 01:24 PM
bctf1
Jan 2, 2016 04:02 PM
MINI Stupor
Oct 1, 2015 11:36 AM
pkillur
Sep 26, 2015 01:57 PM
minimacattack
Sep 25, 2015 07:37 PM
