Stupid tire size question?????????
Old Jun 3, 2010 | 10:54 AM
ronnie948's Avatar
ronnie948
Is the the 205-45-17 sidewall taller then the 215-45-17 ????
I found a width chart that tell me the 215 is .36 inches wider but I can't find a chart on which one is a taller tire.
Old Jun 3, 2010 | 11:17 AM
Carlisle's Avatar
Carlisle
The 215 will have a slightly taller sidewall because the 45 measurement really means 45% of the width of the tire.
I have 215/45's on my car and LOVE them. They have improved the quality of my life greatly.
Old Jun 3, 2010 | 11:51 AM
ronnie948's Avatar
ronnie948
Thank you Carlisle
Thank you for the information. I will get the 215/45/17 Michelin Exalto PE's for my car. I just did not want shorter sidewalls then I have now.
Do you still put 38psi in your tires? I know with run-flats you need the 38psi but is it still needed for non-runflat tires or would 32 or 34 psi work?
Old Jun 3, 2010 | 11:57 AM
moreorless's Avatar
moreorless
Here you go.
Play with this for a while.
Old Jun 3, 2010 | 12:02 PM
ronnie948's Avatar
ronnie948
Thanks Moreorlass
Great site. Thank You.
Old Jun 3, 2010 | 12:23 PM
moreorless's Avatar
moreorless
Aye. There's a ton of information on that one page, including what your speedo will read.
Old Jun 3, 2010 | 01:39 PM
rjtrout2000's Avatar
rjtrout2000
I would run about 33-35 psi in non-runflat tires. However, different tires may require certain exceptions so check with the manufacturer or your tire sales person and see what they say. I run 34 psi in my continental tires and they ride very well.
Old Jun 3, 2010 | 01:44 PM
lhoboy's Avatar
lhoboy
I found the 215/40/17s to be a better fit. The 215/45s are .9cm larger diameter than the the stock 205/45s. The 215/40s are 1.2 cm shorter. Not as close a fit to the stock tires, but better handling (lower auto center of gravity) and better acceleration. Comes at the cost of a slightly harsher ride, and a slightly lower top end speed. The ride will still be much better than stock if you stay away from the runflats.
Old Jun 4, 2010 | 01:25 AM
howsoonisnow1985's Avatar
howsoonisnow1985
+1
on all posts above
I too personally prefer 215/40, but if your willing to forsake slight performance for comfort 215/45 is the way to go.
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
