What's the weight of factory wheels?
>>Any one knows?
>>R90 (17"
>>R90 (16"
>>R88 (16"
>>R87 (16"
>>R85 (15"
>>R84 (16"
>>R83 (16"
>>R82 (15"
>>R81 (15"
>>Which 16" is the lightest?
Hello davecsumini
Here are your answer:
Style R81 (7-hole) 5.5Jx15 - 1512458 & 1512459 = 5.45Kg Offset = 45mm
(Cooper w/ all season tires) [weight is 14.601794lb]
Style R82 (8-spoke) 5.5Jx15 - 1512347 & 6756674 = 6.9Kg Offset = 45mm
(Cooper w/ all season tires) [weight is 18.4866793lb]
Style R83 (5-star) 6.5Jx16 - 1512348 & 1512349 = 9.1Kg Offset = 50mm
(Cooper w/ performance runflat tires ) [weight is 24.309828]
Style R84 (V-spoke) 6.5Jx16 - 1512350 & 1512351 = 8.0Kg Offset = 50mm
(Cooper S w/ all season runflat tires) [weight is 21.4338310lb]
Style R85 (S-lite) 7x17J - 1512352 & 6757859 = 11.4Kg Offset = 50mm
(Cooper S w/ performance runflat tires or all season runflat tires )
[weight is 30.5432092lb]
Style R86 5.5Jx15 - 6755809 = 6.8Kg Offset = 45mm
(Accessory wheel) [weight is 18.2187564lb]
Style R87 5.5Jx16 - 6755814 = 7.5Kg Offset = 45mm
(Accessory wheel) [weight is 20.0942166lb]
Style R88 6.5Jx16 - 6755811 = 8.9Kg Offset = 48mm
(Accessory wheel) [weight is 23.8451370lb]
Style R90 7Jx17 Two-Piece - 6755813 = 10.95Kg Offset = 48mm
(Accessory wheel) [weight is 29.3375562lb]
I hope this will help
>>R90 (17"
>>R90 (16"
>>R88 (16"
>>R87 (16"
>>R85 (15"
>>R84 (16"
>>R83 (16"
>>R82 (15"
>>R81 (15"
Hello davecsumini
>>Oh yeah, AC_MINI -- would it possible to get the weights of the various rims without the tires included? Thanks a lot
Hello erik808
I will try my best:
To start off here are some of the SSR (Speed Star Racing)'s Competition model wheel: Model050
Hello erik808
I will try my best:
If you want to look up wheel and tire weights yourself then read this:
https://www.northamericanmotoring.co...pic=2242&0
For OEM wheels-
https://www.northamericanmotoring.co...pic=2075&4
Or for more details talk to alex@tirerack.
For the lightweight 16" wheels-
In the SSR comp family (but not exactly SSR Comp) see:
The SSR comp R in 16x6.5" which is lighter (about 11.9 lbs.) than the standard SSR Comp 16x7 and less expensive.
No centercap and no polished lip (different than standard SSR Comp rims) or other markings but very strong/nice and light. See alex@tirerack for more info.
_________________
ALOHA
For OEM wheels-
_________________
ALOHA
>No centercap and no polished lip or other markings but very strong/nice and light.
huh, though all comps came with polished lips. TypeC's in Japan do not
come with polished lips.
>>Thanks, AC_MINI!! Actually, I meant the weights without tires of the MINI rims exclusively.
Weights are for rims only.
OE 15" Rims with 175/65 tires
R81 7-hole ET45 12.0lb (5.45kg)
R82 8-spoke ET45 15.2lb (6.9kg)
R86 Five star-spoke ET45 15.0lb (6.8kg)
R87 double-spoke ET45 16.5lb (7.5kg)
R12 steel wheel ET 45 14.8lb (6.7kg)
15x3.5" space-saver wheel 12.7lb (5.75kg)
OE 16" Rims (runflat tires)
R83 5-star ET50 20.1lb (9.1kg)
R84 X-lite ( V-spoke) ET50 17.6lb (8.0kg)
R88 Double spoke ET48 19.6lb (8.9kg)
R90 cross spoke one piece ET48 20.9 lb (9.5kg)
OEM 16" run flat tires:
195/55-16 TIRE WEIGHT (*)
Goodyear Eagle NCT 5 EMT 22.6lb (10.26kg) P,C
Dunlop SP Sport 3000A DSST 23.6lb (10.72kg) P,C
Dunlop SP Sport 5000A DSST 23.5lb (10.68kg) A,S
P = performance (summer) tire
A = all-season tire
C = Cooper
S = Cooper S
OE 17" Rims
R85 S-spoke (S-lite) ET 50 25.1 lb
R90 Cross spoke two piece ET 48 24.1 lb
OEM run flat 17" tires
205/45-17 TIRE WEIGHT (*)
Dunlop SP Sport 9000 DSST 21.8lb P
Pirelli Eufori@ 22.0lb P
Goodyear Eagle RS-A EMT 30.4lb A
A = all-season tire
All Data above from this resource with pictures;
http://www.mini2.com/forum/faq.php?f...factory_wheels
_________________
ALOHA
A = all-season tire
C = Cooper
S = Cooper S
OE 17" Rims
A = all-season tire
_________________
ALOHA
>>Thanks minihune for posting the correct MINI OEM wheel/tire weights!
No problem.
I was looking at the wheel info and doing the math and it was not adding up for me.
I PM'ed AC_MINI already.
I included the link because the resource is good but I gave the info just in case the link happens to go down.
No problem.
>>Thanks for the great info. Hmmph...S-Lite at 30 lbs! So much for truth in advertising.
As far as I can tell the S-lite rim itself is 25.1 pounds and with the tire weighs about 48+ pounds (depends on which tire). It's not really that light overwise it would be called the S-light.
Dec 23, 2015 10:36 AM
eatsleepautox
Oct 30, 2015 06:46 AM
