Brake pads
Old Mar 30, 2010 | 09:35 PM
DEHawk's Avatar
DEHawk
Brake pads
So what brake pads are you using? Looking to upgrade mine. I have a 07 MCS with the JCW brakes. Looking to do some auto crossing and track time this summer, would like a good pair for the front that resists brake fade.
Old Mar 30, 2010 | 10:39 PM
Robin Casady's Avatar
Robin Casady
I'm running Carbotech 1521 Bobcats, and have about 10K miles on them. I like them; almost no brake dust, and better modulation than factory pads. They supposedly outlast the factory pads and are easier on rotors.
However, the Bobcats are a street pad and should not be used for track. Carbotech makes other pads that are better suited for track.
Old Mar 31, 2010 | 08:52 AM
slinger688's Avatar
slinger688
Are those the brembo brakes from the newer JCW (>2009) including calipers etc or are those just the 294 mm drilled rotors.
I would not track with the JCW drilled rotors because they seem to crack. Some friends had problems with them on the track.
For pads, typical trackies have a track set and a regular set for the street.
Old Mar 31, 2010 | 10:14 AM
welshmenwillnotyield's Avatar
I used to have Ferodos but took them off cuz they dusted so bad. I replaced them with Hawk HPS pads all the way around and they have worn really well with little dusting...so well that I don't even have to change out while at the track.
Old Mar 31, 2010 | 01:19 PM
DEHawk's Avatar
DEHawk
My Cooper is a 2007, not sure how old or new the brakes are. They came with it. I bought the car used with 12000 miles on it. The rotors are the cross drilled ones though.
If I bought a separate "track" set how easy is it to swap them out?
What I have been looking at are the EBC "Yellow Stuff".
Old Mar 31, 2010 | 04:37 PM
slinger688's Avatar
slinger688
They are quite easy to swap out but you do need a jack and some basic tools including a torque wrench.
I take my time so each side takes about 20-25 minutes.
I would recommend Carbotech XP10s (front) for the track.
Old Mar 31, 2010 | 11:23 PM
rjtrout2000's Avatar
rjtrout2000
Got mintex red box going on the car here soon. I will post another reply once they are installed!
Old Apr 1, 2010 | 03:54 AM
slinger688's Avatar
slinger688
I believe that is a mild street brake pad.
Old Apr 1, 2010 | 07:42 AM
mrjasey's Avatar
mrjasey
i have the MINTEK red box ones. i dont track or autox, so im not sure how they perform there but they are great on the street.
Old Apr 1, 2010 | 08:34 AM
slinger688's Avatar
slinger688
Just responding to the op on the type of pad Mintek red box would be. He was interested in both street and track pads.
Generally, if you use the pads as intended, they should be pretty decent.
molala
Oct 2, 2015 01:53 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
