How to lose run-flats??
Old Mar 24, 2010 | 12:45 PM
  #26
thevelourfog's Avatar
thevelourfog
Originally Posted by WestonJCW
Just got rid of my run flats 3 days ago.
How long before the tire pressure warning goes away?
Gotta reset it. You sure your tire pressure is correct?
  #27
smpeck's Avatar
smpeck
I had to reset my tire pressure system manually via the onboard computer - check the manual on how to reset. Basically you find the tire pressure option on the Set menu and hold the button in on the stalk for a few seconds. The display will change to "Resetting..." and will take a minute or two.
Old Mar 24, 2010 | 12:54 PM
  #28
smpeck's Avatar
smpeck
Originally Posted by BGM
Third, every time I have a flat I have to buy a new tire?
I went thru this 3 times with the runflats on my BMW 1-series. One had sidewall damage (had to be replaced), one had a screw in it and lost all pressure (had to be replaced) and then a week later one of the new ones had a nail it in but never lost pressure (patched).
Some people will say the RFTs ALWAYS need to be replaced if there is a screw/nail in them. Others will say they can be repaired (i.e. plugged) if the tire never lost pressure.
The shocker is the cost of replacing the RFTs - VERY costly to replace, rarely in stock, etc.
I was happy to get rid of them - your story just confirms to me they aren't foolproof and only offer a slight benefit over traditional tires, not to mention they offer an overly harsh ride.
Best bet is to carry a small spare on long road trips whether u have RFTs or traditional tires. Then you're covered either way.
Old Mar 24, 2010 | 05:22 PM
  #29
WestonJCW's Avatar
WestonJCW
Resetting did the trick.
With run flats this car was great,without them,awesome!
Thxs
Old Mar 25, 2010 | 09:39 AM
  #30
XXLil MickXX's Avatar
XXLil MickXX
I have Goodyear RFT on an 06'. 1st day I drove the car I got a nail in it. I hadn't even completed the purchasing paperwork. The dealer and the local mini dealer said RFT can not be fixed. 360 bones.
I called Goodyear, they had me bring the tire to a store authorized to fix it. 12 dollars and back in bidness.
I can not see throwing these away or keeping them for winter tires. I'll just have to drive them into the ground. It won't be difficult
Old Mar 25, 2010 | 11:22 AM
  #31
Gunner45's Avatar
Gunner45
Run flat tires vs. repair kits.
"What do people that drive motorcycles do if they get a flat??"
We call a tow truck and pay $250 to have our bike dropped at a dealer. I've got CO2, repair kits, cans of tire repair and all that, but with a blowout, you're stuck. I ride a 870 pound Yamaha Venture, so I try to keep good tires on the bike.
Old Mar 25, 2010 | 12:41 PM
  #32
markusw's Avatar
markusw
Originally Posted by 911Fan
Since you're only 17, follow your Dad's advice and keep the runflats. They're not nearly as horrible as some would have you believe.
You can take all the chances you want later in life.
+1. In my opinion, the firm ride feels very sporty.
Old Mar 25, 2010 | 01:49 PM
  #33
Dr Obnxs's Avatar
Dr Obnxs
The debate will never end...
the runflats are not the safety that all think they are. The security isn't universal (as many posted in this thread). The costs are very high. One other thing that others haven't mentioned is that tires with better traction also have better emergency avoidance characteristics as well.
One thing I did see that was pretty cool was the Sport Link kit with a Spare attachement. Then you can carry a full sized spare as well.
Here at AMVIV, I've seen a couple people who have spares in bags as well. But here, you're trading carrying space for a spare tire.
Matt
Old Mar 25, 2010 | 04:08 PM
  #34
Gunner45's Avatar
Gunner45
I don't even see how a compact spare would fit in the compartment. I'll be looking at options when the time comes, but the best I can figure out is have a spare set in the garage in the event of a flat and change out the whole bunch.
Old Mar 26, 2010 | 02:49 PM
  #35
LittleBlueBEAST's Avatar
LittleBlueBEAST
well the guy at justtires offered lifetime insurance that if any of my runflat tires were to get dmaged , bust, whatever he can give me brand new ones.
its only a one time fee of 35$ and another 35$ to renew it after you get your new tires
Old Mar 26, 2010 | 03:07 PM
  #36
tvrgeek's Avatar
tvrgeek
Yes they are. They are too stiff for the weight of the car and cause both ends to "hop" over bumps. Not safe in a corner. Even lowering the pressure to a more appropriate 28 or so in the rear ( forget the buzzer) does not solve the problem. No excuse for a modern car to not keep it's feet on the ground.
I know how to deal with it, as I used to drive a Morgan, but no excuses and I would not let a 17 year old drive a car set up this poorly.
Old Mar 26, 2010 | 03:09 PM
  #37
tvrgeek's Avatar
tvrgeek
I am dumping the rear seat, putting in a full deck, and mounting a full size tire on it.
Old Mar 26, 2010 | 04:36 PM
  #38
Gunner45's Avatar
Gunner45
Spare tire
That'll work.
Old Mar 28, 2010 | 10:24 AM
  #39
MRE7986's Avatar
MRE7986
You may have to reset it, unless you have an r56, they use the valve stems to monitor the tire pressure, make sure they took the old valve stems out an put them in the new tires, there like $250.00 and a million from the dealer.
Old Mar 28, 2010 | 10:32 AM
  #40
MRE7986's Avatar
MRE7986
I experienced first-hand the dilemma run-flats pose, on a road trip from Seattle to SF last week. Roughly 150 miles from SF, my right rear tire went flat. (2009 Mini Cooper Clubman S - 18k miles). It was Saturday, about 6 pm.
Called Mini RA. Told - we will tow to nearest dealership. Which is in Sacramento, the opposite direction from which I'm going. Also, dealership is closed so no help until Monday am. I have a paid for room in SF, plans for Sat. night & Sun., and a business meeting Mon. am.
So I ask - the manual says 50 - 80 miles on the runflats. Is it OK if I drive more? I'm told - absolutely not, will likely damage the wheel, alilgnment, front end, etc.
So I have no alternative - find the only open tire shop, which has 1 tire my size (not a run flat), pay $130 to buy it and have it mounted, and drive to SF
But of course I can't keep that tire on, especially not driving 800+ highway miles home in a few days, so I take it later in the week to the SF Mini dealer who says, can't repair a run-flat, and I get to buy a new tire - $350.
This is nuts. First, no visible damage on the flat - all highway driving, no curbs, etc. Lots of tread on the tire. It should not have gone flat after only 18k easy miles.
Second, Mini RA is worthless. Looking at message boards now, I see people easily drive 200+ on the deflated runflat. But Mini RA is all about not incurring any liability. On my dealer's advice I canceled my AAA because of Mini RA. Stupid me.
Finally, and most troubling, I feel like I can't trust the car/tires on any more road trips.
I don't know what to do.
I begining to learn about these dealerships and how they suck now from when I bought my car 5 years ago. Know they just want your money, they don't help you out. A small leak and they tell you get a new tire, a clutch forms hot spots even when there is a write up on it from the dealer, they wanted 4 grand to put new clutch in, I refused to pay and they took care of it, but still gave me a couple days of having to prove them wrong and that its a manufacture failure. Find out my care is burning alot of oil, another write up, cars from 05, the engine builders were forgetting to put oil rings on the pistons, that sucks I would have to pay a good freing who used to work for a Mini dealership as a tech $1000 to tear my engine apart, and when I complained about this before the warranty was up they told me the car uses alot of oil, Well How about 2 quarts in a 1000 miles. Whatch out the dealerships need a swift kick in the you now what to get your point across. We don't have money like them.
Old Mar 28, 2010 | 03:18 PM
  #41
Herleman's Avatar
Herleman
Did we determine that he has an "S" model? If he's in a Cooper, he probably already has a spare and the whole issue may be moot.
And for what its worth -- there are a number of cars that do not have either a spare or run-flats The latest Miatas and Corvettes as examples. Modern tires are really pretty good if you are not careless with where you drive. (and then there are us motorcycle types who never have a spare tire)
Old Mar 28, 2010 | 05:31 PM
  #42
pillar's Avatar
pillar
just ditched mine 500 miles ago. I must say i do feel rather nervous driving long distances without a spare or fix kit. Arnt runflats suppose to be more responsive than aftermarket tires because of their ridiculously stiff sidewalls? I dont think ill ever go back to them but there is noo way im selling tires that cost as much my new setup.
Old Mar 28, 2010 | 10:48 PM
  #43
The Central Scrutinizer's Avatar
I just replaced my Goodyear Excellence runflats with Falken Ziex 912s ($85 each at America's Tire Co.), and I was blown away by the improvement. Yes, the ride and handling are light-years ahead of the Goodyears.
I bought a Slime kit for the boot, and I have no qualms at all about taking long trips on these tires. In 30 years of driving, I have had to change exactly one tire by the roadside. I like my odds just fine.
Old Mar 29, 2010 | 01:06 AM
  #44
mastawyrm's Avatar
mastawyrm
The stiff sidewall is why they don't have good traction, you need some sidewall squish to get a good contact patch with the pavement.
USA-RET
Oct 27, 2015 10:42 AM
buggyeye401
Oct 1, 2015 01:22 PM
eliseo1981
Sep 30, 2015 07:57 PM
buggyeye401
Sep 28, 2015 04:09 PM
BossyR56
Sep 28, 2015 11:33 AM
