Made a Brake Mistake, need New ones.
I had money and bought cross drilled and slotted rotors. I know now that I didn't need to get them and could of used slotted or even stock, but i will still keep them since they still work well. although they are smaller then the stock rotors. (they still work fine but I am not sure this is a problem.
I also bought EBC Green Stuff. Simple to say that was a bad idea. they fade after 3-4 hard stops. but the do have MUCH less dust.
I decided not to get a BBK since i don't need to worry about heating up my brakes that much on a daily basis.
I have been looking at Hawk HPS and Ferodo DS2500
less dust then stock would be nice, and I want to go for not much noise when braking normally.
I have a 05MC(Non S) R50, I track about 8times a year. no more then 15.
Daily Spirited driving
I am looking for some brakes that bite cold well. since sometimes i cant drive hard when I have passenger. my GF doesn't like when i scare her that much lol.
That are better if even slightly then Stock pads.
I am also putting in SS braided brake lines and ATE super blue when i get the new pads.
So what does NAM recommend?
I many customer running all or part of this setup and loving it and the much less dust then any other. http://www.autoxcooper.com/performancepackages.html
Dustin...
Please check your PMs...
Thanks!
if you want a pad with almost no dust and great bit go woth the carbotech 1521 (bobcat). if you wold like to stop 60 to 0 in about 25 feet COLD get there ax6 pad it is dusty but omg dose it stop. if you plainis to track your car you need to step up to a race compound like there xp8. one thing that is way cool about carbotech is that there pads are enter changeable, with out turning rotors
I have had a lot of good luck with many customers in the Hawk HPS pads. But never track EBC Pads. they can not take the heat. in one day you can go thru a brand new set. not god at all.
ebc compounds where made for 4weelers and snowmobiles form what i told and they are not good any where track/street. hawk hps is low dust but will stop about the same as oem just my 2 cents
I don't know much but my EBC greens do not fade after just a few stops. I read on these forums so often about how EBC pads suck. I had them around the track for many many laps and they did just fine. I am sure there are better options for *really* hard driving but I think they are better than everyone says. I DID have brake fade until having the fluid switched to Motul brake fluid though... After that it was great.
You feel there is a performance difference between slotted rotors and slotted/drilled rotors? The rotors you purchased are *smaller* than stock?
Regarding the size of the rotors. i do not have measurements. and its just from stacking one on top of the other. i did notice the rotors were maybe about 4mm difference.
Thanks for all suggestions. i think i will go with the CarboTechs of the Hawk's then. Thank you all
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
aldito2
Nov 25, 2015 09:33 PM
