Automatic Transmission Fluid
Old Mar 25, 2008 | 11:20 AM
yritchey's Avatar
yritchey
Can anyone tell me where I add automatic transmission fluid and what type of fluid do I use. I cannot find a dipstick or a filler tube.
Old Mar 26, 2008 | 04:25 AM
jggimi's Avatar
jggimi
AFAIK, the tranny on the R56 is the Aisin TF-60SN. This is described as the world's first 6-speed AT for 3L and under FWD vehicles, using a Lepelletier gearing system.
Here's a parts list. Note that there is no dipstick, and no filler tube. My assumption is that if you want to change the fluid, you take it to your local AT specialist.
http://www.automaticchoice.com/Catalogue/tf60sn.pdf
Old Mar 26, 2008 | 05:27 AM
djam43's Avatar
djam43
Sealed for "life"
Old Mar 26, 2008 | 07:46 AM
sfkarp's Avatar
sfkarp
I ran into this already with my MCS automatic. The trans has lifetime fluid in it. The dealer has to add any fluid and use some kind of procedure to make sure the level is correct.
Old Mar 26, 2008 | 10:34 AM
condor27596's Avatar
condor27596
It might be a complicated procedure too.
I wish a bentley manual would come out.
On my 3 series you had to jack it up level,
with the engine running, and in drive (after cycling
through all the gears a number of times), then
while in drive measure the temperature between
like 95 and 105F (forget), then top off the fluid.
Of course billybob just puts fluid in until it runs out
the hole and off you go......
But that's a whole nuther thread!
Old May 10, 2010 | 01:42 PM
greensilk's Avatar
greensilk
has anyone used bebi bilstein automatic transmission fluid for a 2003 mini cooper???
Old May 10, 2010 | 01:43 PM
greensilk's Avatar
greensilk
sorry its febi...
Old May 10, 2010 | 03:09 PM
RJKimbell's Avatar
RJKimbell
sorry its febi...
You've posted in the 2nd Gen. Forum (2007+), you'll find more over in the 1st Gen Forum's.
Good Luck!!
Old May 10, 2010 | 08:10 PM
toolazyforalogin's Avatar
toolazyforalogin
yeah don't touch the tranny fluid.......you can read a few horror stories from people who accidentally thought the tranny plug was their oil plug.....yikes!
Old May 11, 2010 | 10:25 AM
strobeyprobey's Avatar
strobeyprobey
Oh boy....don't any of you read your service manual in the glove box? My USA 2008 service manual clearly states 100,000 miles for an automatic transmission service.
Our automatics are not lifetime fluid and are not sealed. And even if they specified the ATF was lifetime, how can you not recommend it be changed?
MINI specifies an ATX fluid change at 100,000 miles!!!
Let me repeat that...
Last edited by strobeyprobey; May 11, 2010 at 10:32 AM. Reason: Trying to add some flare to my post to get some atttention
Old May 11, 2010 | 11:24 AM
sequence's Avatar
sequence
there's another thread about this somewhere here-- the dealer can flush and change the fluid, and some who track or auto-x their autos--and/or live in hot weather--change it much more frequently, like every 25-30K.
molala
Oct 2, 2015 01:53 PM
thadscottmoore
Sep 25, 2015 10:07 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Ntety
Sep 2, 2015 08:39 PM
