215 for 17x7 VS. 215 for 17x7.5
Old Jan 18, 2008 | 07:40 PM
crazyaboutmini's Avatar
crazyaboutmini
ok so i want an aggressive stance for the city... i currently have rims that are 7inches wide and i was planning to put 215's on them. but i got a good deal with these rims that are 7.5inches wide... since i heard issues fitting wide tires in lowered r53's and i want to lower the car a lil more eventually then i'm stuck with 215's.... so will there be a width difference between putting 215's on a 7 inch and a 7.5 inch wide rims? thanks.
Old Jan 18, 2008 | 07:48 PM
minimarks's Avatar
minimarks
215/45/17s on 7" with no rubbing problems on TSW springs (about 1"), don't see why a 7.5 would be a problem at all unless you go a lot lower...
Old Jan 18, 2008 | 09:13 PM
tazio's Avatar
tazio
Offset?
Old Jan 20, 2008 | 03:18 PM
crazyaboutmini
sorry for a long reply, busy all weekend... the wheel i was interested in is the Kazera KZ-A Dual PCD 17x7.5 with 45mm offset. it has the nismo look, the ones they offer for the 350z.
Old Jan 22, 2008 | 12:00 AM
crazyaboutmini
bump... just want to know if the two sizes with the same tire width will be visually different? thanks
Old Jan 22, 2008 | 06:22 AM
Alex@tirerack's Avatar
Alex@tirerack
To a keen eye, sure due to sidewall tilt angles
Alex
Old Jan 22, 2008 | 05:10 PM
crazyaboutmini
ok cool, thanks for the clarification alex
Old Jan 23, 2008 | 05:14 PM
NoModMini's Avatar
NoModMini
________________________________________________
...seems to me that to keep the backspace the same you'd need an offset of about 35 or so, otherwise you might be rubbing on the inside somewhere....with a 45 offset you'll probably need a spacer
Old Jan 23, 2008 | 05:26 PM
WC50 408's Avatar
WC50 408
I'm running 215/45/17 on 17x7.5 with et 42. They are on a GP which has the JCW suspension, about 1 inch lower than stock, and have no issues at all. I had also ran same tire on 17x7 with et37 and no issues as well. Hope this helps
Old Jan 23, 2008 | 06:10 PM
tazio's Avatar
tazio
Running 215/45 on 17x7s with ET45 I was getting some rubbing at full compression with 5mm spacers in the rear and 15mm up front and JCW suspension (which actually has only about a 1/2" drop btw). No rubbing now with no spacers in the rear and 8mm up front.
Old Jan 24, 2008 | 03:59 PM
crazyaboutmini
i would understand that 215/45/17 has a bigger diameter than stock size (205/45/17). how about running 215/40/17? whats the diameter compared with stock? maybe we can run this and still be wider and have cushion close to stock?
NYMADMINI
Dec 14, 2016 02:33 PM
Chibi2
May 19, 2016 03:46 PM
luisfv56
Nov 16, 2015 01:55 PM
StrongIslandMini
Sep 19, 2015 10:58 AM
StrongIslandMini
Sep 16, 2015 12:58 AM
