Widest tires possible
Old Oct 17, 2007 | 07:19 PM
amg56aaf's Avatar
amg56aaf
What is the widest 16" tire that will fit on a stock ride hight 04 mini cooper s? Also just for the fun of it what is the largest 17" tire that will work? Thanks for your help
Old Oct 17, 2007 | 08:32 PM
verveAbsolut's Avatar
verveAbsolut
First off, I think this is in the wrong forum?
To get to the question: It depends on your wheel (which in turn depends on offset and use of spacers or not). Also dependent are whether you intend to do some body/fender work to make sure you won't have problems with scrub radius.
Anyways, the max sizes I have seen are in the 225-235 range.
- Matt
Old Oct 19, 2007 | 05:30 PM
jefeant's Avatar
jefeant
I run 245x45x17 on S-lites = no problem at all, even lowered 1" with Altas.
Highly recommended, lots better ride, gear ratio and stance.
Old Oct 19, 2007 | 05:32 PM
jeffc's Avatar
jeffc
7th Gear
Any pictures?
Old Oct 20, 2007 | 12:26 AM
verveAbsolut
How did you fit 245's on a 17x7 rim (S-Lites)?
- Matt
Old Oct 20, 2007 | 01:01 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Search for the answer, it's been discussed before.
https://www.northamericanmotoring.co...ad.php?t=62253
https://www.northamericanmotoring.co...d.php?t=112010
Also check the autocross forums, there are many extra wide tires that are used but realize that the widest possible tires will limit your tire selection.
Why do you want wide tires anyway? For Looks?
Personally I like 275/35-15
https://www.northamericanmotoring.co...ad.php?t=87381
Old Oct 20, 2007 | 03:36 AM
minihune's Avatar
minihune
This tread moved from Suspension to Tires, Wheels & Brakes forum.
Please post in the correct forum.
The widest tire that will fit will depend on which rim you use and how willing you are to trim the wheel well arch plastic or buy wider fenders.
Assuming a normal MINI with stock suspension.
If you find 16x8" rims like Rota Slipstream
4x100 bolt pattern with +34mm offset the outer edge of the rim is almost flush with the outer edge of the plastic arch. If you choose +45 or +48 offset and the rim is wide like 8" then there will be not enough clearance for the rear lower trailing arm- you'll need a 10mm spacer to push the wheel outwards for clearance.
You'll need to buy tires that are smaller than stock to have the best clearance and certainly not taller than stock or you'll risk rubbing. Realize that wider rims and wider tires means more weight so for street driving at normal speeds this isn't helpful but for track use or autocross with no speed limits then wider tires and sticky rubber is very helpful- also wears out fast.
225/45-16 will fit 16x8 rims (fits 7-8.5" rims) 23.9" tire diameter
Kumho Ecsta SPT (Ultra High performance Summer tire) $100 each
320 treadwear
and
245/45-16 will fit 16x8 rims (fits 7.5-9" rims) 24.6" tire diameter
Bridgestone Potenza RE750 $134 340 treadwear
Fuzion ZRi $89 320 treadwear
Yokohama AVS ES100 $109 280 treadwear
Stock MINIs will lack the front negative camber needed to make full use of the front tires- stock MINIs will tend to wear out the front outer edges of the tires very fast when doing performance driving- the inner edges are hardly worn.
If you have 17x8 rims (watch the offset, about +35mm) then
you can mount
235/40-17 fits rims 8-9.5" wide 24.4" tire diameter
or
245/40-17 fits rims 8-9.5" wide 24.7" tire diameter
Both available in Fuzion ZRi
Old Oct 22, 2007 | 04:04 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
So, minihune are those really 275's? Or is this a typo? If it is what size are they, their HUGE!
Old Oct 22, 2007 | 04:39 PM
minihune's Avatar
minihune
I try not to type in error.
275/35-15 to fit the MINI.
You do need to cut the wheel arch plastic a lot to make it fit.
http://www.tirerack.com/tires/Sizes....rtnum=735ZR5A6
Fits rims 9-11" wide,Perfect for 9.5" wide rim, 20 lbs! Section width 10.8", Tread width 10.1", 23" tire diameter
Compare with what I use on a 15x8" rim.
225/45-15 same Hoosier A6 tire
Fits rims 7-9" wide,Perfect for 8" wide rim, 20 lbs! Section width 9.8", Tread width 9", 22.8" tire diameter
Be aware that after you put in tires that large, ask yourself what sort of street wheels and tires you'd want to install for daily use. If you have a track only MINI then it's fine.
Old Oct 22, 2007 | 04:55 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks minihune That helps a lot.
Old Dec 19, 2007 | 06:57 PM
COR BLMY's Avatar
COR BLMY
you can mount
or
hello "hue"
So if I Auto x and do track I CAN use a 235 or 245 ?
offset 35 (the tracklites i am looking at are ET 42 so spacers may be needed...?
Ohhh and so many 235 and 245 40s are on back order
i need a set up fot next seasion starting in march and want to be ready ...
Old Dec 19, 2007 | 10:17 PM
minihune's Avatar
minihune
Originally Posted by COR BLMY
hello "hue"
When I search Tirerack I can only find
Motegi Track Traklite Flat Black 17x7 +42mm offset 14 lbs $280 each
235 or 245mm wide tires need rims 8" or wider not 7".
Do you have a source for 17x8" Traklites?
When you put a wider tire on a narrow rim expect tramlining when doing street driving on grooved surfaces such as highways.
Old Dec 19, 2007 | 10:41 PM
SlowB00st's Avatar
SlowB00st
Yeah they make the tracklite in 17 x 8 its one of the wheels im thinking of buying for my R56. Still can't decide :impatient
Check ebay or/and in tirerack.com under mr2 spyder rear fitments...
Old Dec 19, 2007 | 11:39 PM
terryg's Avatar
terryg
The Traklite2 17x8" 4x100's have a +42mm offset. I want to get a set for my R56, but I was hoping to avoid spacers.
Old Dec 20, 2007 | 09:30 AM
COR BLMY's Avatar
COR BLMY
Americas Tire (my local choice for all my other cars rims and tires ...and the street KDW2s) can get 17 x 8.
But a ET of 42 will put me on my fender (VERY modified and trimed already)
that is why I thought I was after a 45 ET (or more) then space as needed
These will be track / auto-x only with either Hoosiers or the BFG R1
TRAKLITE 2.0 Teflon® Black
1-piece forged alloy, painted center, machined lip
TRAKLITE 2.0 Silver
TRAKLITE 2.0 Glossy Black
Part No. 2312-7849
Size 17 x 8
Offset 42
Backside 6 1/8
Bolt Pattern 4x100
Weight 14 lbs
Old Dec 20, 2007 | 10:57 AM
kapps's Avatar
kapps
The 35 offset is on their 15x7's but not the 17x8's.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
