Show me your WHEELS!
Old Sep 17, 2007 | 02:03 PM
  #4476
minipooper02's Avatar
minipooper02
NEW RiMS
How are these..... New RIMS and tires....
Attached Thumbnails Show me your WHEELS!-main-mini.jpg   Show me your WHEELS!-side.jpg
Old Sep 17, 2007 | 02:08 PM
  #4477
PGT's Avatar
PGT
/\ ebay specials?
Old Sep 17, 2007 | 04:57 PM
  #4478
kenchan's Avatar
kenchan
^ COLD!
Old Sep 17, 2007 | 05:13 PM
  #4479
HighSchoolzMINI's Avatar
HighSchoolzMINI
^ wow +1
Old Sep 17, 2007 | 05:15 PM
  #4480
PGT's Avatar
PGT
sorry, I didn't mean that to be mean. That's the only place I see ADR wheels and Lexani tires. where else do you buy them? I'd rock a set with A/S tires for winter...cheap is good
Old Sep 17, 2007 | 05:29 PM
  #4481
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Those arent lexxan tires there nexxen and they happen to be pretty good...edge racing carries them....
Jack
Old Sep 17, 2007 | 06:24 PM
  #4482
goin440's Avatar
goin440
well then... if Edge carries them
Old Sep 17, 2007 | 06:41 PM
  #4483
Rally@StanceDesign's Avatar
Rally@StanceDesign
Old Sep 17, 2007 | 06:56 PM
  #4484
kenchan's Avatar
kenchan
yah, just put some xx's in the name and you're good to go.
Old Sep 17, 2007 | 08:15 PM
  #4485
Rally@StanceDesign
just the lip
Old Sep 17, 2007 | 08:20 PM
  #4486
70spop's Avatar
70spop
Originally Posted by RallyMINI
just the lip
Good GAWD, man!! Those are stickin' out a bit, aren't they? I think, though, that you've barely, technically met the minimum requirement of the tread being under the fender.
Old Sep 17, 2007 | 08:22 PM
  #4487
Rally@StanceDesign
yup no tread shows......should be adding some camber shortly once i get the rear control arms installed. That should help tuck them a bit
Old Sep 17, 2007 | 08:34 PM
  #4488
kenchan's Avatar
kenchan
hummm... calling out for a wide body kit (wider arches).
  #4489
Wake|MCS's Avatar
Wake|MCS
Those are some extremely low offsets. Looks like you could go lower and use some more negative camber.. Any more pics?
Old Sep 17, 2007 | 08:59 PM
  #4490
70spop's Avatar
70spop
Yeah, but then he'd need wider tires, and knowing Rally, then he'd need 10 inch rims, and we'd be back at the same place.
Old Sep 17, 2007 | 09:06 PM
  #4491
kenchan's Avatar
kenchan
yah, you're right. 10" rims belong on my G.
Old Sep 18, 2007 | 07:18 AM
  #4492
Rally@StanceDesign
Indigo just shipped out a set of rear control arms for me....getting them installed before i head to H2ointernational with konky...which of course will call for a photoshoot. Once I get some camber in the rear and finally get around to setting some camber up in front on my camber plates....i will be going lower
I'm working on customizing a set of OEM rear arches to attempt to extend them just a little bit(nothing crazy like the currently available wide arches/kits). I'm trying to achieve the pulled fender technique seen on cars with metal fenders.....but obviously with our plastic arches. Hopefully it works out
Old Sep 18, 2007 | 07:45 AM
  #4493
kyriian's Avatar
kyriian
why not try fiberglass a copy of the current arches and just painting it
Old Sep 18, 2007 | 08:05 AM
  #4494
Rally@StanceDesign
Too much work for a one-off project. It would require making a mold of an extended arch version for each side. If i planned on making multiple copies....that would definitely be the way to go.
Since I'm just making a copy for my car, 'pulling' the plastic arches should do the trick. This post has an example of what I'm looking to do.....before and after pics of a pulled fender (in metal). It has the same vertical lip that our arches has......you can pull that outwards to allow more room. http://www.motoringunderground.com/f...8&postcount=26
Old Sep 18, 2007 | 08:24 AM
  #4495
DJKazzer's Avatar
DJKazzer
17" HP Racing Black w/ chrome lip and Federal SS595 tires
Sorry for the low-quality pics. I really love these wheels and the ride.
Old Sep 18, 2007 | 09:19 AM
  #4496
Rally@StanceDesign
.. Any more pics?
The most recent pics.....2/3rds of the way done restoring the centercaps. Just one more piece left
Old Sep 18, 2007 | 10:12 AM
  #4497
Konky's Avatar
Konky
baller.
Old Sep 18, 2007 | 10:26 AM
  #4498
HABUTGO's Avatar
HABUTGO
finally new shoes, and now i can load my mini on this thread!! yay =)
SSR MS1R Professor 17x7.5
Old Sep 18, 2007 | 10:29 AM
  #4499
kenchan's Avatar
kenchan
^^ woah, very original!
Old Sep 18, 2007 | 10:58 AM
  #4500
MiniStupidfun's Avatar
MiniStupidfun
I like that
