Rota RB's now available in 17"
#201
Also do the stock Mini center caps work on Rotas?
Do you include shipping,
mounting hardware (lugs and centering ring)?
What about tax?
--Dan
Mach V
#202
Will the offset of the wheel make a difference with the control arm? I see that some Rota's come in 35,38, 40, 42 and 45mm offfsets. Wouldn't that be the same as using spacers.... if a lower offset is used therefore effectively moving the wheel out to the edge of the wheelwell? Will it then clear the contol arm? Thanks for responding.
#203
Why not just go with 16's? 16" tires are still inexpensive, and the wheel/tire set won't weigh much more.
--Dan
Mach V
#204
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·...¸><((((º>`·.¸¸.·´¯ `· .¸.·´¯`·...¸><((((º>
That's 3% smaller than stock. A general rule of thumb to keep your gearing and speedometer accuracy close to correct is to keep tire size within 2% of stock. I would not run the 215/40R17. Too small. See this excellent tire size calculator.
A lot of the 15" Rota wheels will not fit without a spacer at the back axle because they'll run into the rear control arm. I think all of them will fit over the brake calipers, though.
No. You can peel off the "R" labels though, and apply a custom label. Lots of vinyl shops will make you one.
Please add whatever parts you want to your shopping cart and enter your zip code for a shipping quote.
Hubcentric rings are included if necessary. You'll re-use your stock lug bolts.
You only pay tax if we're shipping to Virginia.
--Dan
Mach V
--Dan
Mach V
#205
You know I am a webspoke wheel lover but I do like these more. I was about to pull the trigger but I have to see what they look like on a car with the aero kit. Just worried the classic look of the wheel and the aggressive look of the kit may not work together. Having a hard time seeing it in my head.
What would work for me is I have a PW/B and would go with a royal black w/ polished lip. The black center would probably tone down the middle some. I think they would look great but have to see it first. Keep waiting until someone posts a pic if they have one.
#206
Dan,
I am confused. I thought I wasn't as I have researched extensively all threads pertaining to 15 inch wheels, offset, tire width etc. I see some run 225/50/15 with "finger widths" clearing the control arms no problem (8 inch wheel "POST" here on NAM); 205/55/15 fitting no problem fitting with stock height and other variables (Mini Hune); and 195/60/15 being a nice combination of "ride, comfort and width". So what doesn't clear or doesn't fit? In your opinion is it the tire with stock offset (45mm) and wide(r) tires (195 or 205 or 225); is it the wheel with with stock offset (even though less offset variations are available)? You recommend spacers but don't seem to like less offset. Does a 40mm offset affect the steering and geometry that much? Will a 42mm work in size of wheel, clearance, tire size, stering and geometry? Please make a suggestion as to what will work. How will a 16 inch work any differently as offset amounts can be the same and tire width can be the equal to any 15 inch wheel/tire. Maybe it goes back to what doesn't fit with a 15 inch wheel/tire combination. I appreciate your time and patience. This has been confusing for me, but, I think the questions are legitimate. Thank you again.
#207
The problem is not the tire fitment, but the WHEEL itself, bumping into the rear control arm. It has nothing to do with the tire. The Rota 15's we have tried will contact the metal control arm with the metal wheel.
The 16" wheel fits fine because there's more control arm room out farther as the wheel gets larger in diameter.
--Dan
Mach V
--Dan
Mach V
#208
So I have to totally forget about Rota's if I want 15 inch wheels? Additionally a lower offset which moves the wheel out further to the fender and moves the wheel away from the control arm teamed with a thinner 195/60/15 tire instead of 205/55/15 or 225/50/15 won't work? While some other 15 inch wheel brands are recommended, what is significantly different about Rota's that they won't work. Don't worry, you don't need to answer that question. Spacers though, you have said, will work in fitting Rota 15 inch wheels. Well, thank you very much for your time. I genuinely appreciate it. I'll have to do the best I can.
#210
on
What are my options if I want a different center cap?? The one that come with the RB's look good if they are black or dark silver. But on white they stick out like a sore thumb. Not to mention one of mine chipped when I put it on
Anyway of getting something to sit flush?
Oh.... here are mine..
#211
I sent the design to Aesthetic Creations with the specs. for the exact dia. and several months later, they sent me these:
#213
on
Like this: http://www.prestigewheel.com/cgi-bin...n&key=99-95095
#214
#218
Looks like these are now highest in the running for my new wheels. I'm looking forward to seeing how they look on the Mach V. Is a 1mm hub adapter just too thin to work properly? or could it be custom fabricated?
Search Engine Optimization
Google Results
Google Results
#219
--Dan
Mach V
DrFraserCrane
08-30-2015 01:11 PM
